Honda Odyssey vs Dodge/Chrysler minivans
1128129131133134
  • sebring95sebring95 Member Posts: 3,241
    Are you serious? Slalom tests are anything but real world.
    No, but they tell you a lot. Like, if you're loading the suspension quickly (like you would in an emergency lane change) the stability control equipped models have higher speeds. Higher speeds through a controlled lane change = safer vehicle when an emergency arises.
    I find that comment a little suspect as well. Every time I've been to a BMW event at one of our local tracks, EVERYBODY turns off their skid control systems so that they can improve the handling of their cars.
    Well, they're turning it off so they can drift through the turns, which can increase lap times. Not quite the same as technically making the car handle better, you're just exceeding the grip of the tires in lieu of using brake/throttle. The fact that you can't drift the car with stability turned on should tell you a lot.
    That said, when driving in slippery conditions with either of my "i" model BMWs I made damn sure the DSC was engaged (no surprise there). The counterpoint to those two cars is the minivan, a benign sled like handling FWD vehicle, complete with inherent understeer. Go into a corner too fast on one of these things, Odyssey, Caravan, Sienna, it makes no difference, stability control is only going to be able to do so much.
    Oh sure there's a limit, but stability does pickup on steering inputs vs speed/yaw/etc. and if you're asking for more than the vehicle can physically provide it's going to do everything possible (beyond what even an experienced driver) could do in a split second to correct. Maybe a complete knucklehead move can't be fixed by stability control, but can't make the outcome any worse.
  • hansiennahansienna Member Posts: 2,312
    My ideal minivan would have the Odyssey seating, separately controlled temperature of either Ody EX or GC SXT, overhead console of my 2002 T&C LX, NO power sliding doors, Odyssey dash with GC radio and stereo with more control knobs, Sienna transmission choice of D-4-3-2-L, spare tire location of Odyssey, 3.5L V6 of either the 2007 Ody or 2007 Sienna. :shades:
    Sounds like a winner. Let us know how the shopping progresses! As for me, my dad is smitten with the new Civic, and may be trading his 2005 Accord on a 2007 Civic; we're going test driving tomorrow night. He is excited about the design; not to mention 6 MPG better mileage and a much lower car payment!
    "No, but they tell you a lot. Like, if you're loading the suspension quickly (like you would in an emergency lane change) the stability control equipped models have higher speeds. Higher speeds through a controlled lane change = safer vehicle when an emergency arises."
    Sorry, not buying that argument, especially when we're discussing understeer prone FWD minivans. Please point me to a few back to back tests of a FWD vehicle (preferably a minivan) that was able to post better slalom times with a skid control system enabled.
    "Oh sure there's a limit, but stability does pickup on steering inputs vs speed/yaw/etc. and if you're asking for more than the vehicle can physically provide it's going to do everything possible (beyond what even an experienced driver) could do in a split second to correct. Maybe a complete knucklehead move can't be fixed by stability control, but can't make the outcome any worse."
    That's my point. Once you are into understeer on this type of vehicle there really isn't all that much that can be done from the perspective of a stability control system. If anything you are actually bolstering my argument.
    Best Regards,
    Shipo
  • aaron_taaron_t Member Posts: 301
    2012, but there is a a phase in period and soem automakers are trying to get 100% stability control before 20012.
    Shipo, the air susension is only availible with the $600 towing prep package on DCX vans, as you discovered.
    Understeer, oversteer, doesn't really matter. It's going to detect a steering motion that's not compatible with the direction/speed of the vehicle and brake accordingly. If the vehicle detects understeer, it applies the rear inside brakes which will assist the vehicle turn in the correct direction. Oversteer brakes the outside front wheel. That's pretty simple driver dynamics stuff there, except YOU can't control the brakes on one wheel. Of course as you mentioned, if you're plowing into a turn well beyond reason you're not going to recover. But that's pure stupidity which nothing can help ;)
    I can't find the article/story on the slalom test. I believe they were late-model Grand Prix's they were testing and the most obvious difference was when they wet the track. Either way, it's pretty simple that with stability control you can run beyond the capabilities of a normal vehicle so there's no reason you couldn't go quicker through a slalom/emergency maneuver. The non-stability controlled vehicle will spin-out more easily which ends the test. If you're racing on a track, you want the car to work completely differently and disabling stability makes sense.
    "If the vehicle detects understeer, it applies the rear inside brakes which will assist the vehicle turn in the correct direction."
