if your steering wheel vibrates from left to right motion - most likely, your wheels are not balanced properly.
if your steering wheel vibrates in a up and down motion - you probably have a wheel alignment problem. this will also cause your car to drift to the right or left.
from your description, it sounds more like a wheel balance problem. if the problem doesnt exist at low speeds and only appear at higher speed - balancing problem.
if not balancing or alignment problem, check the rim if it is damaged in anyway. last thing to check would be steering rack.
That specific wheel has a problem. It is loosing pressure by around 2-3 psi every week. It could be that I overlooked and had low pressure for a while and that caused the problem. The dealer recommends changing all tires, which is the original Goodyear that came with the car. I have 27K miles on them so far.
I am going to do just that. My concern is that I have a damaged rim and that one of the new tires will be loosing pressure too. The car is still on warranty. Does anyone know if fixing this could be covered? I don't remember hitting a curb or anything that would damage the wheel. It seems that I have the problem since the day one, I just wasn't paying much attention.
I just wrote Toyota. and I got a call from the customer service of the dealership. They said paint chips was not under warranty and they would be glad to give me a bottle of touch up paint. YOu might as well call my Car CHIP.
All I want them to do is try to discover why the paint is chipping so easily. TIRED OF hearing cause is PEBBLES !!!!!!
OH I get only 24-25 mph in town driving.
Also i have discoloration spots on my sills and one door panel. One body shop appiled some kind of pressure to get rid of them However, they came back. ONe sill was badly warped. Another Toyota dealer is replacing that. I have tosee what they will do about the resot of the spots.
My car is a Corollo LE also. What color is your car? My son and son in law talked me into getting a Corolla. I wished I never did. If my car continues to chip like it does ,what will it look like in years to come? The service departments of the Toyotas are very hard to get in contact with either by phone or e-mail. I wanted to talk with the service manager or assistent and as of yet have not recieved a phone call or e-mail answer.
I get tired of calling and leaving my phone number.
I am glad you have not had any problems but I will not reccommend anyone buying a Toyota because of my problems.
paint dont chip unless u got fine dirt, rocks, pebbles, etc. hitting your car.
in my old 1990 corolla, i used to see paint chip on the passenger side doors only and it happens on summer time only! i couldnt figure what the hell is going on. finally, i had the answer! my wife drives the car to work, parks it on the street. everytime the city worker mows the lawn on the sidewalk, rocks starts flying into my car and everytime she goes home, i'd discover a new ding or paint chip!
got some chips on the hood as well. everytime i go on the highway, i get a chip too!
What I would like is everyone with the problem to file a complaint with the Toyota corporation. I already filed a complaint by e-mail .
Has anyone solved their chipping problem with the dealer or Toyota corporation?
One or two chips I could live with but when my chips add up to the grand total of 12 or more,I say that is not normal.
take it to the dealer. Took it to the dealer and was told that it was glycerin that they spray on the engine when it
was new???? Ive been checking the oil before and there was no sign on losing oil(no puddles dipstick looks good)
The dealer did the oil change and said everything was okay(no oil leak) should i be worried????
The Toyota folks are correct. It is an undercoat they spray on the underside of the engine. It looks and feels like a black thick heavy grease.
I would not take my vehicle to a shop that can't tell the difference between leaking oil and an undercoating.
iontrap,
The drain line won't be on the compressor, it's on the fire-wall near the passenger side. Look from below by the steering rack and you will see a small rubber hose sticking out of the fire-wall. This is were the moisture from inside the vehicle drains out.
Is it normal for CE auto to do so (its only 3 speed). I saw a similar post but that guy had a 3 year old car and 50,000 miles....
when u say noise, are you referring to wind noise, engine noise, etc.? with a 3 speed going 70MPH (roughly 115KPH), you would have some wind noise or buzzing. the engine would be somewhat loud at this speed as well.
toyota cars are quiet compared to other cars! corolla's are quiet but not as quiet as a camry or avalon or sienna. if you want a super quiet car, try buying a Lexus LS400 by toyota!
i never will step foot in valvoline again with my car
new battery the trouble went a way for good.
I suggest you replace with new battery.
jsleesi
Seattle
I had a a left front tire damaged the other day which got a hole in the sideawall while driving on the freeway . Got it replaced from Firestone (all tires are same brand).
When the tire was flat it had become very hot.
Now the new tire story.
A week after getting the tire replaced I felt little low pressure in the tire. Checked it. It had lost 2psi in a week. Filled air in in the morning.
Came back from work in the evening, after a drive of 40 odd miles, from Los Angeles to Orange county (relatively empty freeway at 65mph). Touch the bolts on the front 2 tires. They are HOT, the tires are little warm. The bolts on the rear tires are cold (its night time, so thats ok)!!!.
