Oddly enough my previous car needed to be topped off several times to get it to full. The Subie doesn't.
-juice
If this keeps happening and you're tightening the cap all the way, then something is wrong with the vapor system (could be the cap, among other things) or something else is causing the malfunction indicator light. Your dealer could tell you what the code is.
Good luck!
-Colin
In my Chevy Z71, I could top off a whole 1/2 gallon. I don't top off in our Subie or our Saturn, only go to the nearest nickel though.
-Brian
Ken
Steve
Father-in-law swore by it, I've not had very good luck with it - but one of those bad experiences was a '71 Vega... need I say more?
We're a Castrol family here... 5w30 in the Sube & Villager, 10w40 in the ol' Dodge & motorhome. Never had an oil-related problem.
Dealer here uses Sunoco product... akin to Kendall? I do my own changes, so that's a moot point.
Cheers!
Paul
-juice
Or for Mercedes?
Sorry, Ross....
Cheers!
Paul
What's the deal withthe splash gaurd? I'm doing my first oil change on the Forester and there's the little plastic joints at the top that allow it to rotate down once the bolts are removed but do these joint things come undone or do you have to work around the whole thing to get to the oil filter? aaaagggghhhhhhh!!!
Help me please!
thanks,
Kurt
Remove these 6 and the cover pops right off.
Or do what I did - get tin snips and cut a hole for access. :-)
-juice
So how has that homemade access hole been working for you? Does the area around the filter get dirty?
Ken
Kurt
HC STANDARD 100 Actual 7
CO%STANDARD.50 Actual .07
CO2% Actual 15.4%
RPM 2390
Thanks to everyone who responded.
Jon
Bob
I'm very happy with a set of TriCo silicone blade inserts. I got them at Advance Auto Parts, if you don't have that chain near you just head into what you've got and look around. The driver's side wiper is considerably longer than the passenger's.
-Colin
then the OB has to go in!! Ouch.
-mike
You ought to bring Q over and we'll BBQ and service the cars. I bet Tati would love to hear you guys play some tunes, too. If you're interested e-mail me.
-juice
Bob
-juice
-Brian
What do you use to poke a hole in the oil filter?
Ken
-Colin
-juice
I just hate how the oil comes cascading down the sides of the filter. My wife's Jetta has a neat little screw at the bottom of the oil filter housing that you undo first to drain it.
Ken
-juice
Greg
Wait - you have an Outback, right? The cover doesn't apply, so you have more room to work.
-juice
Greg
-mike
mySubaru.com is neat and all, but holy smokes that was half a paycheck for brake fluid, an air filter and a fuel filter!
Air filter and fuel filter we could knock out easily. I'd add PCV valve, coolant drain and refill, and oil change (if needed), plus tire rotation. Maybe plugs.
Heather: I'd get a 2nd opinion. Maybe even call over the phone to save time, see if another dealer or shop can do just the glass.
-juice
-Colin
Ken
-Brian
Chuck
YetAnotherExcuseToBuyMoreTools
Ken
If you mix 87 octane gas with equal parts of 92 octane gas, would the results be considered 89.5?
Is mixing octanes necessarily a bad thing?
You are on the right track. Mixing equal parts of two grades will result in a octane rating somewhere in the middle.
No, mixing octanes is not "necessarily a bad thing". It's just a waste of money if your car performs well, as-designed, on the lower octane fuel.
Three questions (sorry about the long post):
1) I know there has been some discussion about clutch chatter on Subaru's. The clutch on my '01 Forester has always had some chatter since new, noticeable mainly when first staring out on a cold day. Lately, it seems to be getting worse. I've driven manual tranny cars for nearly thirty years now, and never had one this new with this condition (my car now has about 24 K miles). I've had it checked out on two separate occasions during service at Flemington Subaru, but of course, it wouldn't do it for the mechanic, since it was well warmed up at the time it was checked. I'm bringing it in again tomrrow and leaving it over night, so hopefully they will be able to confirm that there is a problem and do whatever it takes to get it right. Does anyone know what generally is the cause of clutch chatter in these cars? I mean, it appears to happen frquently enough, judging from these boards, that there is some type of common cause. I seem to recall someone suggesting weak springs in the pressure plate.
2) Anyone have any experience with the service departments at Bill Kolb Subaru in Orangeburg, NY and/or Freehold Subaru, in Freehold, NJ? (One is near work, and the other is near home.)Flemington Subaru seems pretty good, and I know it's been highly recommended here, but it is quite a haul for me.
3) I've been away from the computer for a while, due to a recent move, and I see Juice has gotten another Subaru? What did you get, the '03 Forester for the wife? Just curious!
Thanks in advance,
Len
Bill Kolb Jr. Subaru in Orangeburg, NY has been servicing my 1996 Legacy for a few years. I recommend their service department highly. They don't split their time between several brands, as it's a single-brand store.
In fact I'm picking up my 2002 Legacy GT Limited sedan there Tuesday afternoon.
-mike
