-juice
You remove the resevior, disconnect the steel brake lines from the old mc, remove the old mc, install the new mc, reconnect the brake lines, re-attach the resevior, fill with brake fluid, bleed all the wheels (usually from farthest to nearest, i.e. RR, LR, RF, LF.). After EACH wheel, refill the resevior. It may take a while to get all the old fluid & air out of the lines.
Check for leaks, test the brakes and check for leaks again.
I've never rebuilt calipers or wheel cylinders, so you'll have to use juice's pix for help there.
HTH,
Jim
My bad.
-juice
Steve
-Bryan
Also, my idle is not smooth. It seems to shudder a bit at stoplights, the tach dropping the slightest amount. Is this typical? I'm still in my break in period. 200 miles so far.
And lastly, when i engage the clutch and shift i've got another faint almost whining noise. This is all alarming because honestly, my mitsubishi eclipse shifted smoothly, had a very smooth clutch throw, and only made noises like these when it was on its last legs.
Is this just paranoia talking? First new car and all. I apologize for the long-winded post.
It does feel different, but I'm used to it and I like it. My Miata is soul-less in comparison.
Mitsu was the first to come out with counter-rotating balance shafts, in fact they own the patent. It makes an in-line four smooth, but you also have a lot of excess rotating mass.
A boxer has inherent second-order balance so no balance shafts are used.
-juice
It was great to talk to you at the chat last Thursday. My first Subaru was a 92 Loyale 5 speed 4wd wagon. Good luck! Rob M.
Also, 200 miles is peanuts -- take more time to get used to the car.
Craig
cheers.
What does this mean?
Sounds like something that kicks in after a boxer takes a straight rite to the head
Craig
Any thoughts who would have good winter wiper blades at a reasonable cost.
For premium I just paid $2.09.
Highly doubt any damage, but it does seem to indicate some deposit formation on either the valve stems or within the chamber. These can impact proper injection charge mixing (on valves), a slight change in compression ratio or the creation of 'hot spots' (within the combustion chamber). You might try a bottle or two of a concentrated solvent cleaner like Techron.
The knock sensor (timing retard) can help to mask some of these issues, but eventually the situation gets beyond the limits of the electronics to cope.
An AG, eh? So if I give the wrong answer, do you prosecute? Or am I covered under 'Good Sam' statutes?
Steve
Have fun!
-Dan-
Problem is, the whole thing is too stiff, so it does not go around the curves near the edges well. So I don't recommend them. Normal ones I've used in the past were better.
-juice
Thing is, the horizontally opposed cylinders are slightly offset, obviously, so it's not vibration-free, but it's a whole lot better than an in-line 4 banger of the same size would be without balance shafts!
-juice
Pep Boys px: $10.99 for the 24" blade; $7.99 for the 18" blade.
Mark
There is no mechanical hinge device on the blade so it is unaffected ny snow and ice.
Cheers Pat.
Now, I've got another issue. The digital clock takes a few minutes to actually come on when I start the car. Then today, it went on and then less than 3 minutes later went off. Is this an early sign of battery trouble?
Joel
The cashier at Auto Zone gave me a funny look when I went to the register with an 18, 20, 22 and 24 inch blade!
~Colin
-juice
www.canadiantire.ca
Copy and paste this URL on your browser, type in Reflex for a keyword and scroll down to reflex wiper blades.
Cheers Pat.
Looks too narrow to get a lot of snow off the windshield. You'd have to clear it first.
That low-profile is probably better for light rain.
-juice
Cheers Pat.
Cheers Pat.
done with that for now as I'm in a different division at the company. I'm 'centralized IT' again instead of being attached specifically to our oil company. I might work on the Georgia-Pacific acquisition and early next year I'll be going to London to do some things for our trading office there.
~Colin
-juice
but no, I don't plan to stick around to retire out of this place anyhow. I think I'll leave Kansas at some point.
~Colin
I hear ya. When my status changed from Consultant to Regular Staff I was actually able to cash in my leave, got 22 days' worth of extra pay. That was nice, like an extra paycheck or two. Only gave up my accumulated sick leave (which I rarely use anyway).
Haven't had a car loan since.
-juice
The digital clock failing is a common Gen1 Forester problem. Mine went kaput a few years ago, I replaced it with a salvage yard special. I believe the problem has been isolated to a poor solder joint on some resistor, which apparently can be fixed pretty easily if you're handy with a soldering iron. I wouldn't think that it is indicative of a battery problem. Hope this helps.
Owen
Owen
Cheers Pat.
When I was in Calgary I never had a rental car because we stayed in the Hyatt and worked in the Petro Canada towers which were 2 blocks away. I know downtown Calgary and Banker's Mall reasonably well because I just walked everywhere. Unfortunately even with the frequency of my trips, I missed Stampede by a week. I couldn't help that one; I wasn't going to go during Independence Day holiday here in the States and the following week my Calgary IT contact was on honeymoon so I waited for him to return before making a trip.
~Colin
