Let us know what the dealer says.
Take care
Still lovin the FreeStyle !
Only once (for about 5-10 seconds) it felt underpowered. Out of 4,000 miles. And that was because CVTs are slower "off the line" than a n-gear transmission. Once the CVT is revved up, it's clobbering time. (And thus the Pacifica-for-lunch 8.5 sec times.)
I've been near home in the situation of stepping on the pedal to merge into a road between two vehicles, trying to beat the latter. By the time I turn my head from merge to road, I must press the brake to avoid whacking the first car. By that time, Freebie's in the 40+ MPH range. Impressive for such a "huge" vehicle with a "minuscule" engine. :surprise:
Granted, we shouldn't go "mano a mano" (Spanish lesson: hand-to-hand, as in combat) with a Hemi Magnum. At least not until Cyclone (Duratec 35) is out. Perhaps it'll need the Torotrak IVT too.
Of course, even a 5-passenger H-Mag can't be as fast as carrying all 7 people in one shot. :P
Sam
I didn't see much change, other than color changes. There was a talk of heat/cool seats (like Mercury Monterey), but seems it ain't so.
Check out the ordering info for MY2006: fordaxz.com guide
Hope that helps.
Sam
1) Speed up to 70 mph
2) Set cruise control to 70 mph
3) Hit brakes
4) Slow down to 45 mph
5) Hit RESUME on the speed control
6) Hang on!
Actually, every Ford cruise control I've tried (which basically means Taurus, Freestyle, Five Hundred) has behaved this way. The RESUME very quickly revs up the engine and accelerates like crazy to get you back to the preset speed. Far faster than I'd do it myself.
here's what you do. (I'll be overly thurough for the novices out there)
1. order a fm modulator off ebay. I got the ANABA AVFM2. they are going for $25 (after shipping) on ebay right now. (example: 5789649960)
2. when it arrives pull off the drivers side plastic cover near the floor (start by the front of the passenger seat and pull out - nothing will break), then pull off the daash panel by openning the top glove compartment and pulling on the panel - again no screws, no breaking - it just slides out. I removed the air bag light wire just to get it out of the way.
3. unscrew the 4 screws holding in the radio.
4. unplug the orange antenna wire from the back of the radio, then plug in the wire that comes with the modulator, then plug the orange wire back into the female jack that comes with the modulator.
5. pull the end of the antenna adapter through the side panel that you removed earlier and lay it on the floor.
6. replace radio and 4 screws (you may have to bend the new antenna wire to a 90 degree angle like the orange wire to make it fit.
7. while the dash panel is still off, I used little wire connectors (look up scotch locks on ebay to see what I used, then go to autozone to pick some up for $2) to connect the power leads to the back of the cig. lighter power leads; black on black (if the other wire doesn't match colors don't worry, just connect it). ignore the instructions about power antenna leads. feed wire down through floor side panel
8. replace any wires that you temporarily disconnected and dash panel.
9.connect antenna connector, power connector, and audio connector that comes with modulator to the modulator itself. set the frequency you want to broadcast on based on the instructions. make sure you use a empty channel in your area because once the car is on, this thing is transmitting even when not connected to an audio source.
10. there is an empty area in that side panel closer to the seat that the black box fits neatly into. place the box in there and leave the audio cable hanging out on the floor, tuck the other wires in.
11. replace side panel.
viola!
Enjoy. Tony
Why oh why no AUX IN? It's not just Sirius, but IPODS, etc.
It is nice to be able to reach back to the area behind the seat for things and not have your head against a back glass. Also, the power port and cup holders are handy. The rear air system is very good, although Ford products have long been known for having the best air conditioning available in cars.
I really like how the third row folds backwards with the rear hatch open to provide shaded seating and viewing at my kid's soccer practice.
:shades:
I tried (two) FM modulators but felt that the sound quality (crackles, static) was terrible.
I searched for aftermarket iPod adapters and found several models. Unfortunately none of them will work with the Visteon 6 CD changer that I have. Apparently the AUX input is for the DVD player and the manufacturers of the iPod adapters have not yet been able to get them to work.
I looked at aftermarket stereo replacements and found several options that would work. The most elegant solutions (Alpine) are very expensive ($500+).
