Diesel in Gas engine
h1vch1vc Member Posts: 295
edited March 2014 in Ford
my supercrew ran outa gas, someone game me a tank of fuel, said it was gas, but was diesel, I put it in, definitely put in less than 2.5 galon, probably around 1.5gal. Should I let ford fix it or can I put in high grade gas and start it, people told me i could do that. If putting in gas is ok, how much damage will that make to any components? Thanks.
    vwracervwracer Member Posts: 90
    I wouldn't take a chance. Drain the fuel tank and start all over
    jgmilbergjgmilberg Member Posts: 872
    Diesel is NASTY stuff, I am not sure about what it will do to your engine but it will clog up your fuel filter in a heartbeat. Best thing to do is drain the tank and start over like vwracer said. It is easy enough to do these days, you just disconnect the fuel line from the filter, stick it in a DIESEL can, or oil drain pan, and jump the fuel pump relay until its dry. Then fill up with high grade gas with a bottle of dry gas in it, sometimes diesel has moisture in it, so the residue that is left behind might have some too it's just a precaution.
    zr2randozr2rando Member Posts: 391
    I agree, empty out the tank and refill with some gas,,,,it could be worse, I've seen people put gas in a diesel!
    fowvayfowvay Member Posts: 29
    Well, this will go against the other peoples responses but I don't believe that you will have much trouble with the amount of diesel that you are talking about. I am unfamiliar with the vehicle that it is in but I will make the assumption that it will hold well over 25 gallons of fuel. With a dilution ratio of 16.5 to 1 you should have no trouble burning the diesel fuel up.
    You will experience some sooting that will disappear after a few tanks of gasoline are burned through the engine. The diesel fuel will drop the octane of the gasoline quite a bit so be certain to use the absolute highest grade you can find. Fill with as much high octane gasoline as you can get into the vehicle and then run this tank as empty as you feel safe doing without running out on the motorway. As for clogging a fuel filter, this is not a issue in the least. If your machine uses paper for the gasoline filter then the diesel will cause absolutely zero problems and will pass through the filter unnoticed.
    Good luck with whichever method you decide.
    al_saadallahal_saadallah Member Posts: 23
    what would gasoline do to a diesel engine?
    Since cetane (diesel) is the opposite of octane (gasoline) then having too high of a gasoline-to-diesel ratio in diesel engine will simply prevent it from running at all. Diesel ignites from cylinder pressure and gasoline needs a ignition source. If you put gasoline in a diesel engine with no ignition source then it simply will not ignite. However, using gasoline to dilute waxed diesel fuel in extremely cold weather was once a common practice before the direct-injection and common-rail injection systems. So, having a gallon of gasoline in a 20 gallon mixture of diesel fuel will simply cause rough running yet will prevent the diesel from gelling. DO NOT put gasoline in a modern TDI or CDI diesel engine deliberately.
    opera_house_wkopera_house_wk Member Posts: 326
    I'd put 5 gal of gas in it to thin it out and try and pump some of it out. I'd worry more about running the pump dry. Then I would put another 5 gal in and drive it to a station and put some premium in. Not a full tank. Just to prevent some knocking. Don't drive it hard. It should drive OK. A friend in college used to run his car on 50/50 back when diesel was cheap. Smoked a little. Another has an army surplus engine that you start on gasoline and then switch over to diesel
    Putting gas in a diesel engine causes HEAVY pre-ignition...gas wants to burn much faster than diesel. Gasoline is a solvent to diesel fuel in cold weather, that is true, but under normal running conditions it will do alot of knocking in that diesel engine..
    If you don't pump/siphon the diesel out it would probably just smoke a bunch and carbon up the cylinders and the EGR valve, that is true, but if you put gasoline in a diesel you get the same as a very low octane condition and get alot of knocking, eventually you get piston damage if it is bad enough..
    High octane is like HEAVY fuel, it needs LOTS of air to burn and does not ignite quickly, but does burn hotter..
    Low octane is like LIGHT fuel, needs less air but does not generate as much heat either....
