Chevy S10 - GMC S15 and Sonoma Accessories & Modifications
Anyone have the hard tonneau that is offered by Chevrolet? What do you think of it and how much are dealers charging? Are there any sources for OEM Chevrolet accessories with good prices on the internet?
The spray-in are said to be better because they hold loads better, will not crack, split or warp, and have a watertight seal to prevent rust and corrosion.
I have had good experience with both drop-in and spray-in liners, they are not worth the money in benifits that they offer, but they are worth the money to me because I like my trucks more with a bed liner.
on it and found out there aren't any predrilled holes?
Does anyone know of a clip on bug shield?
If you've put a bug shield on what name brand did
you choose?
I couldn't be happier with my S10 so far.
I just purchased my very first truck yesterday! It's a 1999 S-10 4X4 V-6 vortec extended cab! We will be replacing the current bedliner with the Rhino soon! I am glad to join you!
Has anyone had any experiences with it, good or bad? Is it hard to remove if the need arises? Has anyone used any of the other snapless covers like those roll-n-lock type covers or the Access cover with the ribs built into the cover?
Now, my question is: what difference is it going to make to my truck if I opt for the 4.3 instead of the 2.8? I have heard that the carbeurator *may* need to be replaced with a more apporopriate one for that stronger engine, that the only change will be better torque and less fuel economy, I have also heard that the 2.8 liter engines with more mileage do not hold up so well with repairs.
Does anyone have an educated answer for this quandry?
Thank you,
Michael RedTurtle
Thanks for any help suggested,
Chip
I broke my cell phone which had your number in it...Call me if you want to go to the beach on Sunday 07/24/05 @at my same number.
Andy
AlexRA
HELP!!! I need to figure out what to do.
don't answer if you don't know what you're talking about for sure
starving for air,
brad
put the lugnuts on and leave them loose about one turn
drive slowly around the block
stop and check if the rim has come loose
if it hasnt; drive around the block again
repeat till it comes loose
this will work for axles and brake drums too.
It looks like I can remove the plastic corners and the short bumper and replace it with the
long one piece newer bumper, brackets and all. Anyone have any experience?
Ok well when I dropped it I used springs and blocks, 4" drop! I put new rims and toyo directional tires on it! Well I had to have the transmission rebuilt because they said the drop put too much strain on my transmission and they say that it will always shift hard in second no matter what I do simply because it is lowered! Its not really that bad but its not great either!
Also now I have noticed that the inside of my front tires are wearing fast where the rest of the tires are still perfect! My husband screwed my rims on too tight one time and it bent my rims very slightly so they are saying its because of the rims and because it is dropped that if I want to keep a set of tires I need to raise it back up, but obviously I dont want to do that!! And the rims were expensive and I like them so I really dont want to replace them! But they are giving me crap saying that it is just unsafe! Hell Its been like this for 4 years, never a problem, if I have to change the tires every other year, oh well! And noone wants to do an alignment for me since it is dropped, not that the alignment is bad its just that it seems like I have a lot of pressure on the inner tire, where it would obviously be a lot better if it were evenly distributed!
Anyone else have any problems like this!