I decided on an Aiwa unit from Crutchfield with a mini plug AUX input on the front panel. I paid $99 for the head unit (Model CDC-X304) $10 for the wire harness and $15 for the face plate adapter.
http://www.crutchfield.com/S-zGAbveUlwAr/cgi-bin/ProdView.asp?g=300&I=055CDCX304
It took about 20 minutes to install and sounds much better (in my opinion) than the Visteon unit. The trim adapter includes a handy pocket (that I plan to place the iPod in) and is cosmetically satisfactory. The only drawback is that the steering wheel volume control no longer works (I wasn't using them anyway).
This ought to work to improve the sound quality for those using satellite radio.
regards,
webbcam
By the way, did you know that Ford is using a CVT with its hybrid Escape SUV? On a related note, Lexus (Toyota) is using a CVT on its hybrid RX 400 :shades:
If you disagree with this, please let me know. I eager for some feedback.
The bench is comfortable for adults. They also benefit from the nice Freestyle entry height. It sits just right and is two inched higher than the front seats. Also, either side folds flat and makes a nice armrest or a table for my kid to do his homework on the way home. The conversation mirror makes it easy to keep an eye on him to be certain he is doing his homework instead of watching a DVD with the cordless headset that is included.
This is correct. Apparently the radio works on the CAN (Controlled Area Network), and you need a device (like this particular DVD player) that also uses CAN so that the radio will recognize it.
Hybrid's basically HAVE to have a transmission like a CVT. Why? Because they have to work in reverse as generators to charge the batteries.
Also, would you say that the manual (specifically the one below) is more for fixing things that have broken or would regular maintenance schedule things be covered as well. I'm more interested in doing my own maintenance and not sure if this is the right manual for me to purchase.
2005 Five Hundred/Montego/Freestyle Workshop Manuals
Price: $145.00
Part # FCS1394905
JJ
I have ridden on the bench in the {parent/grandparent} {parent/child/child} {child} configuration and it's perfectly comfortable, similar to the front row in fact.
The bench folds flat, in a plane with the passenger seat and 3rd row (a plane that's pitched toward the rear in an interesting study in optical perception).
The Helm manuals are full of line drawings (think pen and ink-like), tables, and step by step directions. That is not to say every description is perfectly clear, but I found the manuals to be fairly accurate overall. They do go into excruciating detail for engine and CVT teardown, which hopefully you never need to deal with. But, disassembling a door or air intake or brake system for repair can be useful. In other words, there are pages you will never use, and some you are glad you have. You will learn much more about how the various parts of the Freestyle operate, part numbers of each part (down to a screw) and even the color of the transmission fluid (blue-green). Hope that helps. :shades:
I'm figuring captain's chairs will probably be a better option when the kids are out of car seats. It keeps them separated, and I can add the console so they'll have a place for their things.
Honestly, I don't think it really matters which one you go with with respect to car seats. I think your choice should really be governed by whether you need to fit 6 pass or 7 passengers.
Anyone else have this experience and what would you guess is the source of the noise.?
Ford service rep must have hearing problems, or does not want to deal with troubleshooting it, or thinks it is normal sound. I understand the CVT is complex and maybe dealer does not want to tackle it. Any feedback is appreciated.
July 18. Now I have been told by two Ford dealers that the Freestyle will be
dropped after the 2007 model year - if not sooner. Does anyone else have
anything further about this ? I was all set to buy one and now am very hesitant
figuring the bottom will fall out on value.
I don't think anyone has any more information than what's already been posted here. It sounds to me like Ford plans to keep some sort of wagon based on the D3 platform, but perhaps not called the Freestyle. Because it's a shared platform, it's not like parts will disappear (the CVT is used in the Five Hundred, etc). And I can pretty much guarantee if the sales double they won't touch it, though of course Ford isn't helping matters by not investing properly in marketing the vehicle or educating their dealers about it (I knew 10x more about the Freebie than the salesman I bought it from).
Or just think of it this way, did the bottom fall out on resale value for Shelby Cobras after only a few years of production?
Then there are those that are concerned that a car is being dropped. All cars are eventually "dropped," but in the case of the Freeestyle, it will just be a model change. Models do change. The Freestyle is unique, but relatively expensive to make because there is no shared sheetmetal with the 500 or Montego.