    Kerosene and diesel is a heavy fuel compared to gasoline, and they both act like a high octane fuel compared to gasoline, they need more air and more UUMPH to go bang, and in a normal gas engine they will cause a RICH condition (soot-unburned fuel) if there is enough of it in the gas.
    Either way if it is diluted the engine will handle it, but generally you want the lightest gas you can get that does not knock too much..
    too much knocking is damaging, and too heavy fuel is just causing more soot, because the air mix can only burn so much fuel...
    High compression engines (diesels..) need higher octane grade fuels to prevent pre-ignition, and usually that higher octane grade fuel is considered lower grade fuel (less refined)
    see ya
    Rando
    Yes, the Army uses multi-fuel engines, but of course they are specially designed to do this.
    You should be able to get most of the diesel out by a simple siphon. Then fill the tank and you should be fine.
    I'm a bit surprised the diesel pump actually fit into your truck's filler neck. The guy must have tried pretty hard to get it in there.
    zr2rando,
    I don't mean to be impolite by disagreeing with you but your information is slightly wrong. Diesel fuel is known as a heavy fuel because it carries 16 carbon atoms per chain as opposed to a higher refined gasoline that carries 8 carbon atoms (hence the name OCTane).
    This is the reason gasoline is so much more volatile and has such higher aromatics.
    The part that I disagree with you on is this:
    "High compression engines (diesels..) need higher octane grade fuels to prevent pre-ignition, and usually that higher octane grade fuel is considered lower grade fuel (less refined)"
    Octane pertains to gasoline and not to diesel fuel. Octane is the gasolines resistance to burning - the higher the octane, the slower and more complete the burn and the less likely the fuel is to "pre-ignite" before you would want it to.
    Cetane pertains to diesel fuel. A higher cetane will provide a more precise timing of the fuel combustion especially at start-up on cold engines. The diesel engine works on the principle of "pre-ignition" on a system that has no "post-ignition". Diesel fuel has absolutely nothing to do with octane and the high compression of a diesel engine should not be compared to a high compression gasoline engine.
    swschradswschrad Member Posts: 2,171
    gasoline in a diesel tank will do the same thing that blowing half a can of starting ether into the air cleaner will do... blow the heads into the next county, and possible break the block. the difference between gasoline and diesel is not only that diesel has more energy in complex chemical bonds, but that this energy releases more slowly. gasoline is a very much more volatile fuel, as soon as the injector starts spraying it into the hot cylinder, it can cook off.
    used to be that some garages would actually recommend putting a pint or so of diesel into a full tank of gas as an upper lube. since the fuel filter changes were done every ten thousand miles, a disposeable element inside or just in front of the carb, it was a no-brainer cheap change. so nobody ever noticed the candle wicks and sludge in the fuel filters from diesel. of course, that was back when Dinah Shore was still on the air.
    Gasoline is made of several different weight hydrocarbons, "oct"ane is only one of them, and there are several ARRANGEMENTS of those octanes.
    The octane rating of gasoline only refers to 2 compounds, normal heptane and " iso-octane " or 2,2,4-trimethyl pentane...
    I was saying that the higher compression engines need the slower burning fuel in order to start burning at the right point in compression cycle, the lighter componants in the gasoline will start burning earlier under those conditions and cause the knocking which would damage the engine. I should have said that the diesel needs the higher WEIGHT fuel rather than higher OCTANE...
    As far as the Diesel fuel in the Gas tank, I agree with MR_Shiftright about the Diesel nozzle should not fit in the gas tank, but if it was just pumped out of a drum with a barrel pump...
    see y'all
    I had to get my old Chemical Engineering books out to remember which particular "oct"ane that the octane rating was referring to, but then I looked around on the web.