    Is this your rationalization of what you think is going on or do you really know for a fact that braking the inside rear wheel (the wheel that will have the least amount of absolute traction in this scenario) will correct for oversteer? If this is scientific fact, please refer me to your source. Until then I maintain that stability control on a FWD sled like a minivan is a highly questionable option.
    Best Regards,
    Shipo
    Do you think your dad will EVER save much money on gasoline with 6 MPG better on the 2007 Civic vs 2005 Accord?
    Funny how styling affects us. I DON'T like the Civic design where the windshield is longer than the hood nor do I like the Chrysler 300 where the roof looks like an elephant sat on it and made the side windows too short.
    IF I had to sit in any seat other than the driver's seat for any great distance, the Odyssey would be the BEST vehicle for me. Since I do most of the driving, the compass/outside temperature and trip computer information is very important (but probably a distraction) and the driver's seat of our 2006 Sienna LE is as comfortable as any driver's seat.
    I got a back ache while riding in the 2nd row seat of the Sienna for a couple of hours last August while our daughter drove. The 2002 T&C LX 2nd row seats never caused the bach ache for a longer period of time.
    Test drives are never long enough to find the dislikes of any vehicle. I do NOT like the shiny circles around the speedometer, tachometer, etc. in the Sienna instrument cluster and I HATE the shiny surfaces in the middle of the Sienna dash. On the other hand, I never did like the white faced instruments of the 02 T&C LX.
  • cableguy06cableguy06 Member Posts: 299
    Complete ground-up design. Has very little similarities with the older generation that ended with the 2005 model year change.
    You can google stability control and get as much information and technical specs as you want. The way I explained it is how (in a very basic situation such as understeer/oversteer) stability will correct actions. Keep in mind stability works BEFORE you go clear into full-blown understeer, so it's a HUGE advantage for a FWD sled like a minivan. Now if you want to throw in an emergency lane change with two wheels ending up in loose gravel on the berm....then it's a little more challenging. Even with my experience driving race cars, I won't buy a truck/suv/minivan without stability these days. I won't say that about a car, but if it's an option I'll take it.
    **Skip this post unless you are Hansienna; this is off topic**
    Well, considering he drives about 30-35k miles a year (he bought his current 05 Accord Dec of 2004 and has 68,000 miles on it now) , 6 MPG over 2 years will add up to be as important as the drop in car payment (going down about $50 a month).
    The Civic sedan isn't my favorite style, but I do love the coupe's look.
    If dad drives 3,000 miles a month, and gets approx. the city estimate (as he does now in the Accord - 24 MPG) he will use 100 gallons of gas, vs. 125 gallons in the Accord. With summer prices around $2.90 and prices in winter hovering at $2.15 here, we'll say $2.50 a gallon for average. 25 gallons a month at $2.50 a gallon is $62.50 a month. (Say $60 for numbers' sake). $60 a month is $720 a year; or you could say the gas savings is going to pay our cell-phone bill from now on. With the $50 payment drop, and the $60 gas drop, he's going to be shelling out over $100 less per month on driving.
    The real question is now how his insurance rates will change.
    This is off topic, but we can carry on in the Civic forum if ya want. Sorry to everyone else who can care less about the Civic. I'm through :)
    Hansienna's magic minivan! Especially the part about putting a DC stereo in an Ody. Honda does many things right. Sound is not one of them.
  • mrblonde49mrblonde49 Member Posts: 626
    Hansienna's magic minivan! Especially the part about putting a DC stereo in an Ody. Honda does many things right. Sound is not one of them. "
    My brother just got an Entourage Limited with the Entertainment package (13 speaker Infinity). Best in-car sound I've personally heard without going aftermarket.
    I like the van a lot, waiting to see if they have some better incentives coming - was there Saturday and it's not worth it for me to make the switch yet
    That would figure. Hyundai's trying to grab me. Must resist....... at least for now..... Hey, wait! I'd be the one driving it..... maybe not....
  • explorerx4explorerx4 Member Posts: 20,957
    there have been some spirited discussion here.
    link title
    hopefully, not old news. :P
    Nice link. I test drove my 2006 Sienna LE on the EXACT same course as I drove my son's 2001 Odyssey EX and the Odyssey showed 6.15 % MORE distance than the Sienna did. :shades:
    When I checked my Volkswagen MANY years ago, the odometer read 4 % more miles driven than the actual miles. The speedometer was also overly optimistic.
    These built in errors caused me to think the Volkswagen was getting better gas mileage than it actually did and made me wonder why people were passing me all the time.
