Toyota Sienna Care & Maintenance
try it and it's simply outstanding! wow!
i used it today on my van and the results were amazing! took me a total of 5hrs. to wash, dry, use the clay bar and then wax.
the product really works!
I am due to check, clean, and lube my brakes. My plan is to disassemble my front pads, inspect and clean them, use disc brake grease on the backs and shims, and reassemble, bleeding a bit of fluid. For the rear, I will open and vacuum them, and possibly bleed a little.
Does anyone have any additions? Any advice on "synthetic" brake fluid?
what i started to do recently was use a very fine sandpaper and lightly sand the shoes at the back to remove any dirt/junk on the shoes. i also lightly sand the drums. some brake shops do this to remove the glaze on the shoes.
http://www.tirekingdom.com/purch/brkfluid.html
By "synthetic," I meant Valvoline Synpower DOT 3/4 brake fluid. As the tirekingdom points out, DOT 5 is a synthetic-silicone formulation; I think the usage of the term synthetic is different here. Synpower fluid claims to be completely compatible w/ conventional fluids, and it does meet DOT 3, as required by my Sienna.
Has anyone changed out their PS fluid on their Sienna, and what technique did you use?
For newcomers, be aware that the owner manual and reservoir indicate Dexron II or III as a power steering fluid. Technicians at my dealer recommended using a power steering fluid.
thewolverine "Toyota Sienna Problems" Aug 13, 2002 7:27am
To drain, they say to loosen the plugs (not remove); use ethylene-glycol base coolant; and use distilled water, if diluting. Capacity is about 11 qts with a rear heater unit, 10 without.
Torques: Left-Hand drain plug 13 [N-m]; RH plug 7 [N-m].
Thanks in advance...
any help
give yourself about 30mins. to an hour to replace the rear plugs.
this is why dealers in my area want to charge over C$220 to replace the plugs on any sienna.
Thanks for the help.
i have to check my service manual when i get home tonight. i wonder if you are talking about the fuel rail.
visit this link and look at all the engine pictures (11th picture to be exact) and tell me which part is in the way.
on one of the pictures (11th picture), you will see the cowl with sticker on it, that whole piece needs to come off for u to get access to the rear bank. this is why i'm surprised it took you only 10 seconds to take that piece off!
At least the air filter wasn't too difficult!
My last three toyotas were so easy to do everything, I even replaced a water pump and radiator in a tercel.
The "cowl" is the black plastic that lines the rear of the engine compartment's top; where the wipers and brake reservior come thru. You will need to remove the cowl, along with, most likely, the intake manifold, to reach the right-side (rearward) plugs.
I'd recommend a repair manual!
Jeprox: is that engine cover a "mod," or is it pre-2001 OEM?
yes the piece i'm talking about is the black plastic piece (cowl) that runs along one side to the other. (the one with the sticker). yes, that whole piece needs to come off! i seem to recall that the wipers needs to come off before that piece can be removed! so you can just imagine how much work is involved to replace the 3 plugs in the back! if you don't remove the cowl, you won't have enough room to get in the back and under the manifold. the rear bank is very close to the firewall. from what i remember, you need not remove the manifold to get access to the plugs.
while you are back there working on the plugs, i recommend you to change your pcv valve as well since you're already back there!
PJKSR: i painted the plastic cover myself along with the air filter box, battery terminal cover and a few other things. i used ford blue high heat paint. don't know if you can see on the pictures but i also installed an invisible bug screen behind the grill.
However, I have found in my local public library, a "reference" Chilton's manual that has a section on the Sienna. Look for a large manual that covers Trucks and Vans; these manuals come out yearly and cover many auto-shop-type procedures.
the one i have is the oem repair manual for 1999 model.
gsafarz: i just looked at my manual and yes you have to remove ventilator louver and then the cowl. after you remove the wipers of course!
once everything is off - you will get good access to the plugs. u can try gaining access from the bottom, you may be able to get away with it.
goodluck
Does your 2000 require "Iridium" plugs like the 2002?
Well, I'm looking forward to changing my plugs in about 2 years. Like you said, it sounds like a job for a Saturday morning.
BTW, 18466, and anyone else, have you checked or had checked your valve clearances? I'm wondering how common it is for them to be out of spec...