Check pressure again. The left tire had lost 2psi since morning and right one had lost 1 psi.
Whats the problem here? Could someone please tell me.
I dont want any of my tires to be gone again.
strange it may sound to you but i believe its normal.
the air in your tire expands/contracts. if the temp. is cold (early in the morning), you will find that your pressure is a few psi lower but when u start driving around and test it again, you will see that your psi have gone up. this is normal. when u check your pressure and it's low in the morning and u fill up with air - drive around for a few mins. and check again - you will find that your pressure is now too high!
as for "hot wheels/bolts/nuts", it could be normal, could be abnormal! if your brakes are overheating, you will smell something and your wheels will become very hot! this normally happens if you "ride" on your brakes. your wheels/nuts/bolts do get hot when you drive around - i suspect what you are describing is also normal. if in doubt, ask a mechanic to check it.
One other thing.
If i try pushing the car over 73 mph the engine makes a knocking sound.
I drove a friends corolla and it was fine. He drove mine and did hear a knocking sound at 75mph and above though the acceleration was normal.
Since i dont have an RPM meter i dont know if the engine is going into the RED Line zone of high revs.
Otherwise the engine is very quiet below 65 mph and slight sound can be heard over 70 but approaching 75 it starts to moan like knocking.
My friends car has a constant noise between 60 to 80 mph
When i travel Interstate its difficult to drive at 75 because the noise from the engine scares me off. Its not road or tire noise. Its like something is about to break, kind of noise.
I went to the dealer and they simply put no noise detected over 65 in the comments, though i had told them it was 75.
I appreciate any responses.
I have a 2002 Corolla CE auto. It does not have an overdrive switch, though that portion seems to be covered by a plastic patch.
A friend of mine rented a Corolla CE 2002 from Hertz and that car had an overdrive switch.
Could someobody tell me why is that some CE cars have overdrive and some dont?
I've been dissatisfied with the brightness of my headlights lately, so I bought some replacements. Getting to the bulbs is proving to be a bit of a problem, though. I can't find any way to get the front cover off, and I certainly can't get my hand behind it to pull the bulb out. Can someone post a process or a link to a process for replacing the headlights? Thanks!
Are there any other 2002 Corolla owners who have this problem? What has the dealer done for you? If you have have this problem with your 2002 Corolla log on to www.nhtsa.gov and let them know of the defect.
Some reason or another when I pulled hood release from inside, it is not releasing the hood.
I can not find any place in front to release the
hood. I called dealer near by, told me to bring in for repair, no other way I can open the hood
by manual release.
jsleesi
The engine noise becomes very loud over 70mph. It is not road/wind noise, as i have tested it in various situations. Showed it to dealer few times but they say its the 3-speed automatic causing the engine to rev high.
Using 89 octane gas helped, the engine revvs smoothly and gives a bit more power now. Noise is little lower, but not gone completely. Also, i try to use only Texaco gas.
-acd
OEM size in the manual is 175/65R14 OR 185/65R14.
Have to buy new tires, not sure if i should go for the 185 size this time. Any benefits/disadvantages???
-acd
Do the high revs damage the engine? Hondas are high rev engines by design. Have not heard the same for the Corolla.
Does it also mean that Corolla CE 3 -speed auto should not be pushed over 70mph? If so how do you travel interstate where people zoom by on 80+ speeds?
Newer corollas have an overdrive gear, which helps.
Exceeding the rev limit definitely can damage the engine under most circumstances in different ways. Refer to older posts on that topic.
Older corollas did not have tachometer, so can't see how many rpm's the engine is running on at 70mph in 3rd gear.
-acd
I am thinking of buying GoodYear Acquatred 3. I put them on my 99 camry, and iam really happy with the ride comfort, performance, very low noise, and wet/dry/snow traction.
Iam not sure if my wheel rim (originally came with 175/65R14 tires on it) will support the 185/65R14 tires...
Any disadvantages in terms of handling (185 size)??
I need suggestion from you guys, on which Tire Make/Model should I choose. The size is 185/65R14.
All ideas are welcome.
Underside of car bone dry and It is not burning or leaking oil. Has anyone experienced this problem. Car has 55,000 miles never had a bit of trouble.. Could the last oil change shorted me on the amt of oil they put in. Someone told me that expect these engines to burn/loose oil after a certain number of miles. Any truth in this
fill up your oil and check every 2-3 days and go from there. if you use your car daily and it is burning oil, your oil level will go down within a week. you may not see any blue smoke from your tailpipe but it doesnt mean you're not burning oil. so fill it up and check every few days
the noise disappeared, but about 9000 miles later the noise is back and much louder and it seems to come back in damp,wet weather more so than dry,sunny days. The dealership refuses to do anything further unless they actually hear the noise again which unfortunately is not constant.
Chuck.
