Faye: I'd suspect a loose harness. I kind of doubt the speakers are on a seperate fuse, but check that just in case.
The Forester's radio is very easy to access, much more so than the Legacy's. If you feel up to doing it yourself, let me know and I'll try to find some pics.
-juice
Christine: sounds like you've had more than your share of problems. But I'll tell you...our 626 has a lot more costly problems by that mileage, so it could be worse.
The seat heater failure is rare, maybe the first I've heard of that. The O-ring seal failure on the oil pump is not exactly common, but I've seen it. Bulbs blow, that's normal for any brand. I'm sure Sylvania or some other company makes them universally, for several manufacturers. Window seals were replaced - their angle can be adjusted. See if that repair is warranteed.
Larry: thanks for the update.
-juice
I tried everything I could think of to no avail, and I finally called the service dept. and they told me that this was a fairly common problem with Subarus for some reason and that if I brought it by, they'd fix it. I'll probably do that since I only have 700 miles on my car and don't want to risk breaking something this early (I'm a novice with car work at best), but I figured you guys would want to know and I'm interested to hear what you have to say.
Any ideas? I think that if I was able to remove the hard plastic casing on the back door under the window, I could probably get to those plastic housings from that side.
I still can't believe I ran into this problem.
-Dennis
yes, I had a very nice experience over the last couple of days. You wouldn't believe it, but that very morning when we woke up with the snow and icy streets, I got up a half an hour earlier, just to take a car for a spin out there before going to work. On streets, I couldn't tell there were anything troubling. ABS didn't go off because I was soft on brakes. Actually, I figured out how bad it was only after I took my small FWD car to work (wife gets to drive Forester ). Then, I took it to the empty parking lot and started pushing it until I brought it into a skid. It was a plain ice sheet covered with 10 cm of snow. Acceleration - no problem. ABS kicks in all the time with the feeling that would be best described as a plastic gear where teeth are constantly breaking under the pressure of one's foot. I can't tell I was impressed with the stopping distance, but I was able to steer all the time. I liked the fact that after being brought into a skid, car was easy to bring back under control. Didn't feel any shifting of torque between front and real wheels or jerkiness often described by CRV owners. Over all, I was impressed with its snow/ice handling ability and a little concerned how fast I had to go to feel I'm in (controlled) trouble. There's no way I would ever, under the circumstances, go that fast in my other car. Forester successfully masks bad driving conditions, so that can cause a problems if one isn't careful.
Over couple of days, I tried to push it a little on the streets, just to get comfortable with the car before real winter starts (FYI - real winter in Canada means 50 cm of snow, -20 most of the time, black ice on highways and on top of that everybody drives like it's summer time because everybody had it enough and nobody cares any more ). It's my impression that, when pushed too fast into a turn or sharp curve, car initially under steers, then over steers and finally gets it right. But it is controlled all the time and easily corrected with only slight move of steering wheel without taking a foot from the gas pedal. And once used to it, it's very predictable.
I'll post more, once real thing kicks in.
K
If it were me, I'd yank it out with pliers, then get a slightly fatter self-tapping screw to replace it.
But go to your dealer, yours is so new.
-juice
I then let it sit for ten minutes, and it started up and ran fine.
Subaru tech guy told me Foresters need 89 octane to run right.. I've never used anything but 87 octane and never had a problem til this one instance of leaving the car sit for a day. Have always bought gas at this same place.
Thoughts?
From your description, I'm guessing your last fill-up might have included a small amount of water in the gas. By any chance was the last service station a low-volume seller?
Try putting an inexpensive can of gas-line anti-freeze into your fuel tank. It is mainly alcohol, which binds with any water in the bottom of your fuel tank so that the engine can eliminate it. It also lowers the freezing point of the water so that it can't freeze in the fuel line, leaving you stranded.
I'm not big on additives, but I typically run a can of gas-line antifreeze through my cars about once every other year.
I will have to admit it beats putting the isoheet in the tank in winter!
I think there were a bunch of post here about fuels awhile ago. We do have some fuel experts here at Edmunds that were very helpful in explaining all of this.
Patti
Another thing is have your battery inspected. At a minimum check the fluid level and top off with distilled water.
