High-mileage motor oil ??
I drive an older toyota and the last time I took it in for an oil change they recommended a new oil called maxlife (Valoline). Not sure if it was a synthetic but the technician said it was recommended for all cars with over 75k miles. I went ahead and bought it after the guy told me it could help my car run better, condition seals and some other stuff I cant remember. My question is, is anyone else using this oil and does older cars have different needs regarding engine oil?
Jim
Jim
Many people use it and it seems to work for the AARP engines
max life is not a bad oil but it is not an api certified oil due to the fact they load up higher levels of antiwear additives and such. i would not recommend going over 3 to 4,000 miles on this oil for oil change intervals.
this oil will not hurt your engine and you might even find it to perform a little better due to the higher levels of barrier lubricant that they use.
bob in jville.
Lubricant Specialist
http://www.bobistheoilguy.com
I have a 89 Nissan with just under 190k on it now,
I have always used 10w40, but for the last couple years I add STP now, No change in gas mileage but cranks better and sounds better
Lots of folks don't approve of STP (VI increaser and ZDDP) so be prepared, and remember it does have limitations.
Good luck
Rando
Can't say it is harmful, but my own opinion is that it is relatively useless.
see ya
Rando
I agree it is not needed (or desired) in low mileage engines, but once that motor has some time and miles, oh yeah, it hits the spot. It does hold up the viscosity end of the deal just fine, it is thick when you look at it in the can by itself, but when it is mixed with the oil (in the right proportion mind you) it just keeps it from thinning too much when heated..
I have compared used 10w30 and used 10w40/stp in 2 mayo jars after changing oil and you can't tell a difference at room temp, they both thicken right up (both the same consistency)when I put them in the freezer , I did not check them however when hot so I can't compare them while hot in that mayo jar anyway...
Use it properly it will be your friend, use it wrong and you are correct, it will mess you up.
Just remember if you want the motor to last as long as possible, you will have to thicken up when it starts aging a little...when that motor gets some worn areas you cannot un-wear them , that's true, but you can work with it to get some more time out of it,
see ya
We all getting ready for the game?
See, the "science" of STP just doesn't make any sense to me.
If it's thick enough to "cling" to the engine after shut off, then it's too thick to flow in a hot engine. If it magically gets thin to flow in a hot engine, then it's too thin to supposedly "fill in" the clearances on worn engines.
It's thick when it should be thin (cold engine), and thin when it should be thick (hot engine).
Besides, no oil is going to fill in gaps in piston clearance for very long once it warms up.
And since it is so thick, I presume that STP wants you to think tha the thickness is really doing something. What? Who the hell knows? Not me.
My position on motor oil is obviously different than some posters on here, that's ok. I just have priorities that are different than some other folks. My goal for motor oil leans a little to the metal protection side, some folks lean to the better gas mileage side. I understand that to do things my way includes certain restrictions and I follow them, I also intend to keep vehicles for a long time when I buy them. Some people lease vehicles or at least replace them every few years, and would have a different incentive...fewer oil changes and better mileage suits them better. Just depends on your priorities...
The government priority is for the CAFE to increase and for the manufacturers to achieve that they have to go the lightweight oil way, the manufacturer could care less what happens to me after warranty is up though and particularly could care less after my truck hits 100k...but I do care. SO that's what pushes me to use the heavier oil, I could care less about the .2 mpg I may save myself using light oil.
See y'all
Good morning
Rando
I found a case of this stuff in our garage a decade ago and used it in just about every internal combustion engine we had, especially the older vehicles that burned oil. The most damning anectdotal evidence I have is from using it in our ATC200E 3-wheeler. This was an air-cooled, single cylinder engine that shares a sump with the gearbox and it didn't take too much time before this stuff to become as thin as water when at operating temperature. It and the oil (20W50? straight 30?) were a golden color (like new) but it dripped off my dipstick like warm 5W30. Thanks, but no thanks. I'd only use this goo in a basket case that I was just trying to keep going a few more months.
--- Bror Jace
NOw some will say don't mix synthetic with regular, yadda, yadda, yadda.
Over time the oil seals do tend to dry up it bit and loose their flexibility and sealing. THe Max-Life adds a larger amount of seal conditioner to the oil mix, and a slightly more detergents to the base oil.
Max-life doesn't come exactly cheap, about $2 a quart. So just try some half regular oil (I assume you use conventional) and half Max-Life, and maintain you usual interval, or change it a bit earlier.
add CD-2 detergent
add STP
add Bar's stop leak
then you would have any brand of maxlife you want.
Wouldn't Maxlife oil just be the same as adding your own additives on top of your normal oil (in the right proportions)
Not being a smart aleck here , really, just asking, I know I take a lot of heat for adding STP to oil for older engines, but isn't maxlife doing the same thing?
Rando
why not just use a good blend to start with. no guess work involved.
