Ford F-Series Care and Maintenance
in Ford
Is it possible for the vibration from a warped rotor to transfer to other parts ie; Idler arm bushing, tie rod ends, sway bar bushings,pitman arm bushing, steering componants, drive train and my wrists?
My opinion is that the Ford rotors are an inferior design.
It had about 4 brake jobs, one included new front rotors. Definitely you will feel it in the steering wheel and in the whole truck if you let it go.
Any help would make my move that much smoother. Thanks!
Max
Does anyone have any idea what could cause this problem?
I have run out of ideas, and patience. PLEASE HELP!!!!!!!!!!
Any suggestions would be greatly appreciated.
I and my mechanic are stumped. Any ideas?
I've got an '01 F350 V10, and a '95 F-150 - outta habit I usually change the oil at 3-4K. The F-350 Tranny interval is every 30K, but I tow, sometimes over 10K lbs, so I've changed the fluid more often. I've inadvertently overheated the tranny, gauge read about 275 degrees F, once when I got stuck in mud, and another slowing backing the trailer up a long steep hill. Changed the tranny fluid a couple days later to prevent any damage from degraded/burned fluid.
Forget the rear and differential intervals, but they were moot for me. I managed to be stupid more than once and get stuck in water that turned out to be deeper than I thought, where water was even with floor of cab and bed. The air outlet on the rear end pumpkin was obviously submerged. Changed out the differential fluid to prevent any water damage.
For normal use, follow the recommended intervals in the owner's manual. If you stress the vehicle like I have on occasion, change the fluids more often, it's much, much cheaper than a new tranny or rear end.
My '350 has about 50K with virtually zero problems. My '150 is approaching 200K with original engine - no rebuilds, it's still makes good power - but tranny was rebult at 120K and is starting to bet squirrely again.
I would think that you have a problem in the wiring of that harness, I would take it loose and make sure there are no bare wiring and check the lights and the lights should work fine, then when I re installed the wiring I would use insulted crimping items to reinstall with to keep the wiring in good shape.
If this is factory done, Then you would just take a test light to the rear and check that plug, usually when you have something added that is usually where a problem begins.
If I am wrong I apologize but from my experience this is correct and I work on vehicles every day.
Thanks Friend and hope I helped you if not reply again and I will try to help further.
Ray
I'm trying to find the engine oil capacity for my truck. Is it 5 or 6 qts. if I change the filter as well?
Thank you very much for any help or advice.
signed betard :confuse: As Soon As Possible the answer to this request.
I was wondering if I could get opinions. Did I make a good buy?
I wanted something nice and I want to make sure I have a solid truck to be driving.
