It's gonna cost HOW much???
alcan
Member Posts: 2,550
Interested in knowing the actual published time allowances for repair operations? Post the repair here (be specific) and I'll let you know how much time allowance is given in the current Mitchell Mechanical Labor Estimating Guide, used by most shops to calculate labour charges. Just multiply the time by the shop's hourly rate. Includes domestic and import cars, vans, SUV's and light trucks (pretty thin on VW, though). Some operations may exceed the published times due to factors such as seized or broken fasteners, aftermarket equipment installed, etc. Diagnosis (includes driveability, rattles, squeaks, water leaks, etc) and wiring repairs are usually straight time, the actual time clocked on.
Be an educated consumer, ALWAYS get your estimates in writing, that is your contract, if it will cost more than they thought the shop MUST contact you for approval.
So, I simply ordered new rotors, a pad wear sensor, and new pads from my local BMW parts supplier (who only carries OEM parts) for $117, and did my own brake job in an hour and 5 minutes. Given that I don't have the benefit of a fully equipped garage and a lift (and I had never even done a rear brake job on a car with rear disk brakes), I can only guess that the trained mechanic in the fully equipped service department would be able to accomplish the same job in about 45 minutes.
Hmmmm, let's see, $194 for 45 minutes of work comes out to $258.66 per hour. Not bad work if you can find it.
seriously, that quote was padded way to Hell and gone, somebody must have had a boat payment due.
Shiftright's rule for amateur mechanics:
Disassembly occurs at approximately 6 times the speed of re-assembly.
it's nasty to take big rusty chunks of iron apart when bolts break off, rotors sieze like they were welded to the hubs, and on and on.
add to this the flakes of crud that get past the safety glasses, and the detours by the emergency room when your tire iron slips and turns from a pry bar in tightening up fan belts to a forehead-gouger, and the wish-I-had-a-shade-tree wannabe-mechanic spends a lot of time cussing and whacking at things that don't disassemble.
it does get a lot better as you figure out what you are doing wrong over the years
I am absolutely stunned at how much easier modern disk brakes are to work on than compared to my 1970 Dodge Challenger, or even my 1979 VW Scirocco for that matter. Given the prices dealerships are charging for labor these days, and how much easier things seem to work on, maybe I should leave Data Processing, and get back into wrenching for a living. ;-)
Best Regards,
Shipo
fleetwoodsimca: thermostat replacement, 1999 Ranger 4.0L, .9 hrs (.7 hrs warranty). My book covers only up to 1999.
No thanks, besides, my wife hates the foul words that pour out of my mouth when something bad happens!
Not Included Operations
- disposal of hazardous materials
- diagnosis
- machining operations
- resetting of any electrical components due to battery disconnect
- removal of locking wheek nuts or wheel covers
- time necessary to free up parts frozen by rust or corrosion
- broken bolts, studs, etc
- excessive tar, undercoating, or grease removal
- cleaning areas of the vehicle which may have been contaminated by failure of the component on which the operation is being performed
- etc
- etc
The clock's running the whole time the vehicle's being worked on and somebody has to pay for that time.
The average professional mechanic/technician has probably 30,000 or more dollars just in his toolbox. Add the costs of hoists, diagnostic equipment, brake lathes etc, the costs are staggering!
Kinda makes the 75.00 per labor rate not look so bad.
Best Regards,
Shipo
"The clock's running the whole time the vehicle's being worked on and somebody has to pay for that time." You bet! No truer words were ever spoken! When the clock is running, I pay for the time, no matter if it is me or the other mechanic that is doing the work. I am more conscientious than the other guy toward my vehicles, but sometimes I get so busy with other things (or so lazy) that I'll trade money to not have to do the work myself.
And an afterthought: As cars have gotten very complicated, I have found that paying someone who has all the expensive equipment to do the more sophisticated jobs is a great idea!
Seriously, there are alot of variables that can and do affect how quickly a mechanic can do a repair.
I highly recommend to anyone who thinks mechanics are getting rich and making easy money to apprentice themselves to a good honest shop for two weeks and count what's left over once the overhead, government, mishaps and skinned knuckles have been accounted for.
