2 New Transmissions for my 2001 Acura TL - Help
the reason for the honda failures is simple, the auto tranny is simply a manual tranny with a set of clutch packs and servos added, each gear shift once off the showroom floor, clashes gears and knocks off metal, which circulates and imbeds in the clutch pack seals, inviting failure.
PS - this website also said recent Preludes had a 25% tranny failure rate.....?
Krzys
And yeah, the Galant thing - at least the Galant was running/driving, huh?
My friend has a BMW 3-series with sportshift and has gone through 2 transmissions already as well. I have no doubt that his driving style and poor shifting skills are to blame.
My brother owns a 2001 TL and it runs perfect.
even if the drivers damage the tranny by using SS, it is still Acura's fault for designing it so badly that it would allow itself to be damaged.
In general though, there are plenty of people who baby their car, don't drive it hard, don't use SS, and the tranny still failed on them.
Go check the http://www.acura-tl.com and http://www.acura-cl.com forums. The CL board even has a separate forum dedicated to tranny failures.
P.S. my TL-S' tranny failed at 6,100 miles.
And if it is the case - then it is a bad design.
Well, i told myself that it was a fluke and purchased an 03 TL which my wife now drives. Now it is starting to show the same symptoms that the 99 did. Looks like things haven't changed. I am keeping my fingers crossed that this transmission will be ok, but it doesn't make me feel good when my pregnant wife is driving around in a time bomb. When that transmission goes out you feel like you're gonna die for sure! I had a string of cars behind me on a busy highway and when I suddenly dropped from 65 mph to 30mph or less they all almost rear ended me. Sure was an experience, not to mention the whiplash I got from the dozen or more lurches it made.
Anyone out there looking to get a TL, don't do it! Buying one is like gambling in a casino. Will yours have this same problem? Ask yourself, do you feel lucky today punk!
http://www.petitiononline.com/mod_perl/signed.cgi?acura
http://www.acuraworld.com/forums/showthread.php?s=&threadid=2- 4415
Here are a couple of links about the tranny problem. One is the announcement of the extended warranty offered to only some of the affected customers. The other link is an online petition. The last link is about the law suit that is underway now as we speak. If you are having problems, you should get involved so that Honda realizes their mistake and makes it right.