    If anyone wants to read some cool pages on gas grades, here's a couple:
    http://www.faqs.org/faqs/autos/gasoline-faq/part1/
    http://crystal.biol.csufresno.edu:8080/projects/9.html
    http://www.ftc.gov/bcp/conline/pubs/autos/octane.htm
    http://www.earlham.edu/~chem/pages/gasoline/grades.html
    It was interesting reading back on some of that material, kinda made me think back to some of those classes....hmmm....what else can we talk about
    see ya!
    rando
    note: that 2nd one you have to copy/paste the whole thing, it wierded out on me
    arjay1arjay1 Member Posts: 172
    Putting diesel fuel into a gasoline based vehicle is not difficult, as is referenced above. The nozzle on the diesel pump is actually very slim, it will easily fit into the opening for a gasoline tank on your truck. The opposite is what is difficult.
    The opening in for the filler on the diesel vehicle is made very small so that you cannot accidentally put gasoline into a diesel tank. As Swschrad referenced above, that is a very explosive mistake. Gasoline in a diesel engine can blow up real nice.
    Since the diesel opening and nozzle are very slim, the nozzle will easily fit into a gasoline filler tube.
    I am also of the thought that the diesel in the gasoline tank will not hurt. It will lubricate the upper end of the engine for a change.
    shiposhipo Member Posts: 9,148
    I don't know where you are getting your diesel, but every time I rent a truck and have to fill it up, the nozzle for the diesel pump is an easy twice the size of a standard un-leaded gasoline nozzle. I have never seen a diesel nozzle that would come anywhere near fitting into the filler opening on a gasoline powered car.
    Best Regards,
    Shipo
    Yeah, me neither, but I'm in California where people get flowers in their salads.
    Here in Missouri the diesel nozzle is very slim. Everytime I would fill-up I would think about the big rigs having to fill-up a few hundred gallons through that little nozzle.
    My tank is 25gal.
    It wasn't at the pump. The truck was on the highway, we got a ride to the station, wanted to buy a gas tank, lady said they didn't have any but for $20 we could use theirs, so she gives us their can, it had fuel in it, we asked if it was unleaded, she said yes and we dumped it in.
    Ah, well, then, you can charge HER for this mess.
    mullins87mullins87 Member Posts: 959
    Same goes for around here. The diesel nozzles for trucks wouldn't begin to fit in an "unleaded only" filler neck. The nozzles for the semi's won't even fit in my truck either.
    But she won't admit it though.
    That's okay. There's a witness and there might be a receipt. Good enough for small claims.
    WHitnesses say they don't want to get involved, so we didn't bother to get their info. No receipt.
    Ah, well, still your word against theirs, and you could have a mechanic certify that they extracted diesel fuel from your tank. Sometimes just the supeona for small Claims is enough to get them to cough up something.
    They should pay you. It was their fault, 100% slam-dunk their responsibility unless the can had DIESEL written all over it (doubt it, huh?)
    Ford did a diagnosis and found diesel in the tank. It was a regular gas, red, can. The problem is that there is no way to prove that she gave us diesel. She could say that we put the diesel in the can then into the truck.
    Maybe she'll step up and do the right thing. You could tell her what happened. Not everyone is a weasel in the world or an Enron CEO. Many people take responsibility, and really, this isn't going to cost too much, right?
    She said we could of put the diesel in the can then in the gas tank. The diagnosis cost $160. They told us that there was diesel in the tank, the diesel didn't harm anything, they then put in 24 gallons gas and gave us the truck back. Didn't do much for $160, I feel like I got screwed by them, $160 for them to tell me what everyone else told me for free? Thanks guys. What do you think?
    Let it go and chalk it up to experience. It's not a pleasant thing to do, but next time I bet you'll sniff of it before you put it in the tank. If you do try to get the woman to step up and pay for the "damage" you'll most likely have much more than $160 in attorneys fees.
    I've already talked to the lawyer, so its whatever he wants to do. Only reason I'm using a lawyer for $160 is that the lawyer is free, local university provides free lawyers to students. Thanks
    First, you don't pay attention and you run out of gas. Second, someone hands you an can of something, they say they think its gas, and you put it in your truck with out looking. Third you pay someone $160 to fill up your tank. And this is all someone else's fault. Get a good job, I think this comedy is going to be running another 50 years or more.
    Take them and your $160 repair receipt to small claims court and see what happens.
