Thank you in advance!
I just pulled my front tires off, and I noticed that the wheel studs are seperate from the rotor/hub assembly. What I mean is, there is a small amount of play between the wheel studs and the rotor. I'm not sure if this is normal, because it seems to me that the holes in the rotor where the wheel studs go through would tend to stretch out over time. Both of my front rotors are like this. Does anyone know if this is normal?
Noticed the oil change interval at 5k/7.5k miles.
I am a long-time oil change fanatic (helps keep those engines running smoothly!). I've also seen these stories of people keeping Previas running for ages (and that's my goal w/ Sienna).
When would you do the first oil change in the Sienna? I was thinking 2000 miles for the initial change, going w/ full Synthetic oil (5w30) for use all the time. All additional changes coming at 5k mile intervals.
Also, can you get aftermarket filters for the 04 Sienna? I have always used Fram filters, with great results, but I didn't see any available. Are you all just using Toyota filters?
Thx
I have a 2001 Sienna LE with 36,400+ miles. I do my own oil changes like you. I get the filter for $3.49 at the dealer(when on sale). So I stock up. I mainly do this because the power train warrwanty goes up to 60,000 mile. Just playing it safe and $3.49 is a good price. The job is a snap. I always use standard oil in my car's and change at 3000 miles.
I would do the first oil change at 500 mile's. Then stay with standard oil for a year or 10,000 miles and then switch to synthetic. 5,000 miles sounds good after that as long as you do daily driving at highway speed for at least twenty minutes. If you do a lot of short trips like us you may want to adjust that 5,000.
Good luck with your new car.
Thx for the advice
Not hard to do overall. The filter position is a little clumsy, but I may try a different wrench for the filter next time. I used one of the offset wrenches that wraps around the filter and compresses. I think the type that is more like a giant "socket wrench" might work better.
Definitely liked the little piece of metal that helps channel the oil down into the drain pan from the filter. That is a nice touch.
Good luck!
I also have a 87 camry that goes in every 3 months with less than 3000kms on. Very cheap insurance i might add.
There was a lengthy discussion of oil changes under Toyota Sienna 2004+ just recently.
Personally, I think changing the oil after 350 miles is overkill. When I did my first oil change at nearly 2000 miles, the oil looked great - still nice & amber, no signs of metal shavings (there HAS to have been some, must have been captured by the filter). I would guess that you could easily push the first change out to 3000 miles.
Paul
Yes, you might get "lucky" and "make out" on running into extensive & expensive repairs, but chances are greater that the dealer will take you to the cleaners.
Save the added expense from the additional warrantee and put it towards real repairs (and, better yet, preventative maintenance).
I guess we should be thankful that Toyota didn't put it just above the exhaust manifold or some other worse position.
Overall, I found it not bad. No annoying plastic shielding that has to be removed (like 99 VW Passat and 93 Volvo 245 wagon). The position of the filter is a little clumsy for normal filter wrenches. So, I bought a cup wrench to help out... Actually looking forward to the next oil change to try it out.
One little tidbit I also tried - someone else recommended using a plastic bag as you screw off the filter - let the oil pour into the bag. Worked really well on the Passat, marginal help on the Sienna.
Just my opinion...but repeated oil soaking of the engine mount rubber cover (in the area below the filter) is not a good thing.
2004 Toyota Sienna XLE
1996 Volvo 850 GLT
1991 Toyota Extended Cab 4x4
I bought the shop manual with the same general intentions (doing _some_ of the work myself).
They can be ordered through the parts dept at the dealer, but it will take (much) longer to get. The books are expensive (roughly $250-$270 for both). You have to get both. The first is diagnostics and preparation (this is the one I got). The second is the actual procedure. Haven't bought that one yet (but I intend to).
Little things like the oil change don't require a manual. Really easy...
I don't know how serious you intend to get with the repairs. From the looks of it, I intend to let Toyota do the spark plug replacement (3 easy, 3 hard).
That same day, a customer service manager called me to ask me what the problem was, I asked her why I didn't get the Red coolant and if the green coolant was silicate-free. She went to ask the service advisors, and when the customer service mgr. came back she said they would change my coolant to the red type free of charge if it would make me feel better. Note that there is no admission of guilt nor answer to my silicate question. Needless to say, I'm scheduled to have my coolant changed. Most likely, it will be the last time I visit that dealership.
I'm not here to slam any dealership but if anyone wants to know, it's located in Tustin, CA. Consumer beware!!!
I'm just a bit further south in San Clemente, and have completely eliminated Family Toyota from my service calls for two Toyotas we own. The last straw was their "estimate" on "needed" maintenence amounting to several thousand dollars. I took same vehicle to Carlsbad Toyota and they gave me an optional maintenence suggestion amounting to 125 Bucks. I found Family Toyota to routinely try to encourage rather needless service on several occasions prior to writing service manager and telling him that his operation was merely churning customers.
Ya gotta watch some of these cowboys...
Any info would be helpful.
I drop the pan and clean the screen every 30,000 miles. The screen is completely metal, so you just have to clean it. After the pan is dropped I will normally drain and fill at least twice, sometimes 3 times to change up to 88% of the fluid. Cost: $14 for fluid and $8 for a pan gasket. I have also found that it is worthwhile to change the pan and differential washer. Mine will tend to leak if I reuse it several times.
Every 15,000 miles, I drain and fill the fluid twice. This changes 75% of the fluid and costs me $9 and a little time. This is probably overkill, but it is my money and my time, and I know that it will not hurt anything.
Probably the 30,000 pan interval is best for most drivers. If you tow a lot, the I would drop the pan more often.
Have any of you replaced the standard toyota filter with the high performance K&N air filter?
I never notice it during subsequent start ups. Could this be a problem area?