I happen to think if a mechanic is able to overhaul a filthy, greasy differential in less than book time and do a quality job, good for him!
The next job he does may be a miserable one where he runs into big trouble in spite of his ability.
On that job, he might get paid for three hours but the job took five because things simply went wrong.
Yeah...everyone should try it!
(:oÞ
I wish the small auto shops could catch the same "incentives" as big business. I'd sign up for socialism right away. I'd like ot start with being able to write off my Mercedes repairs in order to encourage USA-EU trade exchange. And get some pollution credits on all those oily rags I'm disposing off properly.
sure different from when a short block slant-6 was $800 and the full job was $1200 or so back in 1973, but them's the times, and I don't think that ratio exactly follows the inflation curve, either.
Engine assembly, R&R & O/H
Includes: replace rings, main and rod bearings, crankshaft and camshaft, burnish cylinders, grind valves, adjust idle speed and timing
Does Not include fit pins or align rods
Montero
3.5L engine..... 37.0
Add
where air conditioning interferes... 1.0
where power steering interferes... .2
The only discrepancy I see is the sublet charge to the machine shop for the valve job. Should be included in the 37 hours.
http://www.jsc.nasa.gov/bu2/inflateCPI.html
Consumer Price Index (CPI) Cost:
Since 1973 the index is 4.015 times or $4900 pretty close.
You should try to rebuild a Q45 V8 engine, $7,800 would be the start and a premium job [to new factory specs] would be closer $10,000.
But then again exotics are $18-25K.
Here in salt country, I find it takes about 5.5 to six hours to do all four on a 4X4 including changing all three axel u-joints (change the inner right on the truck with the OTC ball joint press), while I can do all four on a two wheel drive way under 2 hours. The Ford dealers chage the customers 5.5 on customer pay jobs, but Ford pays less on warranty jobs.
Real Time Labor Guide (On disc) quoted the same times when it first came out, and I got a discount on the update for pointing that out.
Back in the mid seventies Chilton gave 1 hour to change a lower ball joint on a Chevrolet, but 2 hours on a Cadillac. It was the same amount of work.
In my shop I use labor guides for unfamiliar work, but set my own times on jobs I do every day. My prices are usually a little lower than the dealers, but substantially higher than Wally-World type places.
Harry
I have my friend's shop do a big 30K service on my car every two years and we find all kinds of little things wrong.
Ha! I just couldn't resist... (:oÞ
Skipping a major service to save money might have some merit in that some of the "services" may be inflated and meaningless but on the other hand you have foregone the opportunity to inspect the vehicle thoroughly.
I mean, how many times do you read on this board about "I was driving my new car with only 15K on it and suddenly it started to overheat. What a lemon!"
Welllllll, maybe, but maybe there was a coolant leak that was begging for attention as well.
I have been serching around the internet for the cost of joint/halfshaft replacement without luck. I have stumbled across a few sites that say the only noise a bad joint will make is the typical clicking noise.
Now my joints dont click. But when I do go over a speed bump or drive on a bumpy road the drivers side creaks. Should I just wait awhile till they start to click for replacement?
Now my second question is. Would it be cheaper to have the halfshafts done while I am having my clutch replaced or my timing belt replaced (which are due soon anyways) to save some labor?
Finally. Does anyone have an approximate cost of the entire halfshaft replacement cost?
Thanks a million for your help.
Half shaft R&R:
(90-99)
- left 1.1
- right 1.3
- both 2.2
Clutch R&R (which includes R&R half shafts):
(90-99)
- 4.2
Combinations
- clutch pilot bearing R&R .4
- flywheel R&R .3
- machine flywheel .8
Timing belt R&R:
(86-99)
- w/ A.C. 3.0
- w/o A.C. 2.8
Combinations
- camshaft sprocket (each) R&R .2
- camshaft seal (each) R&R .3
- crankshaft sprocket R&R .2
- timing belt tensioner R&R .1
- balance shaft belt R&R .2
I don't know if mechanics even break down CV joints and inspect them anymore.
Thanks again
