Yes setting injection pump timing does require some expertise. I guess if you had the 3-volume workshop manuals for the 300D you could take a crack at it.
I still think you need to do a compression test, otherwise you are just guessing here.
if the compression is no good, then all your efforts are in vain.
If compression is good, I'd have the pump professionally set and then replace the injectors. Are you quite sure the valve adjustment is correct?
Did you get a chance in inspect the camshaft lobes for severe wear?
This might help you:
http://www.goodvibesautos.com/Mercedes-Diesel-Engines.html
Here are more ideas you can try out:
http://www.tdiclub.com/articles/Tune-Up.html
The big giveaway that the problem is the master valve would be that the suction capacity of the car is directly related to the position of the driver lock.
Also, my understanding is that the antenna, sunroof and back seat buttons don't have lights in them. Only the rear defront, when on, lights up. As for the heater controls, are they actually heater controls or the climate controls?
-Ryan
Worst case you'd have to take out the ash tray, metal ash tray surround, radio, (in that order) then the veneer and climate control. When I did mine, I just took everything out and reached up in behind to change the bulbs, but it's a '77, and as you've stated their's minor differences.
Hope it helps at all
I believe your car carries a steering shock--this is not expensive and you can replace it yourself. This might help your situation, if you feel the shimmy is preceeded by a bump in the road.
Another way would be to pull the fuse for the circuit and use an ohmeter on the load side of the circuit to find which branch has the low resistance.
What two fuses seem to be the one's that have an effect?
good luck.
I was cruising down the freeway at 75 mph yesterday--I typically do not drive that fast('82 300SD)-- and lost all power. Engine works fine. Transmission does nothing, not even secure the vehicle in Park. If I put it in Drive and rev the engine, I hear a chain-like dragging noise. Vehicle will roll backward or forward in any gear (actually, I've not tried 2nd or 3rd). If it was in Drive and then revved up, it is hard to go back through Reverse until the rpms slow down.
I have the receipt from previous owner showing a factory rebuilt tranny ~45k ago. Fluid on stick is full and appears OK--changed 10k ago.
Recommendations? I found a junk yard with a clean looking used tranny for $750 with a 6 month warranty. To swap it out, do I really have to pull the engine? My manual on CD has no transmission chapter, where can I get information on that? Is there anything else that you suggest I check before I pull out the tranny? I've not had any other problems with the transmission at all and the rest of the car is in pretty good shape. I haven't pulled the pan yet. If I do and it isn't full of metal, what could that mean?
Thanks for the advice.
If the driveshaft/halfshafts are all intact, check for a busted differential (jack up rear of car, spin wheels).
If that's okay, you musta lunched the tranny real good.
Seems odd you'd lose park though..you gotta look under there.
I've never seen a driveline snap before. Is that common?
You're lucky, I've also heard of the driveshaft breaking in the front, falling down, and jamming into a highway rut or pothole at 60 mph. You can guess what happens next.
So, good guess huh?
No reason the diff should be damaged. Of course, you WILL replace all the u-joints and the center support I trust.
Now you know what that clicking/squeaking noise you heard lately, was.
So back to the questions. The transmission does appear to go in and out of Drive and Reverse with appropriate outputs now that I've been under there and moved the driveshaft aside to see it. However, I could not get the car into Park. I unhooked the shift linkage and was able to maneuver it manually. The shaft is bent--should it be straight? I would believe that it got hit when the driveshaft snapped on the freeway. Is that the sort of thing I should try to bend and adjust, or buy a new one?
Next: I guess I should avoid a wrecking yard driveline for the same reasons this one went. I haven't removed the exhaust cover yet, but I assume there is a U-joint under there. Do I replace the shaft just to the U-joint, or all the way back to the differential because they're balanced together?
There are places that will balance both half-shaft, as they are assembled. That's a sure fire way to get it right.
I really can't say about the park detent. Are you saying you can get into park after removing the shift linkage?
I think I would buy an entire driveshaft from the wrecker and then replace all the u-joints in it. Make sure they DON'T separate the two parts of the shaft until you've marked them with paint!!!
And I will go driveline shopping as soon as I get this one out. Thanks for all the advice. I am so happy that I don't have a 'lunched' tranny.
What should that output shaft look like, and is mine still OK? I took a picture of it, which I can email if someone wants to look at it. As I mentioned before, my manual on CD has no transmission information available. If the shaft is not OK, how far into the tranny does it go? Is that junction between the tranny and driveshaft a common weak point?
For the most part the driveshaft is OK, the only damage it has is a scraped up area where it rode on the exhaust housing while I towed the vehicle. Is it safe to re-use?
The whole flexible coupling area is thrashed, the splines are stripped and the area that slides onto the tranny is wallowed out. I can only guess that the driveshaft started slipping off the output shaft of the transmission, and then started banging around and doing some damage as the parts separated. The center support and u-joints seem fine and show no evidence of being the cause of this. The rear tail housing of the transmission is cracked where it bolts to the rear tranny mount, but I am not sure whether that was caused by the vibration or caused the problem.
Any insight?
Any idea what could be the cause, and if it is a simple fix?
Thanks-
Any other lubrication type of maintenance that needs to be done?
Thanks....
The question is: what caused the failure? The old flex coupling did not fail. The logical guess was the broken extension housing that the transmission mount attached to caused the transmission to lower and led to all the other problems. Except I replaced that mount this summer and I would have noticed the break, unless it happened since then, and then the question is why did it break?
I wanted to thank you, Mr. Shiftright, for your assistance, and my last question is about that transmission extension housing. Why is it so common to fail--the guy at the junkyard knew exactly the part I needed and they clearly supply them often. The junkyard guy chalked them up to failing flex couplings, but I'm not sure why that would lead to a new extension housing. Any thoughts?
By the way, putting new threads on a 1" shaft that is horizontally mounted while lying on your side underneath a car is not easy, but beats removing the tranny.
Congrats on tackling a tough problem and defeating it. Very impressive. I don't mean to worry you. I'm sure your car is fine but if you can run her up on a rack and look around for stress-related damage, all the better.
1) Can I salvage the vehicle after being idle for so long?
2) What steps will most likely have to be taken in order to get the car up and running and what should I say to the mechanic when I tow it to his shop?
3) With regular and timely maintenance performed on the car can I expect it to be fairly reliable?
4) There is a dent in the grill that has bent the grill from a fender bender but it is largely intact and nice looking. Can this be repaired without having to replace the grill entirely?
I would love to keep the car because it has always been reliable and has fond memories for me. Thank you very much for any help you can give me.
Diesel tanks can actually grow algae in them, and the fuel itself can decompose, so your mechanic has the lovely job of draining and flushing the fuel tank first off.
Then probably a fresh battery, new fuel filters installed, and crank 'er over (after LOTS of priming, but he knows how to do that).
Once it is running, it's time to check the tires for cracks. if they look okay, the brake system should be flushed and then tested to see if any of the calipers have frozen up. If it starts, goes and stops, then change the oil and filter.
As for the dent, you can take the grill out, get yourself a little ball peen hammer, or better yet a small wooden mallet, and tap away on it until it's straight.
So to summarize (in no particular order)
new battery
check tires, replace as necessary
flush fuel tank
change fuel filters
flush brake system
change engine oil and filter
flush cooling system
change thermostat or at least remove and test.
check all hoses and belts for cracks
That should do it.
Of course don't buy the tires until the thing is running well. You might not have to change belts and hoses. They need to be looked at carefully.
As for how long it will run, that depends on how much $$ you wish to put into it. 250K is a lot of miles.
I ran my old 300D for about $85 a month in repairs and maintenance.
