Visitor Agreement.
a trans change on hondas only replace approx. 25% of the oil and when it remixes it throughs that % off. 2002 odessey tells you to change the oil 4 times with a short drive in between each change at 30,000 I think all hondas could probably fall under the same maint. scheduale
my used honda had a bad color to it so i changed trans oil every eng oil change till it looked healthy again now every 2nd or 3rd oil change i change the trans oil
One of these days will try to change all the atf by disconnecting the hot side of the ATF cooler and connecting it to a large clear plastic bottle and while running the engine, attempt to put new atf into it at about the same rate as it flows into the jug connected to the atf cooler inlet. Have had a couple of different people suggest this approach.
For those people using the machines to change atf-ever wonder how much of their cleaning solvent remains in your tranny-something to think about-betcha it don't meet any atf standard anywhere.
you're going to spill/squirt ATF no matter what you do, so you will want a nice bed of absorbent underneath, and have a place scoped out that can take it for proper disposal.
every time I have to try and get liquid down one of those danged skinny "filler necks," I get an airlock from a bubble and lose about half the quart of fluid, anyway. seems like this would be a better resolution.
warning, I bet that bucket will empty quickly under pump suction, have somebody atop the ladder ready to yell "look OUT!" when they can almost see the bucket bottom.
After the change, my Previa will make big clunk sound as soon as I let the brake go from a stop to go.
Did not know what it was, but check the transmission oil level. It was way above upper part of
hot level. I drained it and about 4.3 quarts came out. The manual calls out 2.5 quart capacity.
The moral of story, the thunking sound disapeared and convinced that this particular bad dealer did overfilled. Be cautious.
The following is observed:
1. I can not fix the “HOLD” button on the AT shifter in neither ON or OFF position
2. The “HOLD” sign on the indicator blinks.
3. When I drive the car, the engine does not shift to the 4-th (overdrive) gear.
4. After resetting computer the symptoms 1 and 2 disappear, but only temporarily -- until the car moves a few meters. Then it all (symptoms 1, 2 and 3 combined) starts over again.
Probably, the problem is not a mechanical in origin but rather a failure of some electrical circuits. Mechanic who replaced the tranny has already inspected visually all the electrical connections of the transmission unit but did not find anything wrong.
Anyone can help here?
Thanks a lot!
Thanks a lot!
good luck
hint: just work with 1 connector at a time
see ya
clubs.It can be easily broken down in boiling water(212*F).
Better compare the temp of the fluid vs. the temp of breakdown.JMO
see ya
you could also go to Autzones website look up capacity and they will give you the total however you'll have to subtract what had come from the tranny
The 4L60E holds approximately 11 quarts of fluid. a fluid and filter change only gets out about 5 quarts. A fluid change only, gets out less than 3 quarts.
As for the taking the drain plug out as often as I do, how is it any different than taking my drain plug out of my oil pan every 3,000 miles when I do an oil change? I've never wore out the threads in my oil pans at this interval. If by chance I do wear out my tranny pans threads, I'll just buy another one for $40 at my local dealership.
I do alot of stop and go driving and tow occasionally with my truck. This is hard on the transmission. Even though I have a tranny cooler, it needs all the help it can get. Fluid is cheap and it doesn't take much time to do and I have the piece of mind knowing that I always have fresh transmission fluid.
Wayne
Most of the [non-permissible content removed] cars have a drain plug. I will drain the Toyota each year (3-4 qts) and the E150 each 2 yrs because I can get 90% out of the E150. Most USA cars have no drain plugs; nesessitating the addition of a drain plug after the 1st time I drain & change the filter.
I'm a nut with fluid changes: Antifreeze, ATF, Rear Differential, Power steering, and brake fluid every 2 yrs. Engine oil: 3K + filter. Fram is junk. Use the Purolator or OEM. Fram went to Mexico yrs ago. When I switched to Purolator about 5 yrs ago I discovered both my /6 Chrysler and Toyota Minivan stopped clattering upon startup. The Frams had cheap valves. I use dino oil (Castrol or Valvoline).
There is also a cheap fix,either change a spring or block the valve.
If your tranmission starts to hard shift go for 1 of the repairs ASAP.
Now, I have been warned that if a tranny has not been serviced for a long time (I have 80K on mine, bought it at 68K, so I think it has 80K with no service), doing a flush may screw things up. Thus, I opted for a less stressful solution. I sucked 2.5 quarts of the old fluid through the dipstick, and added 2.5 quarts of new fluid. I will dirve the car for a day, and then repeat this 4 or 5 times. By then, 80% of the fluid will be new. My idea is that if the detergents in the new fluid are dislodging crap from the tranny, it will not be as dramatic as if I did it all at once, and I would also be removing some of the junk with every drain/refill.
My plan is that after I do this and I have given the tranny time to 'adjust' to having new fluid, I will do a regular complete 'two-bucket' flush.
I know that it sounds really cumbersome, but is it a reasonable thing to do? Any comments and words of wisdom will be welcomed.
G.
rubiconno gasket. I just torque them to 20 ft lbs-get the torque value for yours. (20 should be OK though) Believe me, it won't come loose.
G.
I suggest changing every 30K-the Honda owners manual says change at 90K except in extreme conditions. I do all highway driving and thought this would not cause the ATF to over heat-wrong.
G.
I'm getting 2.5-3 quarts through the dipstick, but it would be nicer to let it drain to remove all the crud out...
G.
Please Advise!!!!!
Several people I know have said to completely change the ATF, disconnect the ATF line to the ATF cooler and divert it with a flexible tube to a large clear container, start the engine and fill at the same rate as the drain container fills. Sounds like a keystone cops maneuver but it might work.
I have not tried this, and probably won't.
Regarding elaborate schemes re brazed fittings on buckets, etc, to refill the trans, forget it. Pump suction is from the lower sump in the trans, which coincidentally is where the filter is usually located, not from a cooler line.
lots of chances to disturb dirt or do something wrong with the filter change method.
