Miscellaneous Truck Questions
I hope this helps you..
Stiffer ride: because they come with heavy duty suspensions.
lower gas mileage: only when trailering or loaded; assuming it is the same size engine.
Anyone know where I can get one?
mmaster@ibm.net
Thanks Bnesb
bnesb737@nextsteps.com
Has anyone accidently added Kerosene to deisel fuel and run it in their truck?
I made the mistake last weekend when I had not had my first cup of Java. I pumped 8 gal. of kerosene
into my Dodge before realizing I had picked up the wrong nozzle. Thought I was going to get stuck
on a trip to V.A. with a nasty mechanic bill but
found out instead that some truckers actually mix
kerosene with their deisel fuel because it burns cleaner and hotter.
Just a thought but I would like a responce.
Also, I've heard some vehicles being described as having a tall gear ratio, does this mean that it has a high gear ratio (e.g. 3.73) or vice versa?
Tall gear ratio means higher 3.08. I know it can be confusing, I'm glad you are asking questions...
For Fords the tow rating for 4.2L V6 with 3.08 is 1900lbs. With 3.55 its 3600lbs.
I hope this helps..If not keep asking questions.
Glad you asked the questions about gear ratio. I was equally confused. I have found some answers in other chat areas also. If I understand it right, the offset of getting the additional towing power and power from the start is that you are running at higher RPMs at all speeds. My guess is that you might see a little improvement in gas mileage on a long highway trip since you would be pulling less RPMs. If you travel a lot of highway miles, the engine may also be working less on a taller gear over the long term since it's pulling less RPMs at the highway speeds. Theoretically this would mean that the engine might last longer or require less maintenance. But remember, I'm not anywhere near an expert in this area and I could be wrong. I'm looking forward to hearing mharde's response. He appears to have the gear ratio stuff figured out.
mharde,
I'm giving some serious thought to ordering one of the new 1999 Superduty trucks. The gear ratio question is one I'm unsure about. It appears that the V-10 comes with the option of a 3.73 or a 4.3. I read in one chat area about a guy who had a 4.0+ gear ratio and said that it really lowered his highway cruising speeds. I'm guessing that the 3.73 is more than adequate for my needs. I probably won't tow much for the first couple years and when I eventually do tow, it will probably be a camper on top and boats or snowmachines on back. I won't be towing a fifth wheeler or anything that heavy. What's your opinion? Is the 3.73 the way to go?
By the way, I currently have a 1992 F-250HD 4x4 with a 3.55 gear ratio and the 5.8L. I've got 81,000 miles on it with lots of highway miles. The truck runs great on the highway at 75+mph for extended periods. That's one of the reasons, I'm thinking the lower 3.73 gearing might be the way to go. At one point would someone consider a 4.3?
would be the best for your application. It was a hard choice for me also, I'm still not sure I made the right decision when I ordered my Ram 2500 turbo diesel. I ordered it with the 3.54 instead of 4.09. I wish they offered a 3.73. I would have jumped on that one. I was afraid the 4.09 would be a little to low.
I now have F150 5.8L w/3.55 and I tow a 26' 5Th weel.
There is so many choices and combinations it makes your head spin....
What kind of price are you figuring on the Ford 250 superduty. I had a hard time choosing between the Ford and the Dodge too. I hope I made the right decision. I get very nervous spending this much money for a truck. My deal came to $28,646 + TT&L. That was the Turbo Diesel Quad Cab, short bed with everything except the leather.
everyone seems to be calling these "gear" ratios
and I think they really mean "axle" ratios. The difference is that gear ratios pertain to the transmission and axle ratios (3.54, 3.73, 4.3, etc.) pertain to the differential. One other point mharde2 might have made is that an easy way to remember how to choose between a small or big number when selecting an axle ratio is that it represents the revolutions the engine makes for one turn of the rear axle (I think but am not sure that applies when in high gear). So....., you'll want that number to be small if you're looking for efficiency and big if you want to do some serious
hauling or towing.
For a 97 S-10 what would be the gear ratio of a 4 speed automatic transmission?
If 3.42 is the axle ratio!?
"Could someone please explain the difference
between "gear" ratios and "axle" ratios.?
If 3.42 is the axle ratio!?"
I thought I just answered the first question the other day. I can't tell if you are pulling my leg or you really don't understand the difference,
but I'll try to elaborate on what I had previously described as the difference between between "gear ratio" and "axle ratio".
gear ratio......This pertains to the transmission which has an input shaft that is coupled to the engine's crankshaft and an output shaft that is coupled to the driveshaft (the steel tube installed between the transmission and the differential through a couple of universal joints). For a 3-speed transmission there are 3 gear ratios, for a 4-speed transmission there are 4 gear ratios, etc. Typical gear-ratio values are:
2.8:1 for 1st (usual value but it might be slightly different) and this means the crankshaft makes 2.8 revolutions for each
revolution of the driveshaft,
1.7:1 for 2nd (usual value),
1:1 for 3rd (always).
For the S10 4-speed automatic you are interested in, I'm almost positive the 4th speed is an overdrive gear and the gear ratio is probably somewhere around 0.9:1 (someone from Chevy will have to provide you with the actual value).
Some of the manual transmissions today have 5 speeds and in these I'd guess that 4th is 1:1 and 5th is the overdrive
axle ratio......I probably added to the confusion the other day when I defined this as the number of revolutions of the engine crankshaft for 1 revolution of the axle when the transmission is in high gear. That's not really incorrect, but it would be better to think of it as the number of revolutions of the driveshaft for 1 revolution of the rear axle when the vehicle is going straight so that both of the rear wheels are turning at the same speed. You have to keep in mind that the primary purpose of the differential is to transfer
power from the driveshaft to the two rear driving axles (left & right) in a manner such that when in a turn, the outside wheel rotates faster than the inside wheel. On the straight-a-way, they rotate at the same RPM, but it is never at the RPM of the
driveshaft. It's always slower, and in the examples provided in earlier postings
those numbers representing driveshaft-to-axle revolutions were 3.54 to 4.09.
