I am not sure but I think the transmission warranty on the '02 model was extended to 7/100,000 can anyone confirm?
When I called Acura several months ago about the transmission problems I was given the same information as frev in post 159.
Look back to posts...
sbcooke "Acura MDX" Jun 19, 2002 9:45pm
sbcooke "Acura MDX" Jun 19, 2002 10:33pm
It is important at the step 13 you have all the fobs you want to program ready to setup.
I have had two cars that I know had been repaired before the dealer received the cars. Each had a small area where the paint wasn't quite right. In each case the dealer didn't receive any information that the the cars had received repair work before being delivered to him. Both had to be "fixed" after delivery. Both were just a repaint (one was the driver's door and the other was part of the trunk) and both held up fine. I kept one of the cars 12 years.
I suspect my 1990 Volvo also received some paint work after shipping. The paint on the right front side of the hood was rough, though the color matched perfectly. The hood was re painted after delivery to me, matched perfectly, and was fine for the ten years I had the car.
If it was my car I would insist that the hood be made right. Don't expect a new hood pre-painted at the factory. Probably would not be an exact match anyway. A good body shop can do a long lasting repair that will match the rest of the paint on the car. My 02 MDX has two cosmetic defects that I noticed shortly after delivery. One is paint on a rear fender and the other inside on the top of the dash. The dealer offered to repair both under warranty.
I also have experienced the weird "chirping" noise. I thought that it could have something to do with the A/C but I turned off the A/C and the sound persisted. It only happens every now and then. It sounds like a bird is stuck in the engine.
And now, most recently, I am experiencing a very distressing grinding noise when I carry anyone over 100lbs in my backseat. It occurs mostly on turns, curves or bumps. It sounds like the tires are scraping against the fenders, but there is no evidence of this on the tires. I will be taking the car to the dealer next week. Oh and also, this week I have experienced the car stalling at stop signs. The idle "skips" and the car stalls. I did put cheap gas in the day before this began and have since used only Premium fuel but I'm still experiencing a "miss" in the engine but not any stalling.
Is anyone experiencing this grinding and stalling? I do have 40K miles but the MDX was touted as the best SUV on the road.
Grinding over bumps...I had an old Nissan Altima that did the same thing over bumps with anyone in the car, it was the struts and I learned to live with it since it was common. With the MDX it isn't common, so they should fix it. It could also be something loose or rubbing in the suspension.
Have you had your MDX serviced at the regular intervals? They supposedly "re-torque" some suspension components at 7500 miles and the 2001's had a few welds that had to be grinded off to elimate noise.
My Honda dealer is willing to do the 15k maintenance on my 2002 MDX. The price is 150 vs 300 dollars.
Is this okay? Anything special that needs to be done for this service?
http://www.northeastacura.com/en_US/f_MiscPage_6.chtml
You might be able to save $$ if you go ala carte.
Though the manual did say 5W20 oil...which was a mistake, it is supposed to be 5W30.
one day i noticed that my front headlight, has condensation in it. i was surprised cause i thought those lights were pretty air tight.
After switching off the turning it on again, the prodlem did not re-appear.
Did you check with the dealer , if so what's the response?
I ended up cutting off everything that covered the sides and back of the middle row seats. Now it is just a mat, which works quite well for my hauling. I've carried sod and lumber, as well as bags of salt, plants, and other dirt dropping things. Keeps the carpet clean and I just hose it off. I left enough on so that there is a flap that covers the rear bumper when I load and unload. When not in use I roll it up and store it in the under floor area in the back.
I also found the cargo net tends to keep things from sliding around.
Here are some symptoms:
- It turns ON whenever I open the doors, along with the other lights
- When I start the car and shut the door, all other lights in the car slowly turn OFF by themselves except for the light in the glow box
- When I stop at the signal light it will sometimes turn OFF but comes right back as soon I start moving.
Is this a loose connection, it has only been a three days since I bought this vehicle.
IF you have a problem with the VTM unit, Honda, if they want proof you have maintained the car according to the owner's manual, can ask for you to prove you had the fluid changed. If you can't they will probably not do the repair under warranty. You could fight it if the problem was not lubrication related, but it would be a long shot.
The cost of the fluid is about $20 per gallon. It takes less than a gallon. Your mechanic will need a very clean pump (about $10 from the Acura dealer) to get the fluid from the container into the VTM unit. The pump fits the container top and has a fitting at the hose end that snaps into the VTM unit.
There is no accurate way to check the fluid properties visually. All one can do is check fluid level. There are clutches in the unit and, like my old positraction (limited slip) rear ends from the old days, the fluid needs to be changed to keep these functioning properly (no grabbing).
Around here Acura dealer charge $65 to $85 for a VTM fluid change. While the job takes less than a half hour, it took my dealer over two hours before he got the car in and back to me. I bought the hand pump from Acura and will change it myself at 30k. It will be done while I change the oil, so it shouldn't add more than 15 minutes to the oil change time. As with an oil change, the car does not need to be on a lift. There is plenty of room to slide under the car and get to the VTM unit.
Has anyone had issues with this? There was one post from a 2001 MDX on that forum with a problem? Since the 2003 Pilot and 2001/2 MDXs are almost twins I would assume those same problems would show up here?
Considering other vehicles with "floating" systems don't seem to have this problem one would think Honda would have a fix by now. Maybe the 2004 model is different.
Yes, it is annoying. No, one doesn't expect this noise on a $40k car, or a less costly vehicle either. Our experience is that with time it becomes less annoying.
Harjit
Harsmdx...
Some manufacturers are very good about taking care of customers. Jaguar replaced my car three years ago, at my request, after two repair attempts (in a 4 repair attempt state). My Chevy dealer offered and did repurchase my first Corvette years ago. I thought so much of how well he treated me I bought another one from the same dealer about a year later.
By contrast, a little more than ten years ago, Volvo was like a tug of war. In my sixteen years hearing lemon law cases I found manufacturers, for the most part, were reasonable. There were some glaring exceptions.
If the car is not fixed the next time you bring it to the dealer make sure to write a letter to Acura about the problem and clearly state what you want and why you feel the car qualifies as a lemon. Be sure to document all of your conversations and, very important, make sure the repair order clearly states what the problem is (the noise) and the effect it has on you.
Hopefully the noise will be gone in a week and you can start enjoying your MDX.