    We had a Chrysler Pacifica rental car that registered 85 that my father drove, while I did over 90 in the Odyssey trying to keep up (this was back in 2004, right after Hurricane Ivan - we had two vehicles full of stuff). Wonder which was more accurate?
    Probably the Pacifica.
    My son's Odyssey showed 2.6 % more distance than my 2002 T&C LX when driven on the same course.
    I regret NOT driving the 01 Ody, 02 T&C, and 06 Sienna on the same course instead of comparing Ody with T&C and then later comparing Sienna with the Ody.
    Interestingly, the T&C Trip Computer was closer to actual mileage when computing by dividing long trip miles driven by gasoline consumed than is the Sienna. T&C was about 1 % overly optimistic while the Sienna is just over 3 % higher than actual gas mileage.
    I see where right now it's a measly $500 rebate. I'll wait, thanks.
    Have DC minivan owners stopped reading in here or have Odyssey owners fallen asleep?
    :) I dunno! You can bet it will pick back up again once DCX revives its now-dated but value-priced entry into the minivan field with a competitive engine and nicer interior. Then things will start shakin' again!
  • 1997montez341997montez34 Member Posts: 202
    I have been too busy using my Stow 'N Go seats to move people and stuff. Also, I have been enjoying my $400 power liftgate. See you all for '08! :)
    That's what we like to hear, now! USE the things!
  • rorrrorr Member Posts: 3,630
    "Have DC minivan owners stopped reading in here or have Odyssey owners fallen asleep?"
    Yes.
    Is there any ground we HAVEN'T already covered on these two vans? I'd love to know what it is. Otherwise, I'm going back to sleep...... ;)
    THANKS for responding to the wake-up call. :shades:
    I would buy an Odyssey IF the dealers were not overly arrogant AND the Odyssey LX were offered with separately controlled temperature for driver and front passenger AND a complete overhead console with compass/outside temp/trip computer.
    I do NOT want to pay extra to get power sliding doors on each side and cast wheels.
    I would like to see DC make a less CHEAP interior, offer the most powerful engine on all models, and have the complete overhead console optional on ALL models.
    I think Honda is wise to NOT offer Factory Discounts/Rebates/Incentives like DC and Toyota offer. It is easier to know I did not pay too much when a company is consistent in their marketing schemes. :blush:
  • dennisctcdennisctc Member Posts: 1,168
  • blackexv6blackexv6 Member Posts: 503
    I'm quite impressed. I think (hope) within the next 10-15 years, the American car manufacturers will once again rule. After owning 3 Hondas with mechanical problems (transmission failures, droning defects, & vibration defects), I am looking for another manufacturer. Toyota has some serious quality control issues to contend with + transmssion problems in their Lexus, Camry, & Avalons.
    Honda & Toyota have become complacent since their former reliability ratings are carrying sales.
    WOOOOOW, went to an OLD post! Thanks for the links. I've since seen them, but I appreciate the link and the thought nonetheless.
    Is it just me, or does the 3rd row have a nasty angle to it? Like your knees would be up around your ears.
  • marig0107marig0107 Member Posts: 92
    I won't go into all the repair jargon because I am just not that well versed. But I will say thank heavens we got such a good deal on our 98 Caravan because all the savings went into the repairs throughout the years. And almost everyone I have known that has had caravans, mostly 98's and newer, have had numerous issues with reliability.
    I would never ever buy another chrysler product nor could I ever recommend it to anyone. My van still runs, mostly because all it's parts are now new....rofl
    But it is now used by my husband to get to work. We could not continue to use it as a family car. Too unreliable, thus unsafe. We went on ahead and bought a honda crv for the family, rather than all sitting in a roomy, packed with features caravan. What does that tell you? At least now, family and I drive on in peace!
    When we can save up some money, caravan goes and husband can by a reliable small car for himsefl.
  • jchan2jchan2 Member Posts: 4,956
    that there are varying levels of reliability even within a single model. Someone else's Odyssey may be more reliable than mine, or someone else's may be worse.
    I can agree with that. I can only go by my experience and my friends that have had them. After 9 years, I FINALLY have a functioning a/c. The belts have all been replaced and have had major engine work. After that, there was the major brakework done.
    My girlfriend swore her van was awesome, had to be only mine, well guess who was picking her up off the highway cause her transmission blew? Yep, me in my clunker caravan.
    Now mine leaks power steering fluid. Or rather, my husbands van.
