If your noise fits the discription, then there is a good chance it's just the car cooling. And that's normal.
If you hear a knocking noise when driving, or with your engine on. Then I would say you need to take it to a mechanic for a check.
#0 of 0: (chipzz) Fri 21 Apr '00 (08:13 AM)
I'm getting a whine from the rear end of my '92
Corolla 4wd wagon I bought last yr. Toyota dealer
mech said probably differential, $200.just to
open it up to assess problem, then big bucks if
differential replacement. I noticed a slight whine
when I test drove, Toyota dealer mechs examined
and gave it A-1, AOK, "go ahead and buy it",seems they didn't test drive it, now I'm facing big bucks, cause I assumed the whine was normal for 4wd, but noise now seems louder and I want it fixed. Called junk yard for diff., they have the part for $300. (I hear new diff. can cost 1000+?Any advice, similar problem of this model/year?
Any suggestions for chipzz?
Pat
#0 of 0: 1988 Toyota Corolla Charge warning light problem (randell) Tue 25 Apr '00 (08:44 AM)
Hello --
My trusty 1988 Toyota corolla LE Sedan has just
started having a problem where the 'charge' and
'brake' warning lights are both staying on after
starting the car (they are next to each other in
the console display).
Anyway, I removed the instrument panel, did not
find any shorts or anything. The fuses called out
in the Toyota service repair manual look okay, as
well as the wiring...continuity checks okay. The
alternator appears to be charging fine, although
admittedly I have not checked everything as the
regulator is built into it.
The only thing that seems funny to me is that
according to the electrical diagrams, both the
'charge' warning light and the 'brake' warning
light are connected via diodes on the ground side
to the 'charge' 7.5 amp fuse (which is okay as
mentioned above). Removing this fuse does not
change the problem, although when I apply the
brake I hear a solenoid of some kind clicking in the engine compartment. I have not figured out which solenoid is the one making the noise, and this may be irrelevant, but it seems strange to me, as no solenoid noise is heard when the fuse is there.
Any ideas or pointers would be most appreciated.
Ken Randell
Any ideas about Ken's problem?
Pat
there 2 very small springs holding the c-ring of
the rear cup holder (one on each side) located in
the center console (2K Corolla CE). I noticed only one spring on the right side when it is pulled out (it does not pop it cleanly) or should
there only be one spring on the right side. I've
checked the shop manual but unfortunately, it does
not have a blow-up of the center console. Thanks
all for any replies back. I've addressed this earlier #448 in another townhall Toy topic. No answer to date.
I had an older model Corolla with a mechanical fuel pump that developed a slight hesitation when I accelerated, despite having tuned it to a gnat's whisker. One day it stopped on my wife, I towed it home, got a fuel pump in case I needed it, and started diagnosing the problem. Initially I removed the fuel line from the filter, filled it with fuel, and it started and ran fine until it burned the fuel out of the line. I knew it didn't have a firing problem, so I repeated the process, but while it was running reattached the fuel line to the fuel filter to see what would happen, and it continued to run. Test driving it, though, the engine just died. I went home, got the fuel pump, put it on, and that cured both the bogging and the intermittent running. In this case, I think I had a valve in the fuel pump that was leaking some and stuck intermittently. Replacing it solved both problems. This car had 100,000+ miles on it. Later I moved about 50 miles from my office and wanted to be certain I didn't break down going to and fro, and as a preventive measure changed the mechanical units out on vehicles once I got to 100,000 miles and had no further problems.
Now, however, the fuel pumps are electric, last far longer, and cost far more than the mechanical ones. I have never had a problem with an electric one, but they do fail. I have a '92 Tercel now that has 164,000 miles on it, and still has the original electric fuel pump in it. It is the first I have ever had with one, and I dropped by the Toyota place once I got my usual 100,000 miles on it thinking I would do the same preventive change, but the service manager said he had never had one go bad, and the parts man gave me a price of $160.00+ for it. The combination convinced me to leave it alone, and it is still going.
william_sommariva@ascap.com
Chris
I was wondering if anyone knew any good dealerships/repair shops in the Long Island Area around Commack that has reasonable prices.
