-juice
prlady1, "Talk to the Press" #1017, 4 May 2006 2:55 pm
Ken
It's more likely that you have some plugging issues in the passages and radiator. Give it a good flush. Also check the fins on the radiator for bugs and leaves. Another decent possibility is that the thermostat is not opening all the way. But, take care of this problem ASAP because these alloy block and heads won't tolerate overheating.
John
My mechanic replaced the water pump and thermostat at the 105k timing belt change.
You can check 1stsubaruparts.com for parts prices, both list and their discounted cost. (One of my local dealers charges 10% ABOVE list!)
Jim
Jim
I have to unlatch the driver's side door of my '93 Subaru Legacy Wagon from another door in order to get in. I un hooked the activating bar inside the door when I tried to unlock it with a wire coat hanger. I took the door pannel off and was able to see that the outside handle lifts up and pushes a bar down which, in turn, pushes the lever down to unlatch teh door. It seems that the top part has become detached and the bottom part is in the correct positioni. I can not see or feel where the top has to be reconnected. I think I need to take teh door apart even further, but I do not know how to do it. I am thinking that a diagram would help so I do not have to pay a dealer to fix it.
Rocky
Nice to see our post here where you should get a good range of answers.
Rather than trying to dismantle the door further, why not remove the inner trim from the opposite side door and check out what the mirror image arrangement looks and feels like. Typically, door problems are loose clips or similar and checking against a working door should give you an idea of where everything should fit.
Cheers
Graham
A squirrel would have done worse, so I think it may have been a mole?
This is the 3rd time I've heard of this, did Subaru baste the wires with au jus sauce or something? LOL
-juice
:mad:
-juice
Actually, I have a squirrel (or maybe a group) that has taken to stealing insulation from my storage shed. I couldn't figure what they were doing with it all, but a couple weeks ago we found the fruits of their labor.......
A CONDO! in the tree! I swear this thing must be about 2' in diameter.... it completely envelops the stem of the spruce in which it is positioned. It is made up of twigs, grasses, and, primarily, insulation. Hahah... quite a sight. Some friends suggested I get a cat to deal with them and that might be a good idea! I could get 3 or 4 of them and just set them loose. Come winter they'd freeze, but hey, if I got them from the animal shelter I'd be doing a public service and the cats would be doing a public service as well! I am just concerned that they might try going after my rabbits instead of the squirrels...
Rocky
rpersico@mhcable.com
You might check your local library for a Haynes service manual. The illustrations in the factory manuals are quite obscure.
Jim
-juice
Juice - I am somewhat allergic myself (though it goes away after a few days of becoming accustomed), but I doubt it would be a problem if the cats never set foot inside the house.
I thought it was just some bug guts, but as I looked very closely, there are two spots(about as big as U.S. nickels) where the paint is beginning to break down. I showed the dealer, and they agreed to fix them at no cost to me. The dealer suggested to repaint a door on the driver's side and a fender on the passenger side.
How successful do you think the paint will be to match? It is Garnet Red. The dealer says it will be a perfect match. . .
Is repainting the entire door and fender better than just repainting the two small spots? A friend suggested that if the colors do not match exactly to ask the dealer to repaint the entire car. Suggestions??
I just put some on a small cloth and used it as if it were very fine rubbing compound or steel wool, turning the cloth as needed and re-wetting with the polish, then finished with a clean, dry cloth. Repeat until any haze, scratches, and pitting disappear.
I'm still trying to understand the physics of a surface that seems only slightly scratched and pitted, which nonethless scatters a major fraction of the light out of the beam. You could see the bulb and stuff inside rather clearly beforehand, but of course it was much clearer afterward.
Stanton
We have had a 25+ year running joke between my wife and I about 'fuzzy metal'. It stems from a 1978 summer job while in college, which in part involved running an electron microscope in a semiconductor lab. At a mere 10,000x magnification, 'mirror smooth' metal surfaces look more like the wooly blanket on your bed! A surprisingly large amount of light is scattered about in all directions when exiting a plastic lens with this kind of surface.
Steve
-juice
But by 40k, the rubber is drying out and starting to crack anyway.
As for the spare, it's really only for temporary use only, 50 miles max I believe.
Forester up until 2005 had a full size spare, but Subaru uses donuts for everything else. I wish they didn't, but the whole industry is moving in that direction, to save weight and space.
-juice
As you saw, any surface, no matter how smooth it appears, can be seen as rough if we magnify it enough. In your electron microscope case, you used an electron beam, with wavelengths far smaller than those of visible light, so new roughnesses showed up. But in my headlight case, the wavelengths are the same: visible light, 400-700Nm. My puzzle is this: if the "scratched" lenses were rough enough to scatter a mjor part of the light out of the beam, why did they appear "clear" when looking inward at the bulb and internal facets in the reflector, etc? I can only conjecture that the human eye (brain) interprets ("sees") the lens as clear as long as the image of the internal parts is sharp enough for the brain to accept. That may be the key: as long as the image is visually "sharp", the eye sees the lens as clear, even though much of the light may be scattered
Not very well-stated, and VERY far afield for this forum, but...
