A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
1999 Chevrolet Silverado
I'd wait for the next yr model as long as your '97 is still doing the job OK. I think they are still working out shortages from the strike, plus any first year bugaboos. If the heavy duty models make it out next year, you may be happier with the big block gas or Isuzu diesel other than the 6.0, which might not be big enough depending on your fifth wheel size.
and to all doubters, chevy's and GMCs used to come from the same factory (don't know about the '99s) I've seen chevy trucks get to the dealer with a GMC grille, or a GMC door emblem, etc...
I know the brochure says you have to order the Z85 or ZX3 when ordering the heavy duty trailering package...but I was able to order it(the HD trailering pcg.)with the Z83 suspension. The Z85 susp. cost $81.70(invoice) more and mine doesn't have it listed on the options...The ZX3 sounds like a neat idea if it works... might be worth the wait....007
Including the factory stuff SILVERRADO sticker in chrome OR GMC TRUCK . JUST PREY THEM OFF WITH A SCREWDRIVER carefully LOOKS MUCH NICER WITH NOTHING ON
All you have to do is get your wifes hair drier put it on low heat and warm up the sticker and peel it off. It will leave some glue, just get some rubbing alcohol on a soft rag and rub the glue off. If the alcohol does not work then you will have to get some wax and tar remover at your local automotive store. I would wax the area after your done.
Tom201- when did they let you know you had a build date? I'm hopeful that things work out for all of us who ordered the G80 differential option.
Dave40- I chose the CHEVY over the gmc because I prefer the grill. Although I like gmc's just fine, the grill looked a little too much like a big mouth for my tastes. Just my humble opinion.
ps. The ZX3 seletable shocks aren't avalable on the 2500 I heard?
Any IDEAS WELCOME !!!
Don't see the G80 limited slip on hold. November report should be out shortly.
3/4 ton silverados are now being manufactured per the report. Chevy says 12 to 16 week leads....
I was ready to order my silverado, but there is a hold on the non-carpet floor and camper mirrors and I will have to make decisions.
6.0L should do a dang good job towing anything less than about 10,000lbs. I have owned two diesels and will never buy another unless I do at least 50% of the milage towing long distances. For everyday driving, buy a gas motor. Hell, insurance on you vehicle is probably more per year than 10,000 miles worth of gasoline.
Catback guy: Why would you replace an all-stainless steel, well engineered exhaust system with a junk aftermarket exhaust? I race dirt bikes, and in general, I believe that exhausts that are stock and quiet are the best, be they for tow rigs or race vehicles!
Of course, there are plenty of options out there if you JUST WanT someTHING THATS LOud...
Most of gale's power increases are tend to be near the peak HP RPM range. If you got another 50 hp at 4500rpm, how often would you operate there?
How long is the payback for a $2000 investment for an exhaust system if you gain 10% fuel economy?
compare to the FORD SUPER
DUTY 3/4 ton 6.0 vs V10.
Who has smother ride ?
Lets see, the vehicle will weigh approximately 2.5 tons......
You have a VERY good salesman if you believe this.
I'd bet about 10 to 12 around town and 15 on the highway.
Govt doesn't do economy ratings on vehicles with GVWR above 8600 lbs.
Gas prices now are relatively cheaper than they were in the 60's at 25 cents per gallon.
I wouldn't sweat the mileage......
service said they won't give that information out anymore to the customer. You have to call the dealership and have them get the information for you. What a bunch of crap!!! That probably means they won't give out a ship date either. It seems Chevy has won this round in customer service.
Two weeks later I was informed the entire 'order system' has been revamped: No more wait to be prefferenced and then a build-date... No, what we need now are 'allocations'. Allocations are issued at 10:00 AM Eastern Time Tuesday mornings. No allocation, no order. (No soup for you today! Wait until next Tuesday!) Four weeks into the proccess, no allocation, the order has not been even entered yet! Next Tuesday 11/24 is do-or-die because, due to Thanksgiving weekend no allocations will be issued on 12/01.
Anybody else having a similar order experience or am I being played for a sucker?
from an Unbiased and Happy NEW truck owner
Dennis
would like to hear comments
Also, it seems that everyone here is ordering as opposed to buying off the lot. Is that just because of the still limited inventory that most dealers have?
However, with the other options I want and the limited dealer inventory, the Z85 seems to be more readily available. Is it safe to assume that the Z85 ride will be noticeably rougher than the Z83 or is the difference negligible.
supposed to be built NOV 9th BUMP ME BACK ANYMORE AND I'LL BUY A PEARL HARBOR SPECIAL NISSIN DATSUN TOYOTA LETS GET ON THE BALL GM ! I ordered it aug 1st WHATS THE HOLDUP?
The Z71s have bigger shocks
and much firmer ride.
.....just a thought.....
shocks make NO difference whatsoever on the height of a vehicle.
4/4.
I'm not a tech, but the way it was explained to me
is that a "4x4" without limited slip differential
is really a 2x4. Since one of the front wheels is not a "drive wheel" so that the vehicle can turn easily, only one front wheel provides traction. Limited slip rear axle provides the ability for the second rear wheel to provide "drive" when the first rear wheel begins to loose traction (slip).
So with the G80 your "4x4" is really a 3 wheel drive. (not sure of your age, but if you can remember when "positraction came out, you could tell if the burn marks were fron a car with or without "posi" if there was a single tire burn, or a double burn.
Thank you for the explanation on the locking differential
option. I can now see the value to ordering this option.
