Transmission fluid change-which method is better?
This question was asked about a year ago, but everyone got off the subject. What are the pros and cons of the two transmission change methods:drop the pan, change filter, change half the fluid versus pumping out 100% of the fluid with no filter change. I have a '99 Ford Escort and the manual just says "service the transmission fluid every 30,000 miles". The Ford dealer wanted $120 dollars for the pump out method.
I've found transmission shops can service your fluids for about $50.
You can drop the pan and change it yourself for a lot less than $120, too. Even multiple times. Just be sure to spread out a bunch of dropcloth and wear goggles!
Also, there are "oil extractors" out there...I hear they work. Search the net under "oil extractor," or check out the Edmunds forum under "oil changes."
While under warranty I would do what the book says to do.
After the warranty I would do the 100% fluid flush about every 30k and change the filter after every other flush. Keeping newer fluid in the transmission helps keep seals in good shape and keeps the fluid properties at new fluid levels and avoids any heat related decomposition from being a long term issue. The transmission filters I have seen did not have any blockage issues, the main issue was the fluid condition
CLick & Clack, the guys on NPR, said that if you have 75-100K, dont open it up, its just as likely to cause problems.
A "flush" (not a pump out change ) is fine but "no one does it properly" due to cost. After flushing the system the pan should be dropped as the gunk is removed and sits in the pan and can and has caused problems.
Now, if you are simply pumping out the old fluid via the cooler line then that is fine. However, overall I think this is overkill. For the cost of fluid (if you have a plug) drain and fill yourself. Measure the amount taken out as this is much easier then filling up and overfilling as it is a pain to remove the fluid if overfilled. Remember, check when tranny is hot and engine running.
No one does it properly? Not one? Nobody at all? Anywhere? Ever?
Btw, some newer models of flushing machines attach to the trans at the pump suction port normally occupied by the filter. They make a bit of a mess but they replace all of the fluid. Every drop. How one could attach one of these flushers to the trans without first removing the pan and filter is beyond me.
For the Caravan, it's cheaper than a new transmission.
Change at 10K.
Alcan, can you please clarify a point regarding torque converter pump-out. Isn't there considerable mixing of the old and new ATF as the new ATF is pumped in because the path through the converter is not one of First-In/First-Out? Isn't it necessary to put some 7 or 8 quarts of new ATF through a 5-quart converter to achieve a reasonable purge percentage of the old ATF? I am not familiar with solvent flushing but, if you are purging cleaning solvent from the converter with new ATF, what is the criteria for being assured you have "gone far enough?" Thanks.
Am I the only one who misses having drain plugs on the torque converter as some had 30 years ago?
I appreciate all who contribute to the board...
What's the story on synthetic fluid and changes?
I usually change trans fluid every 10K.
1. Remove fill plug/vent cap.
2. Refill minus about 1 quart.
3. Jack up car, remove right front wheel so you can see level hole easier.
4. Start engine. Let it run long enough to warm up trans to operating temp. Shift through all ranges to distribute fluid.
5. Remove oil level plug in side of trans. Engine should still be running.
6. Lower jack down so car is relatively level.
7. Add fluid until it comes up to bottom of level plug hole, or till it just runs out (easier unless you like jumping up and down a lot).
8. Replace level hole plug. Don't turn engine off with the plug out unless you want to start again.
9. Jack car back up, put wheel back on.
10. Don't forget to put the fluid fill/vent cap back on.
I had the car in the shop last week for a minor warranty repair, and I was discussing the tranny fluid thing with the service manager. I asked him about doing a change,(they have the flush&fill machine) and he said,"Save your money, bring it in at 30,000 miles". They did, however, put it up on the lift and check the level.
I'm used to doing my own maintenance, which involved changing the fluid and filter annually.
Thanks for the friendly advice, neighbor.
The best answer may be to just "pay the man".
If you take your time and loosen it up such that the oil drains out of one corner its not really messy. When you pull the filter off make sure that the rubber gasket/oring comes off with it. When going back together use a light coat of grease to hold the gasket in place. The filter rests on a shelf attached to the housing. Difficult to screw up.
The only trouble I had was the torque value of pan bolts. The manual indicated 96 in/lbs. The filter box indicated 144 in/lbs max. I went with about 120 in/lbs and had leaks. Went to 150 in/lbs-no problem. Filter/gasket kit was $8 at Advance.
Al
Napa has good filters and good (quality material and THICK) gaskets come with them, but they are more expensive at Napa.
Like ADC100 said, make sure you have pan clearance, I have a 95 s10 Blazer and the back part of the pan is above a frame cross member which had to be removed to get the pan out (it only lacked clearance by about 1/2 inch!!)
Most vehicles do not have that type problem though. Good luck!
