A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Miscellaneous Truck Questions
My last Pep Boy special lost the pulley flange from the shaft after 10K miles. Operative term is LAST. Labor is far more expensive than the part.
between a SRW and a DRW on a 1999 F350 4x4 diesel?
www.kbb.com
Please e-mail or post, as I lurk here in the pick-up forum and get much appreciated info! -PT
I will let you all know as soon as I find out that other prices have been updated.
PS -- Kelley's site doesn't have the 1999 Dodge Ram prices either.
http://www.carprices.com
could call. I overlooked the obvious...
A friend of mine had a Bronco II which had similar symptoms, and it turned out that his driveshaft went out of balance. But, as lwf indicated, it's more probable that the tires are the cause.
Chevrolet C1500 LS Extended Cab Shortbed
1999 Chevrolet K1500 LS Extended Cab Shortbed
Ford SuperDuty Extended Cab and Crew Cab
http://www2.ford.com/searesults.asp?qu=trailer+towing&ct=fordcom&country=Global+Links&x=7&y=22
might be a good place to start.
I think the spray on bed liner like Ziebart has is
the best liner out now. It does not shift in the bed and take the paint off to rust under the liner. It can be repaired if you do get it marked up from hauling things in the bed. It's a little more expensive than a drop in liner but it is worth it in the long run.
Casper47
You should also check out the following topics, which have a lot of dicussion about spray-in liners, tonneau covers, and all sorts of ways to cover the bed.
topic #96, truck accessories
topic #252, R hino liners vs. spray in liners
PS sorry I couldn't be of any help.
Are your tires a lot fatter than stock? or underinflated?
Does your vehicle have some sort of pressure switch on the PS system that boosts the idle speed when you operate it? If so, and that is not working, the idle speed could be too low for the pump to do its job.
The basic problem is that the pump is working harder than it should, or the fluid level is too low, or it is in fact defective in some way.
HP
HP
and the rear tires to 80 lbs, but when I took delivery of the truck all tires had 45 lbs. I am somewhat confused as to what is the proper inflation for the tires. Does anyone know? Thanks
