Chevy/GMC Owners
There is a link to them on this site.
For the Z71 lift kit get the magazine from Performance Products, I think they have some.
We went ahead an bought the car. As luck would have it, I started to notice a problem with my truck. It's shuddered a few times when I'm in low gear and idling as if its going to die. It hasn't died yet. I just had the coolant flushed, so it shouldn't be antifreeze problem. Maybe the fuel line? I haven't changed the fuel filter for 30k miles.
Any ideas? Or is this just what an old truck will do.
FUEL FILTER.(MAYBE) BUT IF THE FILTER IS PLUGGED IT ADDS STRESS TO THE FUEL PUMP. WHICH IN TURN MEANS BIG BUCKS TO REPLACE THE PUMP.
start by replacing the fuel. then drive the truck for awhile. if that doesn't fix the problem it may be the fuel pump(maybe). have the pressure in the fuel line checked!!!!!!!
if it is the fuel pump it will cost a few bucks. you need to lower the gas tank and remove the old pump. by the way new pumps are not that cheap either.sorry for the bad news. hope it is the fuel filter
additives will not help the pump.
sometimes if you drive with a half plugged fuel filter it puts added stress on the fuel pump. which in turn does not get the fuel up to a high enough pressure in the line.
I have had 2 others ('93 & '97) that did not do what this one is doing now. But, Chevrolet tells me (because my dealer told them) that this is "normal". I'm intentionally not putting how much it is using until I hear others experiences.
Any feedback is welcome.
Got the fuel filter replaced. Haven't seen anything since then, so I've got my fingers crossed. Mechanic suggested some injector cleaner just in case. He checked the alternator to see if that was problem, but it seemed OK too. (mentioned something about I should check the spark plug wires for arcing?)
Added a new part to my Glossary of terms - Idler Arm. The Mechanic says I need a new one and showed me how it is supposed to move left & right only, whereas mine moves up & down as well.
Estimate for the part surprised me. They also said I'd have to get a front end alignment with the new part. Is an alignment absolutely necessary when you replace this part?
I've had a history of this mechanic throwing parts at my car periodically. They do a good job, I just have to watch em.
Feedback appreciated.
if your idler moves up and down, then you'll need to replace it. have you ever greased all your steering linkage? that's usually the cause of linkage wearing out. is your steering a little loose? that would be another indicator something is wrong. if your steering is still like brand new, then i would be suspiscious.
you will probably need an alignment because you are taking a major link out of your steering by pulling out the idler. it is unlikely a new one would fit exactly the same alignment as the old one.
If you live in an area where there is "oxigenated" gas you need to replace the fuel filter at least once (better of twice) a year. The oxigenated gas pick up all the junk from the tank and blocks the fuel filter, also the gas treatment they put in "eats up" the element inside the filter.
I am suprised oxigenated gas is still around, it is a proven health hazard.
Most of my maintenance has been oil changes, fuel filters, air filters, which I've been very good at.
When you start talking about greasing stuff, I don't know.
In any case, the mechanic showed me where the arm moved up and down, but my steering hasn't been loose.
I'll take it to another mechanic to look at it and see if I can good a good price. Looks like I'll need that alignment.
(Stevek, what is oxigenated gas? You don't mean Octane do you? Or are you talking about Gasohol? I use mid-grade at major name gasoline centers so I doubt fuel is a problem.)
On the window sticker he does not have tow package specified and we have no explanation. The trucks were manufactured at the same plant about 6-8 month apart. His truck is also lighter in the back than mine therefore the ride and handling sucks.
Anyone got any ideas.
I ordered a Black Silverado Z71 extended cab LS Sportside 5.3L 3.73 on 10-12-98 and got preferenced a week later. I called Chevy today and they say that the Sportsides are still on hold for something with the tailgates?? They told me to call back in 3 to 4 weeks? Be patient hopefully it will be worth the wait? It is my understanding that the Chevy's and GMC's are built on the same lines so I don't think any are being built?
Look at the 1999 Silverado forum in Edmunds!