I'm sure all that zinc isn't the best for cat. converters, but I'm also sure that theres a lot of old beaters out there that do just fine on the stuff. If it squeezes out another 10,000 on some old clunker with 180K on the odo. what's wrong with that?
My friend used to use synthetics in his cars (like I do) but he has switched his whole fleet over to Valvoline Max-Life. He loves the stuff. It doesn't hurt that we purchased several 5-quart jugs of this stuff for $5 each. >;^) he uses it in a bunch of Hondas while I use it in my dad's 4.6L V8 Ford ... which is known to have valve seal problems.
STP is just goo. It is very unstable and should only be used as a band-aid for basket-case engines.
Blending can be fun but I reserve it for really old junkers and/or single-cylinder lawn & garden equipment. Besides, add up the cost of all those additives and it probably exceeds the cost of Max-Life oil ... even when it's not on sale.
--- Bror Jace
Chain & bar lube seems to be a 50/50 mix of STP and 20 weight oil. REALLY sticky stuff.
spokane, that sounds like it would work great. I just use K&N oil. What little I bought will last several lifetimes.
--- Bror Jace
Is the Group III the same as the CASTROL SYNTEC but Maxlife is just charging the correct price for it? If that is true, once the word gets around, Castrol Syntec would have to drop price to compete with it wouldn't they?
BROR, the last jug of bar/chain oil I had was vegetable based oil according to the label, it was real sticky too!
Good Morning
Rando
I understand the different base stock oils to be as follows:
Group I stocks - traditional dino (mineral) oil.
Group II & III stocks - hydrocracked?isodewaxed/isomerized mineral stocks known as UHVI - Ultra High Viscosity Index.
(I think the difference between these two groups is the degree to which they are processed.)
Group IV - PAO
Group V - Esters: polyol (& dibasic?)
I'm sure this is overly simplistic but it's a start to understanding the 'big picture'. Perhaps others have comments as well.
There is more technical info on hydrocracking and base oils on Chevron's website (Chevron.com if memory serves).
As for Castrol lowering their price, I wouldn't hold your breath. Think of the average DIYer that might consider buying synthetic oil in a discount store like Wal-Mart/K-mart. I doubt they know the difference. The stuff is at least decent so unless they are like us and like to talk cars, racing and maintenenace on-line, how will they ever find out? Especially since Castrol spends so much on advertising saying how they are the best, yada, yada, yada ... Hype is king.
--- Bror Jace
-Tyson
That was the Castrol example...
Havoline example would be, now you wash with detergent water, suds start getting darker/greasy/filthy looking, then you rinse off with detergent water,,,,,the runoff now is dirty soapy water....
It seems that like BROR said, Castrol has less emphasis on the detergent aspect of motor oil, at least with my engine it seems like the Havoline is cleaning up old deposits left over from before.
All I know is I'd rather give money to the Havoline folks than the Castrol folks, CastrolGTX was king of the 70's, and reputation carried them futher than that, but now, they seem to be living on left over reputation from back then. Just my personal thing...
see ya,
Thanks Bror
later
Rando
-Tyson
Maybe someone on here knows if the color could be due to breakdown...HMMMM,,,, I think I see a test coming up........campfire with a grill grate....
aluminum foil with 2 dimples with 2 samples of oil.....
Castrol vs Havoline......hhmmmmm....sounds like a drinking event to me...
anybody know the answer here???
see ya
Rando
The down side is that they don't have the superior cold weather starts like synthetic. But in my area it doesn't get that cold.
I spent a couple of weeks researching this and am convinced enough to currently have in 3 quarts of Maxlife, and 1 quart of Synpower. I still like the increased wear reduction of a synthetic. I'm going to go on a vacation in May then get the oil analyzed. Will let people know then.
Gotta go see the passing of the Torch. Happy Olympics, and God Bless America. We need it.
Armtdm- Is Amsoil ATF a PAO?? I'm thinking of going to it because Mobil 1 is not. Guess I'll have to become a dealer again. I can pick up the stuff 20 miles away. How much to be a dealer?? Used to be $25.
However, Ashland Oil Co. has some rather convincing testimonials on their web site as to the value of this oil. They even say that you can use it in new or rebuilt engines. The seal expansion of only 5% additional material is only a small part of the additive package. They have additional anti wear additives that are not permitted by the newest oil specifications. And I just assume SL and GF-3 spec.
All I know is what I've read on this site and from what I understand these additional additives may have an adverse effect on the sulfuric acid generator, i.e. catalytic convertor.
Current annual fee for me is $20 I believe and, as my local jobber has inventory, plus Richmond airport is a distribution center, I can pick oil up for $4.35/quart plus tax. ATF is big bucks though, like $7/quart, don't remember, now comes in 2 1/2 gal container. My containers of Amsoil sitting in my garage are the most valuable things in my garage right now as I only make the trek to the jobber once or twice a year so with five cars I maintain I usually drop $100 at every visit.