Just got a quote for $170 for 15000 mile service. Want to take care of the car but it's hurting the wallet a little too much.
When you say that your car 'broke down again several days later', what exactly do you mean? Was the engine running, making noises, not running at all...??
I think that your mechanic may be taking you on an expensive ride. With the prices quoted by your mechanic, you are better off getting a used engine for your Corolla.
Kristina/co host Our Turn
Thanks for any info.
Mitch
Mitch
Any suggestions? Thanks.
I have 1999 Corolla LE with only 7500 miles on it.
1. I feel that the steering wheel is not aligned centrally, as when I move it fully, it does not move in a circular motion. It rather goes in slightly ecliptical shape.
2. Sometimes the rear right hand side door lock does not get unlocked, while getting in the car.
I have not yet shown this to the dealer and thought of taking your opinion before doing so.
#1. Steering wheel not centered.
This is the way the steering wheel was designed. It is not a defect, somebody thought it was a "feature". I agree, it is disconcerting, but they did it to try and fool the buying public that the car has a bigger interior than it actually has.
Bruce
Tim
I am the owner of 1999 Corolla LE with 17000 miles on it. From the last 2 fill ups, I found out that my car is giving me only 22 miles/gallon. I drive mostly in the city (silicon valley commute). Can anyone please tell me is it a serious problem or normal one ?
Senthil Kumar
The gas milage is couple of miles lower when I turn on the A/C alot. But it never dipped below 25 mpg city driving in the summer. In the winter, the mpg is lower, around 23 mpg city driving (I live in Michigan, we are talking about deep freez over here, so I can't complain).
I would check to see if the tire pressure is right. Make sure it's around 30-32 psi when cold (meaning you havne't driven the car for a in the last couple of hours).
Also, don't drive at high speed with the windows down, since it increase the drag very quickly. I hard at over 40 mph, driving with your windows down uses up more gas than turning the A/C on.
Also, if you drive with the car loaded, it will use more gas. lso, wouldn't hurt to switch to a different brand of gas, just to see if the low milage is with the gas or the car.
Also keep in my that the gas milage stated (28 mpg for city) is actually is a range. If you look at the sticker, it actually says between 23-31 mpg is normal (or something like that).
Anothe question, is the gas milage always 22 or did it only become that way recently? Anyway, good luck.
Thanks for the info.on the corolla mileage.
When you are stop at triffic light for a long time,
Shall I put the the gear (automatic) in neutural
or just put Drive gear and idle?
JS Lee from Federal Way Washington
It has 24K miles on it.
So far, so good. I do not hear my Corolla's engine at all.
Usually, you can hear such pinging/knocking noise, if your engine is overheated or heavily overloaded.
Good luck!
Sripal
Assuming, you're doing 12K/year, make a simple calculation. If you change oil every 3K, you do it 4 times a year. If you do it every 6K - 2 times a year. For 3 years you'll save 6 visits to a service station or $120 ($20 per change in MA).
So, what is cheaper: $120 of oil changes or $2K to rebuild your car's engine?
I have a brand new corolla LE bought 4 months ago
having run 6000 miles. Now i am feeling my car is
making noise and i can also feel the vibrations.
Can anyone please suggest what the problem may be?
the chipping of paint on her car.
Seems it takes very little to chip it.
Others have also asked about it.
Has anyone taken it to Toyota USA and gotten an answer?
If you have this problem please post it and give
us the date of Manuf. found on label on door post.
If this is truly a problem we should band togther
and seek and ans. Charlie
The date of manufacture is 04/99
techs. I trust to tell me things as they are, is
that the goverment has put there finger in the pie
and auto paint is now a water based paint and is
more likely to chip than the older oil based
paints.
I am now contacting paint manuf.and will post
what I find out.
Also told it is not only the Corolla that is doing it but all Toyota cars. I am going to start looking in parking lots to see if I can see more
chips than you might expect.
If you check the Toyota news group alt.autos.toyota you will find theses answers to
my post there.
Any more comments are welcome. Charlie
