-June 2024 Special Lease Deals-
Problem #2:
Recently, started getting a sound when the steering wheel is turned and the accelerator is applied. It sound goes off after I drive the car for sometime, or when I keep the a/c on for sometime. Can anyone let me know what this problem might be?
Unfortunately, while the repair might be something as simple as replacing a kickdown switch , it *could* require a transmission repair
One thing you could try before shelling out $$$ for a tranny repair is to replace the transmission fluid and filter, using at least one bottle of a transmission product made by Lucas(R) (I don't remember the exact name of the product, but I don't think they have more than one product for automatic transmissions). This stuff is significantly thicker than regular ATF, and can in *some* cases postpone the need for transmission repairs.
All that work and I tested the starter and it works. Is there any thing I could do to clean or freshen up the starter motor and brushes?
I tried cleaning an EGR valve once. It was a scheduled maintenance item on my old '85 Mustang.
I carefully removed this thing and disassembled it--guess what? It wasn't dirty.
Because of that experience, I would be inclined to replace the modulator first and wait to see if it solves the problem before doing the rest of the EGR work.
As far as the VSV valve goes, I'm not familiar with this component, but the usual rule is to replace failed components.
Just be sure to get a model-specific repair manual and read it *carefully* (as a rule, these manuals are not written very clearly). Try to make sure you can reach all the screws, nuts etc. you'll need to remove with your existing tools before starting the actual work--better to find out ahead of time that you'll need a wrench that's longer, skinnier, has a deeper offset and so on.
Also, try to get the parts locally, rather than over the internet. (Advance Auto Parts, AutoZone and Pep Boys are the big chains in my area). Very often the few bucks you save over the internet are eaten up by the shipping costs, and if the part turns out not to be the right one for your car it's much harder to return and get the right one.
P.S. As for problem #2--be sure and check your power steering fluid level!
Sounds like your heater is continuing to operate, even when the switch is turned off. :surprise:
Hopefully, the repair will be covered under warranty. :P
Steve
To remove starter: Remove air cleaner (4 clips) and hose (clamp) at carb. This provides access to upper starter bolt. There may be a wiring harness bracket in front of it; loosen and pull back to provide an additional inch of clearance. Bolt can be loosened with 14mm socket, universal, and 12" extension. All the rest is done underneath. Raise front end as needed. Remove cable nut (12mm) and connector (depress protrusion in plastic housing) from starter. Remove lower starter bolt with same tools as above. Remove starter through wheel well (pull back plastic shroud). NAPA rebuilt starter is $110. Good luck.
I wonder how often struts need to be relplaced. Did not get a quote yet as it was the end of the day and she said they would call today, but she said it is labor intensive and costly, so want to be sure it is time (I have about 86,000 miles on my car).
About the brake lights. She said it was not the fuse, so they would need to do an electrical system diagnostic. ARe there any other things I can check before (i.e. bulbs, wires, etc.)?
I just want to be sure I cover the bases and am not sold more than I need (or unnecessary diagnostics). I have been going to this mechanic for about a year and they seem pretty honest and resonable, but I am never completely confident when it comes to my car.
:confuse: :confuse: :confuse: :confuse:
My Toyota corolla has an annoying rattle coming from the right hand passenger side door when I drive. Any guesses? :mad:
*However,* I have found that if I need to accelerate hard at low RPMs, the engine vibrates quite noticeably.
This doesn't seem right for an engine with *variable valve timing,* but it occurred to me that Toyota may have done this deliberately, as a way of discouraging heavy-footed driving and maximizing fuel economy.
I am planning to take it in for warranty service
Thanks, Jerry.
With winter and cold weather coming, I'm worried. Does anyone know what this might be?
I know 0 about cars. They told me to replace the EGR valve, so I bought the part ($160--Sacramento, CA) and put it in. Required no special skill or tools, but check engine light came back on. Reading other postings, I should have tried cleaning my current valve before buying a new one, but at 178K mileage, I felt ok about just leaving the part in and not returning it. My husband got tired of waiting for me to find our manual and look at what my next step was and took the car to the dealer. They said it is the EGR module and want $222 to replace it. I can get the part for $70, so I am going to see if I can do it myself. I'll report back.
Sounds like you may have an ignition problem.
I've had similar symptoms on 2 different cars, and in both cases the problem turned out to be the ignition coil.
There is a bank of rotary valves near the intake valves in the head of the 5AF. They are operated by a vacuum diaphragm. There is no such thing on my 4AF. I want to use the carburetor from my old 4AF. What should I do with the rotary valves? What is their purpose, and how do they function?
AM
When we bought our '05 LE I thought the fake wood trim looked tacky, but my wife thought it looked great--no accounting for tastes (BTW, it has grown on me since then).
If you can find someone, you'll probably be saving quite a bit--my guess would be between $100-$200 for the parts.
I also found that my local library has service manuals available for checkout. They had quite a selection. Free is good!
I have the same problem with my '99. Are you saying the second bolt comes in from the backside, opposite the way the bottom bolt does?
Any other tips?
If I try to turn on my headlights with the switch, the dashboard lights come on, but the headlights do not; if they are on as DRLs, then they go off. If I shine a flashlight on the automatic light sensor, I can kill the dashboard lights and the headlights (DRLs) will come back on. (That might sound silly, but I thought I'd experiment.)
I figure I have a bad electrical relay somewhere, but I am not sure if I'm on the right track. (I've already checked the switch for continuity per a repair manaul I am reading, and that looks fine.) Does anyone have any suggestions? Thanks!
THANKS!!! :sick:
I have a 2000 Toyota Corolla VE with 57K. I was getting a little bit of noise from the engine and went to a Toyota dealer. They told me the engine oil was low and the engine may be burning oil. How can I be sure if the engine is burning oil or not? How expensive will it be to repair? The dealer suggested in case of this problem engine needs to be rebuilt and costs $3000-$40000.
I never heard of Purge Valve malfuntion. I'm wondering if all you need to do is just to replace the PVC valve. It's cheap and very easy to do. I have the same car as you with 93k on it and not a single problem. How about that for a car built in Fremont, Cal.