Stanton
John
I finally broke down and went to the local dealer. I really lucked out by going as the service department was opening up. the service manager started to tell me what I had to do to get at it. it involved taking the window apart which looked and sounded like a nightmare. the next thing I knew, he walked away with out a word and came back with a long screw driver and some other tool that looked like a very large dental probe. he reached into the exposed door had me hold the handle up and viola!! He fixed it without taking anything else apart and did not charge me a penny. With his experience and apparent eyes on his finger tips, he was able to put it back where it belonged. I learned a little bit about car door anatomy, but more importantly I know how not to open the door if I ever lock the keys in the car again.
gldnhrt: what if you replace the canister? How much does a new one cost? It could be cracked and have an air leak or something.
-juice
I have a 1998 Imreza L with the 2.2L engine. I was wondering how many miles I can reasonably expect to get out of this engine and drive train. It's been well maintained with the oil being changed every 3k-4k miles since day one, and the belts have been replaced at the suggested intervals. It currently has 127k miles on the engine and seems to be going strong. I've read stories of Subarus exceeeding 200k miles but I am not sure if these are true or just marketing hype. What do you think?
TIA
If it ever got real hot, there could be potential engine trouble.
If it has been thrashed, it may not last much longer.
You can always do an oil sample and have them check for engine conditions.
John
In terms of tires, if there is more than 1/4" difference in circumference (about 2-3/10ths tread depth) you can shave the new tire down to where the old tires are. The only people I have heard of doing this are Tire Rack and some performance stores. If your tires are around 4/10s, it is about time to replace them anyway.
My question is, does this sound about right, and also, where is the best place to get a good boost controller. I do not care if it is Subaru or aftermarket. I am in SoCal.
Also, any comments or suggestions would be appreciated.
if that's even close to true let's have some more detail about what was done the first time and how long it was before the problem came back.
____
however, to strictly answer your question, I would use a stock boost control solenoid if you want it to behave just as it did when new. if you use anything else there could be some tuning involved which could be fun, sure, but it also could make your car more of a hassle than it has been thus far.
money-no-object, I'd use an Apex'i AVC-R electronic boost control unit.
~Colin
In the case of the electron microscope, the resolving power is based on how 'bright' the beam is (pico/nano amperes), the accelerating voltage & landing energy (kV - effects depth of penetration of the primary electron beam and how large an excitation volume), the spot size (related to electromagnetic lens, apertures, working distance), and detector efficiency plus video chain. Today we can produce million X images and achieve single nanometer resolution, but not because we have fundamentally changed the nature of the electrons, just how well we can control their travel & divergance.
You are correct, in that white light is in the 400-700 nanometer range. That creates our resolving limitation with white light optics, and why we rely so heavily on electron microscopy to see sub-micron stuff. Half lamda rule of thumb says that you are just not going to see features below a quarter micron (250 nanometers) with white light. That is why 'printing' illumination has gone to deep uV. But by the same token, a surface roughness on the same order of the wavelength of light will scatter that light to some significant degree. So a surface that looks fuzzy at 10,000x is displaying a surface roughness on the order of a half micron or more. If that were a transmission surface (lens), I believe you would get scattering.
And now back to our regularly scheduled programming!
Steve
- Jason - Funny think is that I really do not notice a difference between the boost controller and not. The car seems to not be as neck-breaking as before though. It still accelerates well, just not as well as before.
I am guessing it might be a combo of both?
- Colin, considering this car is mainly used to make my commutes more fun (in SoCal you have to drive a good distance to get to anywhere!!!), I would lean more towards less hassel vs. performance. If the aftermarket units like the Gready (sp???) or other units are capable of similiar reliability, with little to no tinkering, after professional install, then I would strongly consider those units, if it will require much more tinkering on my part, I would rather just stick with the stock unit.
Thank you again for your responses. One of the reason I love this forum
Colin - one other note, how is the Evo doing? I remeber you loving it with the cruise control installed, but for commuting, the ride was starting to take its toll.
- Kevin
Now I don't really know what the surface of your lens looks like, so this may or may not be the case. But if it were to look 'wolly' at 10kx as viewed in a SEM, it is exibiting a surface roughness on the order of a micron or so. That would have some scatter effect on white light.
The other possiblity is that the surface might be both rough from impacts, as well as oxidized. A plastic surface (hydrocarbon) can combine with air to form a new material. The material 'interface' can cause scattering, and the new material can have a transmission difference, resulting in absorption of light. Illumination becomes heat. Heat promotes more oxidation....
It sounds like you still don't have a solid diagnosis on what's up with your WRX. I'd find some locals to you on Nasioc.com or I-Club.com and go to a dealership or independent servicer that they recommend. At 82k miles your WRX isn't a new vehicle anymore but I would still be a bit surprised if the boost solenoid, wastegate, or something like that had failed.
~Colin
The car ran fine before I changed the lines! Drove the car up on ramps, changed the lines. Engine turns over but wont keep running. Fuel pump comes on. Gas is going to the engine, only trickles. Car will keep running for 15 seconds when spray in starting fluid. Is the fuel system pressurized? If so, how do I pressurize it? I have tried - turning engine over until the battery dies. No signal lights come on in the dash. All the regular lights come on...check engine, oil, door open...like when normally starting it. With the price of gas now :mad: , I cant afford to drive the 1987 Dodge Ram for too long! Please help!
If your lines were rusted, what do you think is going on in the tank?
I had a diesel tractor that would quit on me occasionally (fuel not feeding to fuel pump) and I could always get it going again by blowing back through the fuel line to clear that blockage at the tank outlet. You may have a bunch of junk too. Eventually I took the tank off and cleaned it out, it turned out to be a flat piece of peeled paint.
John