Now, how much will they charge you, and will they just do a "drain and refill," or will they do a flush? IMO, a drain and refill is good enough; you can do it yourself for less than $10, using quality fluid (like Havoline) and a little effort; there's a discussion about this earlier. At any rate, changing ATF is cheap insurance for keeping that silky smooth tranny workin' right. And double-check your fluid level after anyone touches it.
There are other obvious things to change too, as I'm sure you're aware, including the air filter and pcv valve...
You may want to check early in this thread, because there's a procedure for draining the ATF, kindly posted by an owner who called Toyota on it. Upshot is that if you drain the differential and tranny drain, you'll get out much more than 2 1/2 qts; more like 5 1/5 or more. At any rate, even 2.5 @ 15k would freshen the fluid pretty well.
Reinstall the drain plug securely(NO TORQUE MENTIONED)
With engine OFF add new ATF thru the filler pipe. (3.7 qts)
Start engine and shift the shift leveler into all positions from P to L and back to P.
With engine idling, check the ATF. Add ATF up to the COOL level on the dipstick.
Check the fluid level at normal operating temperature, 158-176F and add as necessary.
DO NOT OVERFILL.
I got a Mitchell repair manual (mitchellrepair.com) on CD. So, there is a "generic service manual for Siennas...." My only note is that for my 1999 LE, there is not much info on the CD - I refer back to the 98 model year.
The drain bold is on the pan. You will also see a differential drain plug right near the pan, but I cannot remember its size. Mine took the 3.7 quarts of fluid as specified in the owner's manual to refill.
In regards to rear plug changing, you can get a tool from Snap-on that will get to the back plugs without removing the Cowl. I would not invest the $50 for the socket/u-joint combo since you only have to change these plugs every 60,000 miles. The Cowl and plenum takes about 15 minutes to remove. (The guy who said 10 seconds has obviously never removed each piece... and I have an air wrench to remove the screws quickly...)
Hope this is of help.
2. obviously, just draining thru the drain plug sounds easy. it has been about 25k miles since the last atf fluid change(it was at the dealer ship where they flushed thru the torque converter). so with the info you guys gave me i am thinking about dropping the pan since its been 25k miles. Now, when i drop the pan, do i need to replace the gasket??
3. when i clean the pan, what do you use to clean the pan? parts cleaner? brake cleaner? non residue spray?
4. Is there any filter that i should change?
5. is there a torque specification for the pan bolts?
I will check out the web site on the sienna manual!
Thank you for your input, it is a great help!!!
Dana
In your case, I would drop the pan. You will need a new gasket - around $8 I think. I think the torque spec for the pan is 70 ft. lbs, for the pan drain bolt is 36, and for the torque converter it is 30. I would have to check the manual to be sure, but I am 95% sure on that figure. Once you drop the pan, you will see a screen that has 3 screws. Remove each of these - be prepared for a pint of fluid to come out. Clean this screen with parts cleaner and then blow dry with air compressor or the like. You will want to check the fluid several times (over a few days) to make sure you have the fluid level correct. Mine did take the 3.7 quarts as specified in the manual. On another note, this transmission is not designed to have the fluid back flushed. I am really surprised the dealership provides this service. I know it is easy and a good moneymaker, but I would not have this done to my transmission.... Also, I bought the manual (on CD) off of Ebay for $30.
For Dana - the books says to change the timing belt at 90,000 miles. My guess is that you would be looking at a $600 repair item, but I have never had to have this done (yet).
For Isac, I would torque the bolts down to 70 ft. lbs. to see if that takes care of the leaking gasket. Otherwise, it is not a big job to replace the gasket. ATF fluid is something to check monthly.
Hope this is of help to each of you.
Cheers
For jtlanejr, thanks for your advice.
You are smart in having the van inspected. My only concern would be the previous owner's lack of oil changes, etc. We all know of the "sludge" problem these engines develop with lack of maintenance. The mechanic that is inspecting it could pull a valve cover and check for signs of poor maintenance. I am convinced that if you regularly change your oil and keep up with scheduled maintenance you will not have any problems with this van. Mine has 66,000 miles on it and I have a T100 with 125,000. I have only put a starter on the truck. OEM parts and scheduled service will yield good results (at least that is what I am betting on...)
My road test was ok. I bought 4 qt Sears brand Dextron II/III fluid for $1.19 each. Sound good.
