Chevy S10 - GMC S15 and Sonoma Accessories & Modifications
For the longest time I have always wanted to drop an LS-1 motor into it. You can get them from GM performance. I have no idea how much they cost, and haven't really researched it yet, although I am sure that the monetary amount needed to do such a conversion is not a couple hundered dollar job. That is why this is still a pipe dream, but I would really like to do it so I am thinking out the logistics of getting the motor into the truck all monetary needs aside.
Can it be done? And if so how difficult is it? What would need to be done to get this accomplished? Sounds crazy I know, but I know that people take the old 80's style S-10 and drop 350s into them all the time. Most of them are carbed and basic setups. This involves electronics, computers that involve everything from shift points on the transmission to the spedometer reading... so it's not just a simple transplant I'm sure.... but can it be done. Remember, price really isn't an issue since I know it probably isn't cheap and if I ever do it, I have an idea of what it would cost and I am willing to spend that much, but just not yet. (One, I can't afford it, and two, I have other priorities at hand. Oh yeah and 3, it's my only truck and so if I do the conversion I would have to go get another truck to use as a "truck"). When I am able to afford it, the other priorities will proably be taken care of.
Does anyone know if putting a newer (1989 or newer) model's 4.3L V6 in will help me avoid having to do a transmission swap?
I have no idea if they are compatible, hoping someone else does or has another suggestion.
Thanks, Marc
Good day everyone,
I am looking to replace the shocks on my rig. It's a '99 S-10 (4.3L, auto, reg. cab-short bed) with ZQ8 suspension package. I was wondering if anyone here replaced their shocks on their ZQ8 truck and if so:
Which shocks did you use
Where did you get them
Cost
I've checked a couple of places like Rock Auto, Edelbrock, Summit (gateway from the Edelbrock site) and GMPartsDirect but it they are hella-expensive (especially if I go with the AC Delco replacements :surprise: ).
Also, was wondering if anyone has replaced the oil cooler lines and if so:
How difficult of a job was it
Any special tools / tricks & tips needed
Specific steps / procedures needed to be followed
Is there a better, more robust assembly than the OEM assembly, particularly at the hard-line to rubber hose crimps
Am I better off taking the truck in to have it done
Thanks everyone
JAE
I have a factory steering wheel with the airbag in the center. The airbag is perfect but the steering wheel that holds it is in extreme disrepair. I thought about sacrificing the airbag and getting an aftermarket wheel. However, the initial research says there are or may be issues when an airbag is in the factor. Has anyone else changed and airbagged wheel on a late 90's early 2000 S-10? Any help would be great.
The ZR2 also has 3in lift from factory an comes with 31X10.5 R15 tires. So either sell your stock s10 an get a Z or lift the one you have. You could always do a suspension lift an bigger tires and a accessory body lift. I have a 96 ZR2 with some performance mods and I love it. Wouldn't trade it for anything else.