    So I am glad that you are enjoying your van. No need to get snippy on me. You lucked out, many have not. Funny how we got the caravan because it was top rated in Consumer Reports and then within another year or two, alot of their reviews on the caravan were lousy.
    MOST of my friends have had NO problems with their Caravan/Voyager or Town & Country. Many are repeat buyers such as my sister who now drives a 2005 GC SE because her 1986 Caravan had NO problems when she sold it to a neighbor at 170,000 miles....or Kurt who now drives a 2006 GC SXT after owning a 2000 GC LE, 1996 Plymouth Grand Voyager, and a 1988 GC.
    Meanwhile, enjoy your MUCH smaller CR-V. ;)
    I bet they are. And the extra 5 MPG that comes with it!
    lol....did I miss something here! I thought this board was dead!
    Thanx I am super loving my much smaller CRV with way more cargo room and one less kid in the car to shuttle around...woohooo, teen driver, right ;)
    BTW, dh is driving around that caravan. Let's see last year was the a/c finally got fixed after the third year of repairs, last year was the brake work repair and now this year is the power steering. But I told dh he is not allowed another repair. So hopefully we'll be able to afford a used car.
    And teen driver will be driving the 93 dodge shadow! How's that for keeping a car around??? :D
    The only thing that would worry me about that would be lack of safety features. I'd at least want a car with dual airbags for a new driver.
  • bhs1975bhs1975 Member Posts: 2
    A (good) dilemma:
    Have verbally negotiated a good deal on a new Honda Odyssey, however have just recently been offered a family van (the Chrysler) for $10,000 less. Seems like a no-brainer to go the cheaper route - the Chrysler only has 27k miles on it. But I'm still a little leary about the Chrysler product's reliability over the long haul. If you were in a similar situation, would you go the new van route or save the cash and go with the 3yr old model?
    I would think there should be a larger difference than just $10,000 IMHO. Price a new T&C similar to the Odyssey and see how that comes out. There was about a $6,000 difference BRAND NEW when I bought my Odyssey (price wasn't my main sticking point.....). And you're comparing vehicles with 3-4 years between them.
    The deal we have worked out with Honda is about $1000 under invoice. The KBB indicates the Chrysler would have stickered about $6k more, yes....yet I think this Chrysler held some value from the low miles on it. After speaking with the seller, the difference I calculate is now $13,000, and if you compared to Honda's sticker, it would be about $16,000.
    I'm just now trying to do analysis on cost of ownership on this used car to determine whether the current savings would dwindle next to zero over the next 5 years. Resale value after 5 years could make up a huge difference in the numbers, but I'm not sure if it would be that significant.
    Well, as for longevity of the T&C goes, our two Dodge Grand Caravans (twins of the T&C) are fast approaching a combined quarter of a million miles, and they've been virtually bullet proof. In addition to regular maintenance, the 1998 has needed a starter, a door switch, a transmission and a vacuum battery tray over 145,000 miles. Not too shabby. Our 2003 has been similarly endowed with reliability in that it has required an ABS sensor, one set of front sway bar bushings and a power door motor over the course of 95,000 miles.
    Combined the above repairs total to about thirty-four hundred dollars (and change), which given the mileage is awfully darned inexpensive. ;-)
    Best Regards,
    Shipo
    I would get the 07 Odyssey.
    The lack of Stow N Go in the 04 is a big negative for me, and the fold flat third row comes in handy more times than you think...
    I think with just the one airbag, this is a good starter car. It will be a long while before he's driving anyone around, particularly other teens.
    It is certainly a whole lot safer and better than any car I started out with.
    That said, I am prone to the paranoid and now you have started up my paranoid zone. :cry:
    Thank God for the school buses, that he will use daily for school! That limits car time to work and home only....
    A (good) dilemma:
    I'd say do your homework. There are a few around here who swear by their dodge products and have themselves experienced good things with them, along with friends.
    We've had the whole other spectrum with dodge. had a terrific car with them so we went with the caravan when van shopping. CR had them rated top of the line and we thought, why not. Well, the next year, the reliability rating in CR plummeted. We had awful experiences from the first year of owning it.
    So check the newer issues of CR, check online reviews here for that model caravan that you are looking for. See if it is acceptable to you. Sometimes price is not the first consideration in car buying. You may end up with the more expensive deal when trying to save a few dollars.
    Good luck and most of all, make it a fun car buying experience
    Didn't intend to make you paranoid. I didn't realize the Shadow had even one airbag (and it will be the one the most important person to you will use!).