There have been some recent postings bt new owners.
thank you. Aaron Burns
I also have oil smoke on startup which is a result of oil dripping in the cylinder via valve guide seals (no big deal). However, I find that when I go up into the mountains (over 10K feet) for a while, I get lots of smoke until I get back down to about 5K feet. I assume this is a result of the computer changing the mixture due to the thinner air. Can anyone confirm this or provide another diagnosis? R/Clay
How exactly did you know for sure that the valve guides were leaking? what did you check? i've never had to do that diagnosis and am curious about how you check that.
any ideas on the heater prob?
The truck was bought in May and has about 13,000 miles on it. Since I have had it I have had to replace the the master cylinder on the brakes (leaking) had to replace weather stripping on one door because it wasn't glued down. Had to have the glove box aligned because it wouldn't close properly. Had to have the air conditioning fan replaced because of noisy operation. The center console/armrest was replaced because it stopped opening. Driver's door has been worked on twice for rattles, 3rd door is now in for new rattles (I have heard that many 3rd doors tend to have noise in them). Wires from the battery were not attached firmly from the factory and resulted in starting difficulty. The cruise control was not properly adjusted from the factory as well.
This truck is in the shop again for an unexplainable thump/clunk noise from the floor board when leaving a stop (this does not occur all the time and I'm still trying to isolate what I'm doing at the time the noise occurs). Does anyone have any ideas/suggestions as to what this noise may be?
Is this truck worth keeping? In my opinion there are way too many quality control/assembly problems with it at this point for me to want to keep it for the long haul.
Through this I have been lucky in that the Chevy dealership in my area has been very good about doing warranty work even though I bought the truck in another state.
Anyway, I hope I didn't bore anyone too much. Your comments and feedback are very much appreciated and wanted. You either reply here or email me at jgt74@yahoo.com
Is the "thump/clunk" noise coming from the floor or from the rear end?
We have a '98 3500 6.5L diesel that sounds like going over rumble strips when leaving from a stop. It also doesn't happen all the time, but seems to get worse the longer it is driven. We had a '97 that had the same problem as well as numerous others. (It was repurchased by GM because of a chassis problem.) Both of these trucks started having the rumble effect around 3000 miles. The dealership replaced rear end fluid in the '97 many times. They replaced the cluster gear in the '98 and said there were metal shavings present. This seemed to help for about 7000 miles and now it has started up again. A friend of ours had a Chevy van that also had the same problem.
S10 good luck (stevek) Fri 02 Jan '98 (06:37 AM)
The sound I'm refering to is coming from the floorboard area, near the hump in the middle of the cab. Took it in to the dealer and of course they couldn't duplicate the problem. So right now I'm in the same boat I was before. With all the trouble I have had with this truck, I may be over-reacting to a normal sound. Thanks for your input iluvspots.
I have an 89 s10 Blazer. So far with 180K on it and the engine and tranny has not been touched. I was told I am the exception especially when it comes to the tranny(automatic), they seldom last much over 100K. About 3 years ago I repainted it but the rust is starting to "blossom" now. The rest of the truck is solid and I may even replace the engine when (or if) it goes.
$6K sound a bit high even with low milage (like 80k) it should not worth more than 4K in my oppininon. Try several web sites (like Edmunds) where you can put in the info and it will give you a whoilesale/retail price.
1)Power steering pump leaked
2)Front axle seal leaked
3)Tranny went (Xmas day,48 k miles)
All have been repaired by dealer, I had to kick in $100 for the tranny as I was beyond 36k by now. The picked up the balance under their "goodwill"program. I have always beena GM man,my wife also drives a Chevy. But, I have become dissilusioned after the tranny went at 48k. I always felt one of GM's strengths were their drivetrains.You cannot beat their gas motors. I admit I drove the Dodge and Ford after getting pissed about my tranny. The dodge rides like it is 20 years out of date, the Ford was pretty nice.I may switch, I may not.Untill the four door 1/2 come out next year (see Ford.com) I probably won't do anything because neither the 99 GMC or the new Ford was significantly better than my 97 GMC.But those four doors (four real doors and a real back seat)sure do look nice! Any feedback on the problems I have listed would be appreciated.
I got the 4.10. I like that extra get up and go! GO FOR IT 4.10