As to the torque, I have basically given up on the OEM recommendations. Especially for valve covers and oil and tranny pans. Valve cover I could almost hand turn when it started to seep so now I re torque via the "seems tight to me method". In my experience it seems better to over tighten (not to strip or break) these bolts. The dealers and mechanics seem to have the opposite belief and I wind up having to tighten them when they begin to seep.
I do have ramps so time to give it a try
What has been you experience, how did the filter look when some of you replaced it?
99- change all fluid (fluid-exchange at quickie-lube place) at 30k, and pan/filter at 50k, added Lubeguard at 50k change-------------filter material still looked like new (not exactly but very clean for what I expected) at the 50k change.
95- pan and filter at 52k, all fluid at 75k, all fluid at 98k, pan and filter at 125k, added Lubeguard at last pan/filter change.----------------filter material was slightly darker than new material, but still in very good shape.
I did the pan/fluid changes at Cottman's Transmission, price was good ($30 for labor and fluid (not synthetic),, and the 95 has to have that frame member undone (stupid Chevy engineer tricks!!!!),
From what I have seen, the main thing for trannie fluid is to check periodically for color and smell, making sure there is no overheating issues that would be breaking down the additives. If it does not get overheated, the DexronIII actually seems to last pretty good,,,,,LOTS better than the older DexronII ever did.
Both transmissions are shifting as well as when new, (knocking on wood as I type!!!:)
The brake fluid replacement is a different story. In another life I used to work summers at my dads service station. Back then we used a power brake bleeder to supply fluid under pressure and cracked the bleeder valve at all 4 wheels. I don't know how they do brake fluid replacement today, but i assume it is similar to this.
30K is premature for both of these fluids to be replaced. However its your car and your money.
Happy driving.
The manual says to change the transmission fluid at 30K. If I have the brake fluid changed at an independent garage will it matter if they use "Honda" brake fluid?
That's quite a bit different than your 2k model. I changed mine at ~45k. I now have 62k on my 15 month old accord and no problems to report other than the odd rattle here and there on rough roads.
For the trans and power steering it is important to use honda fluids. I'm not sure about the brake fluid.
Is power steering fluid something I can easily do myself?
It is strange that the change interval changed so dramatically in only one model year. It kind of bothers me with all of the automatic transmission trouble on the Accord thread. Thankfully mine has been fine and I hope changing the fluid is all I need to do to it for about 10 years.
Now, I'm a believer in preventive maintenance and had the engine, transmission, and cooling systems flushed on my pre-owned 3.5RL, but these services were done at 45K/4 years, not 7.5K/six months!
Regarding Honda ATF-got a tranny code at around 70K-turns out my fluid was a bit burnt and discolored. Changed the ATF using honda fluid and reset the CEL and no problems 60K later. Would suggest changing ATF every 30 to 35K. I think mine requires about 2.8 quarts. You will need one of those funnel things with a long clear tube attached to pour the ATF into the ATF dip/fill hole. Oh and drive it at least 30 miles to get the ATF good and hot. Be very careful when removing the drain plug-that fluid gets extremely hot and can fry your skin. I wear protective gloves and am very careful-it really squirts out. Changing atf is easier than changing oil.
2. drain the fluid.
3. close the pan / drain plug
4. Start the engine
5. shift through gears
6. drop the pan/ open the drain plug
* I assume most of the fluid from the Torque convertor must have now been pumped into the gear area *
7. drain the fluid.
8. change the filter
9. reseal the pan / drain plug
10. Start the engine
11. add ATF through the ATF dipstick hole
Anything wrong with this method?
Also, shifting into gear with virtually no fluid pressure will allow clutch/band slippage.
So, filter had caught very little contaminants, a few specs of debris here and there but basically clean. Now, the magnets (3 of them in the pan) were all covered with debris, more like thick oil and pan was basically clean. From what I could see into the transmission after removing the filter it looked really clean, no varnish, no build up of any kind, clean metal and whatever else was used. However, based upon the debris on the magnets it was due for a clean out. In the future, if ever done again I will just drop pan and clean magnets. The screen was a waste of time and money. Been using Amsoil synthetic ATF since 25,000 miles on transmission.
I got 108,000 out of a Windstar before the engine gave up, but no trouble with the transmission. I have 135,000 on an Explorer on the original transmission, no troubles there either (I even pull a 2,000 pound trailer with it from time-to-time). I plan to stay with that system until it lets me down.
http://www.bgprod.com/autodrive.html
Anyone have any experiences with it? How well does it work? They recommend the service every 25K and they drop the pan/change the filter at 50K and 100K. Price quoted is $119 per flush, and they'll throw in the pan drop/filter change for free at the 50K and 100K service.