    I started in a 1996 Accord. Dual Airbags are all it has (I still drive it regularly!). No ABS has been something that's scared me only a handful of times though, and I'm turning 20 next month (got the car 50,000 miles ago in August of 2002). I'm now at 174k miles, and haven't been injured in either of my two wrecks in that car (wrecks that combined cost over $4,000 to repair - NOT MY FAULT, but still!).
    Don't be paranoid. In a Shadow, and in the city, he won't be going too fast to do anyone too much harm, much less himself since he has an airbag.
  • bobber1bobber1 Member Posts: 217
    No need to calculate anything for me. If you're saving $13,000 go that route. Your family member has already taken the resale hit and that shouldn't even factor into the equation with the savings you're looking at.
    Honda's are nice(I own one), but the Chrysler products are decent as well. Parts will be a lot cheaper to come buy than the import products and you'll be able to afford to stick some money into it with the savings you're looking at. ;)
  • masterpaul1masterpaul1 Member Posts: 421
    If it checks out mechanically, I'd go with the 04 T&C. You might even be able to get an extended warrenty for peace of mind for over $1,000. We bought a used 01 DGC EX back in Sep. 03 with 37K on it. (This was a new year module.) We bought the extended bumper to bumper warrenty for three more years. (We saved $10,000 buying used.) We now have over 88K and for the most part has been very reliable. We have never been stranded or needed a tow. Under warrenty we had both front window regulators and motors changed. Front suspension sway bar, bushings and links replaced. Cargo latch changed and computer upgraded software added. Other things out of warrenty that needed to be replaced was one of the thermostate housing bolts broke off while still inside the engine. (Not sure what caused this. I backed out the bolt myself and replaced the thermostate and bolt. Only cost about $20.00) Just last week, I broke the emergency brake padle, while trying to apply it. (I will have to take it in for that to be fixed.) We will need to have the water pump replaced in the future from a very small leak that was found when the cooling system was flushed. (This I'm going to keep an eye on, because I haven't seen any leaks on the ground, before or after the flush.) The links and bushings are going to need to be replaced again in which I'm going to try and do it myself. (This is the only thing that I don't see as reliable only lasting a few years. But, it is farley easy to fix according to some here on Edmunds.) All electronics, air/heat and mechanical are working as they should. Still get about 16 mpg city and 24 mpg highway. :shades:
    Maybe I've been spoiled my my service from my 174k mile '96 Accord, but you've had a lot more things fixed from 37k to 88k miles than I have from 125k to 174k miles in my car. It doesn't sound particularly "high-quality" with all of those repairs... multiple suspension parts needing replaced more than once over 50k miles, power windows, thermostat, water pump, breaking a pedal(!)?
    It's that sort of stuff that will nickel and dime a customer right into the arms of another make of car. Sure, I'm sure any manufacturer has its share of the same, but your vehicle seems particularly full of little issues to have so few miles.
    lol...doesn't take much to make me paranoid.
    Yep, he does have the airbag. I have never had ABS up until now. It was never a big thing because being a NYC driver, I really pump brakes. I have beeen making an effort with my new car NOT to do that, but darn if it ain't hard ;)
    thanx for the kind words. I do worry about him. People here drive awful...I have seen worse driving habits than any big city up north in this little town!
    The swaybar bushings on Gen4 vans are problematic, period, full stop, the end. Some also claim that the swaybar ends are troublesome as well although it is unclear whether that is actually the case or whether the links are being lumped in with the noise generated by worn bushings.
    In our case, our 2003 developed the infamous "clunk" somewhere in the thirty to forty thousand mile range and we simply ignored it until about the 85,000 mile mark when it finally got annoying enough to do something about. I am an analyst by trade and as such am a fan of changing one thing at a time instead of throwing a whole bunch of parts at a problem hoping to solve it via brute force. So, ignoring the dire warnings of many experienced folks, I simply changed the bushings (I used the NAPA "Blue" bushings that cost about $11.00) and NOT the links.
    When I admitted what I had done I was told that I'd need to go back in and replace the links as well and that I was a fool for not doing them all at the same time. Well, I'm here to say that nearly 10,000 miles later and our 2003 is still as quiet as it was the day it rolled out of the showroom. ;-)
    In defence of the "You must change the links" folks, I've heard anecdotal reports that suggest that Chrysler used two different end link types, one primarily plastic and one primarily metal. If that is the case, then I can certainly understand why some folks are convinced that the links are needing replacement at the same time as the bushings.
    Best Regards,
    Shipo