-juice
I need the experience of the crew to diagnose a possible problem. my 98L started to make a whirling noise when I take a left hand turn at speed or a curve that lean the car to the right. The noise only occurs if the car is leaned toward the passenger side, once I come out of the curve the whirling noise is gone. I had the bearings replaced not more than 10K miles ago, I don't know if they have gone bad all over again or if its something else.
Any help is appreciated.
Thank you in advance
Mike
Do a quick visual inspection of the right side suspension. Check the boots, look for leaking grease. While you're at it, spray some lithium grease on the sway bar bushings, those can squeek.
Maybe the shocks are due for replacement.
-juice
Why do you use distilled water? Does it make a difference if you use regular tap water? If it does, I will start using distilled water instead.
Larry
So, not power steering? Wheel bearing - but sounds like metal scraping on a rotor? Happens when not braking.
Anyone with similar experience???
Thanks in advance,
Ralph
Owen
99 cents at Wal Mart or Target.
Ralph: debris in the brakes? Though a wheel bearing can make a scrunching sound, our 626's did when it was failing.
grugru: check the lug nut torque. Though if it's warped it may already be too late.
-juice
New rotors at a dealer can add up, $400-500 is my SWAG.
-juice
Patti
-Colin
-juice
Faye
Any how, you start under the arm rest, two screws come off and then the center console tilts up and out. Move forward, do the shift surround. That leaves room for the center console to come out.
It's not hard, just don't use too much force so the interior doesn't crack.
-juice
-juice
I bought a 2004 Impreza TS Wagon 2 days ago. It has 48 kilometers on it. I parked the car in front of my house last night, about 24 hours ago, and did not get back into it until now. It won't start. It turns over, but then won't catch. I am in Edmonton, Alberta, and it is cold. It is -15 celsius, which is probably around 5 degrees or so farenheit.
I can't call the dealer until tomorrow morning.
Does anyone have a clue as to why this would happen?
I'll be having a good stiff drink while waiting for messages.
Anniedee
Or, plug it in overnight and try again tomorrow morning, you might just get lucky. Make sure all the accessories are off.
BTW, where did you get it from?
K
RT
that's an old topic, you'll hear a lots of opposing opinions. Generally, there's no need for long warm-ups. Definitely, not until temp gauge moves. Unless you get -20c or -30c (highly doubtful it in NJ), you'll be OK with just running it for a 15-20 seconds.
What I usually do is start a car and then go around and scrape the windows. It gives it a plenty of time to warm up properly (and I get my morning workout and warm-up too).
K
Greg
Greg
But wow, on the first tank! You could try DryGas.
Also, let the fuel pump prime before you crank it. Turn the key to the on position and listen for the whirr the pump makes, only then try to start her.
A block heater might be a good option if you encounter those temps frequently.
-juice
Oh and for this--
quote: I'll be having a good stiff drink while waiting for messages.
I suggest Crown Royal, eh. Always keep it on hand for such emergencies. Well OK maybe general purpose use too.
-Colin
Jon
-juice
-Dan-
-juice
Overtorquing led to deformation of the bearing housing and premature failure of the part. Even if torqued properly, the old design bearing still has a propensity to fail. Try to get your service department to use the Legacy rear bearing. I once posted the parts numbers for these but don't have them handy.
On the plus side, my experiences introduced me to the famous Patti (a/k/a subaru_team on this board) and a great customer service relationship with SoA.
Hope this helps.
Ed (edit: need spell checker or at least more coffee)
Greg
So now I know not to in the Subaru.
All is fine.
It came from Rally Subaru in Edmonton.
(and my drink of choice is a nice single malt)
Annie
Jim
Chuck
Patti
Well, I came up with the brilliant idea of "hooking" the front (and only) tire of my wheelbarrow up and over one of the rafters. Worked great for months, and nobody is confessing to bumping it, but it either did get bumped, or I hooked it a fraction of an inch too little. I came out to find my hood and driver's side front fender dented nicely. The handle also put a 50 cent piece sized hole in our jogging stroller. Uhg. The wheelbarrow is now secured to the wall, far away from the cars.
Jim
Jim