The uniqueness of the current Freestyle, when they are no longer available, should keep the value relatively higher. I predict people will be clamoring for the CVT as soon as the word gets around a little more. Every Freestyle has one.
Also, Freestyle sales are trending upward. Ford will be watching the numbers. They dropped the discontinuance of the Excursion after announcing its demise when demand surged.
By the way, do you think the current T-Bird will have the bottom fall out of its value now that it is no longer being produced?
The article implies that Ford Motor is in total disarray.
Maybe you should buy a Freestyle while you can because soon maybe the car will not be available.
I have a Lincoln town car and a Freestyle. The Freestyle is a terrific vehicle that is well designed and well engineered. My wife and I fight over who is going to drive the freestyle and the Lincoln sits in the driveway. I am thinking about buying another Freestyle before the car is hard to find and i have to pay up for it!
I really think that if the Freestyle will be dropped it's because of the introduction of the Mercury Meta One concept vehicle at that time. And you could always pick one of those up in a few years and probably get 30% better gas mileage to boot.
This D3 platform is the best handling platform I have ever had in a larger car. I can't fathom Ford not utilizing this chasis within it's American product line for their family customers.
Meanwhile, the NAME Freestyle will probably soldier on, but on something else, perhaps completely different. I wonder if THAT is a mistake...At least the too similar Freestar name is to be dropped, from all indications.
The person who said that Freestyle sales are hurting Explorer probably hit the nail right on the head. I bet the Mercury version of the current Freestyle is MUCH more expensive....and it will give Lincoln Mercury dealers an exclusive they weren't supposed to have otherwise...
They should just drop the Expolorer and replace it with the Freestyle!
It seems to me that that is a good place for ford to start laying people off. The public relations with respect to the Freestyle have been a disaster.
Unfortunately with the rumors now rampant that the freestyle is to dicontinued who will want to buy one? Ford now needs (soon) to hire some new public relations people who understand the Freestyle and be honest with ford Consumers about the future of the Freestyle.
The Freestyle is driving the automotive press crazy because they can't conveniently classify the vehicle into one of their pigeonholes. They just will not accept that it is a new breed of vehicle with loads of utility, the best safety rating and some very forward technology inside.
A note to Lee Iacocca. I took your advise. -- I did find a better car than a Chrysler, and I bought it.
It's the Five Hundred Wagon, plain and simple.
Sure, it's different than most wagons. Kinda like the Five Hundred is different than most sedans.
The press has been so caught up in the SUV craze that they don't know a REAL wagon when they see it. Everyone seems to think that only the SUV term will sell vehicles.
It's sad really. It's a great wagon....WAGON...there, I said it.
It says to use the set-up button to run the system test and then at that time oil life comes up on the screen press(pull) the setup and reset together when the oil life comes up.
I have tried this about a dozen times and it has not reset. Can someone give me the secret?
I discovered the Freestyle in a parking lot while I was waiting for my wife. A lady pulled up next to me in a Freestyle and I could see immediately it was an interesting new car. It appeared to have a lower center of gravity than most SUVS on the road and the lines of station wagon yet the cargo space of a SUV. I have a 1989 Country Squire that I am looking to replace so the Freestyle instantly appealed to me. I asked the lady how she liked the car and she smiled and said she loved it. She proceeded with a great deal of enthusiasm to show me all the great selling points of the car. My wife came out and looked at the car and also loved it . We went to the local Ford dealer and took a Freestyle for a test drive and loved it. We bought a new Freestyle that afternoon and now fight over who is going to drive this wonderfully engineered vehicle.
It wasn't the Ford dealer that sold us this unique new vehicle it was an owner! This car has to be sold or it will just be lost in amongst all the other vehicles at new car dealers inventory. Salesman seem to want the manufacturer to come up with a car that sells itself. That usually requires radical appearance changes and not mechanical things that make a car a better vehicle. I believe chrysler is doing these radical appearance changes.
The development of this vehicle and its uniqueness are an interesting story. Ford should get the story out rather than abandon the vehicle as is rumored. They have a winner but they don't seem to know it! A lot of good planing and engineering went into this vehicle and to give up at this stage of the game is going to be a very costly mistake.