    Uh-uh, Opera, this is totally not his fault. Why do I think so? Because the accident was preventable by a person other than himself. This is not the same as running out of gas, which is his fault. It's no different than a pharmacist putting the wrong pill in the box. Her negligence or somebody's. If I was working at a gas station and handed you a big can that says GASOLINE in it, you are going to dump it in your tank without tasting it, I'm sure :)
    I was one of the first persons to respond with help and say it wasn't a big deal. We all make mistakes and we should try to help each other out if we can. I know when I was young, I had a tendency to blame others for my mistakes. Think long enough and you can always come up with reasons it is someone else's problem. We have gotten just one side of the issue here and my experience tells me it is very colored. He stated that he poured some of the fuel in the truck before he realized it was diesel. I contend that whatever it was that made him know this, could have been used at the gas station to determine the contents. I can almost guarantee that the container didn't say "GAS" on the side. The container could also have been half filled with water that was drained out of some vehicle. You have to take responsibility for your actions. The only bad mistakes are ones that you don't learn from. It is so hard for some people to say, I made a mistake. This is a good lesson - Always consider the source.
    This is just not a big deal. He needs to learn to take his lumps and move on. You shouldn't call a lawyer for everything. Take some responsibility.
    Well, the way I heard him tell it, she handed him a gas can and said something like, here, use this. I was basing my comments directly upon the assumption that he was handed a can marked "gasoline" in exchange for a $20 bill.
    I also don't like people who blame everybody else for life's little knocks. Bugs me, too. But this doesn't fit that category, in my opinion, because it appears that he was mislead by negligence.
    You'd figure somebody working at a gas station handing you a can of gas, well, then it probably has gas in it. In law I guess this falls under the "reasonable man" idea.
    I think there's a difference between someone claiming "this car gets 32 miles per gallon" and someone who says "this can marked gas has gas in it".
    How about "oh, yeah, that fire extinguisher is full charged, you can count on it" and your car catches fire and Cool Whip comes out? I think you'd have a case.
    and get a different image. This could have been almost the same story and I would have totally agreed with you. I read it and came back again before posting. This story just didn't fit together well. My gut feeling was that there was a lot being left out. Cases like this can often hinge on a couple of words. I think he was sold a can and the cashier thought it might have gas in it. Steep price! I once bought 4 quarts of oil for $45. Do what you gota do. It has been said that if they came out with the internal combustion engine today, that gas would be considered too dangerous to sell to the public. But, we have grown up with it and the courts probably consider the smell of gasoline to be common knowledge. Something that comes out of a back room is not exactly a dispensed product and a cashier may not be considered knowledgeable. You would certainly examine closely any pills I gave you out of my desk drawer. He had the opportunity to examine the contents before any "damage was done. In cases like this, the courts often assess a shared liability and use what would be actual damages. If I play Perry Mason, $160 minus $50 cost to have someone bring him gas -$32 for 24 gallons of gas and 25% station responsibility, he gets about $18.
    I watch a TV court program once in a while. Did take two courses in business law. Most of what I remember is that the test cases were almost opposite of what you thought was just. I am a technical consultant for a lawyer and get about two calls a week (which means nothing). We do talk about interesting aspects of the law now and then. Can never get a straight answer out of him. He says going into court is always a crap shoot and "How much justice can they afford?"
    Mostly, I can still remember what it was like to be young. Impulsive, impatient, far too trusting, with periods of impaired judgment, and an undying belief that someone else would make it all better. This is the first time most of us sort out life on our own. Some of the things I did defy explanation. I just think the real story, if you could ever get it, would be quite interesting. He could always get me as the judge. Remember, you never learn anything from people who agree with you. Being right isn't enough if you are dead right. I hope our young women readers closely assess the source of liquids that are given to them.
    Well, sure, if the story changed perhaps my attitude would. I'm taking it on face value at the moment, sort of saying "IF what you say is true, go to small claims with it". The $20 is for the deposit on the can, a common charge.
    If this happened to me, as stated, I'd go to court right away. This is about the most careless thing I ever heard, giving people diesel fuel in a can marked "gas". I hope they don't sell propane at that station or live ammo with a butt hanging out their mouth.