All of what I just wrote pertains specifically to rear-wheel vehicles. With the front-wheel vehicles I'm acquainted with, the transmission and differential are combined into a "transaxle" and there is no "driveshaft" per se; however, I believe the principle is the same.
Now to turn to your to question about the S10's 3.42 axle. I hope it's crystal clear
to you by now that the "gear ratio(s)" of the 4-speed automatic transmission have absolutely nothing to do with the "axle ratio" of the differential, whether its 3.08, 3.42 or 3.73. I think all three are available with the S10 4x4
but only the 3.08 and 3.42 can be provided with the 2WD versions.
Thanks for explaining axle ratios and gear ratios I wish I knew more about that stuff before I bought my truck, I guess next time I will know better.
I just ordered a 99 super duty w/diesel. XLT but not Lariat. I couldn't see the extra for leather. My dealer added $1300 to the invoice. (How do I know? We both sat in front of the Ford computer screen and typed in the options and ordered it.)
Just be aware that what you don't see in the pricing services is $640 for shipping, $22.41 for fuel and something like $50 or $75 for joint Ford/Dealer advertising. If you're in the LA area I can give you the name of an honest dealer/sales manager. This is the third vehicle I acquired from him.
Rich
Thanks for the info. It sounds like everyone is getting the new trucks for about the same amount over invoice. The lowest I've heard is $1,200. I've also heard 4%, which is about the same depending on what options you get. I was prepared for a destination charge in the $700 range. I guess we can assume the advertising charges are for the future, because I haven't seen a lot of advertising of the new trucks by Ford yet. I think alot of people are going to be surprised when they start showing up on the streets, especially the new F-150 owners. I don't think most people know about the Superduty body style changes for the F-250HD and F-350.
As for living in the LA area, I spent the last 4 1/2 years in Southern CA (one in LA County, the rest in Orange County). My job transferred me to Dallas in November, so I won't be able to use your dealer. I will probably try the Auto-by-Tel on this site and see how that works. I plan to pay about what you and the other people have paid, and I have a price range that I expect to get on my trade-in.
You should try State Farm Finance, (you probably never new they had such a thing) they are usually about 1% below the bank rate.
Joel
It's a great article.
Automotive fads come and go, but pickups still rule, and will continue to evolve since they provide not only transportation, but the most versitility of any mass production vehicle.
Even SUVs are limited by comparison. You can always virtually duplicate the functionality of the SUV by putting a cap on a pickup, but you can always remove that cap for carrying larger items.
It will be interesting to see what the next generation of pickups have to offer...
true 'crew cab' again, not just a 'quad cab' but
one with 4 real doors that holds 6 real people
like the Ford but with a good diesel?
The back seat of the quad cab will at best hold 3
well behaved small kids on short trips.
How's the new truck other than the engine noise?
ghuchin,
I don't know that much about diesels. Do you think the changes Ford made to the Powerstroke for the 1999 SuperDuty will make a difference? Some of the changes are outlined in an article on the 1999 SuperDuty trucks at www.truckworld.com. What are the some of the bigger differences between the Cummins and the Powerstroke?
OWL=Outline White Letter
Jim
The Ford is rated at 235 HP@ 3000rpm & 500lbs of torque@ 1600rpm (I think). The Dodge is 235 HP@ 2500rpm & 460lbs of torque@ 1400rpm. They both get around 20 mpg. They will set you back in your seat...
They are both great trucks, we just liked the looks of the Dodge better. I havn't towed my trailer with it yet so the jury is still out for a few more weeks.
Some people on the boards still seen to be confused about, "Why would you buy a diesel that puts out 235hp, when you get a big block gas engine that puts out 275-300hp,for alot less money?"
I will use a 3.55 rear axle in the explanation sense this seems to be the most popular. w/auto
When you are going down the hwy at 65mph your turning around 1750rpm in O\D, 2650 in 3rd. With the DIESEL your cranking out 235hp at 2500rpm, the GAS engine is putting out about 185 at 2500rpm.
You don,t get that 275-300hp until you reach 4000-4250rpm. (That would be 150mph in O/D)
Also the DIESEL uses 60% less fuel, and will last 3-4 times longer than the GAS engine
Went to order my 1998 Sierra shortbed X-cab with 3rd door and got a call back saying that they were no longer accepting build orders for this a/o 3/18/98. However they will be accepting builds for a 1999 Sierra "Classic" in about 3 weeks. Dealer says this will be the current style bodywork with current engine options but sold as a 1999. He had no info as far as pricing or options but gauranteed me no problems in ordering with my specifics. As I do not want a new body style, I'd really like to know about this "Classic" a.s.a.p. so I can decide if I'll be ordering one or if I should start looking on lots now for a left-over I can live with. Thanks for any info sent my way.
-- Desmo
The diesel produces its peak torque usually at a lower RPM than the gas engine. (1600 V 2000 RPM)
Your numbers are correct though Brutus.
Actually, I'm just trying to convence myself that I made the right decision going with the diesel. It was a very hard choice...
Interesting article. What's the deal with that chip? It looks like the author might be a tad bias towards Ford, but the two diesels are a lot closer than die-hard Cummins fans would like to admit. The interesting data will be when we see how both engines hold up at 150,000+ miles. My opinion is that the Ford is the better built truck, but Cummins probably has a slight edge over the Powerstroke. But I'm bias toward Ford, and I'm not driving a diesel.
If you're not, you should be a politician!
(I mean that as a compliment...)
Ron
