-mike
One new symptom: Got stopped in place for 5 minutes in 90-something degree. The heat gauge went up for the first time ever - - - up close to H before I was able to move. Once going forward again, the gauge quickly returned to normal.
Cold starts still no problem.
Repeat hot starts are no problem. Re-starts after 10-30 minutes are erratic - often have to step on gas pedal which causes rpms to rise ( a couple of times to the degree that the car would go up to 20mph without more gas).
Any more thoughts? My mechanic (good) is at a loss to figure out what to do next.
The 99 LGT has developed a new one... this car has so much personality
The best description I can provide is that it's a mechanical ticking sound, that is MPH related, not RPM oriented. Starts after a few minutes at freeway speeds, frequency varies with speed, then goes away as I slow to about 40. Sounds a bit like a variable-speed fan would if there was a clearance issue with one blade. It's just subtle enough that I can't tell where it's coming from, but just loud enough to be a bit annoying. Car drives fine/as usual. I'm thinking a CV joint/wheel bearing is trying to tell me something vs. (I hope it's not) the front transaxle.
Turning the volume up in the meantime...
Cheers!
Paul
I'm going through the motions now to purchase an `09 Legacy 2.5i SE. I've done my research over the last year or so (originally was after an `08 but once I learned VDC was standard on `09 I decided to wait), but I'm having a heck of a problem getting my trade-in, a 2000 Honda Civic LX Sedan Automatic Transmission, ready to be, well, traded in.
My two options are to sell it to my cousin, who's just turning 16 and is in the market for a car, or two trade it in to the dealer.
There are two mechanical issues going on with the car that I must get taken care of if I'm going to sell it within the family:
1. The speedometer needle appears to be stuck at 20mph. This doesn't affect the transmission, and cruise control will hold a mileage above 20mph. Depressing the trip odometer reset button several times while the car is in motion will correct the issue and it remains functional until the next time you start the car up, where it immediately pegs itself back to 20mph, even in park. It was suggested that the speed sensor is operating properly because Cruise is holding a speed above 20 mph.
While the speedometer is stuck at 20, the odometer and trip odometer do not function. After it begins working again, the odometer picks up to where it was prior to the stuck needle (in other words, if it's stuck and I drive 10 miles, when it starts working again, it doesn't add the 10 miles on, it starts at 0.1)
I've been in a lot of conversations with the helpful people on the Honda forum, but I'm wondering if you've heard of anything familiar on this side of the forum.
2. The compressor belt will intermittently squeak when the A/C compressor turns on. The squeak's severity depends on the actual RPM of the engine (between 1.5-2.5k RPM upshift, a squeak will be heard for 0.5-1.5 seconds depending on how fast I get out of the 2.5k RPM range) but only occurs with the A/C on and was told this is not a transmission issue. I recently had the belts changed - about two years ago - and it was suggested that this is a tensioner that is probably bad since those weren't replaced. I was also told that I can go ahead and let this fail because it'll only affect my A/C and not anything else, and after it does fail, to get it fixed.
Moderators: Please do not move this to the Honda Civic forum as the thread already exists. If you feel this thread is inappropriate for the forum, please delete my post.
2. Try replacing the tensioner on the belt. They are not very expensive.
The mechanic just heated up the needle a little (after removing it),not too much or you could melt it. Then he reshaped it to straight. Put it back on and I never had another problem.
Pics here fwiw.
Upon first startup, it looked good, no jumping, just 0 mph. I'll try again when I go to work in a few hours and we'll see if it holds.
Thanks for your recommendation, hopefully this is it.
Sounds like classic CV joint issue. I'd start there and then possibly look at the bearing but you would here a more wop wop wop on the bearing rather than a clicking, although I have heard it clanking like a loose brake pad for the bearing before.
-mike
I was thinking CV too... sigh. Time for another trip to my favorite yellow-sign white-shirt come-a-running store (fellow northwesterners and west coasters will know)!
Cheers!
Paul
I posted this on the Outback problems thread a few days ago but didn't get a reply, so I thought I'd try it here in this more-active thread. Any thoughts and/or advice would be greatly appreciated.
First, the vitals: it's an '02 Outback 2.5 wagon, MT, 96K miles. As far as car maintenance goes, I'm pretty much a novice. I used to change my oil, air filter, plugs, etc on my previous cars, but have had the dealer do the work on the Subie.
The issues:
1) I tried to change the spark plugs yesterday and, after pulling #1 and #2, I saw a decent amt of oil on them. I've smelled some burning recently but I couldn't really tell if it was oil or something else - I guess it was oil. I did some quick searching on this thread and it's sounding like blown head gasket. It is critical that I replace it now, or can I wait about 10K when I have the timing belt replaced? For what it's worth, the car is running fine - normal acceleration, no CELs, etc.
2) Given the tight spaces around the engine, how on earth do you pull the plugs on this car? I've had my dealer do it in the past, but decided to save some $$ this time and do it myself, but there was no way I could get a spark plug socket, extension bar and wrench near #3 and #4 (and #2 was really, really tight). Given that, I put the old plugs back in #1 and #2, rather than have mismatched plugs.
3) I did manage to change the air filter - I'm not totally helpless! Added windshield washer fluid too (not to the air filter - I put the fluid in the right place)!
Thanks!!!
Clicking/Clacking like a playcard to bicycle spokes.
-Dave
Regarding access to the spark plugs, I've watched my mechanic change them. He removes the washer fluid bottle and some other things to gain access to them, and uses several different extensions and u-joints on the extension.
Be careful with the air filter. Make sure the tabs on the back of the housing fit properly into the slots on the other half of the housing, or you'll have air leaking in past the filter. The housing will clip back together even if it's not seated properly, so make sure to check.
I hope this helps.
Len
On a happier note: Tuesday = New `09 Legacy hopefully!
I haven't been back to either dealership, but every day I call the "other" dealer and get a little bit better of a price (not by much, we're talking $50 increments here), but eventually what it's going to come down to is the financing.
I noticed on the Subaru website there's going to be new national incentives starting August 4th, and right now there's absolutely nothing for the 2009 Legacy. (Unfortunately there's no more 2008's and the dealer we originally went to lied to us about searching for one and said there weren't any `08's within 250 miles, but the other dealer we saw on Tuesday located one about 50 miles away.)
I know that I'd prefer the 2009 because of a few reasons... It's a 2009 so the trade-in/resale value will be a "year" better, the VDC is standard (though the dealers both alluded to VDC not being "as important" as other brands because AWD is first and foremost), the better sound system (which I actually did not bother listening to - I wanted to hear the infamous Subie rumble rather than the radio, though I didn't find the `08 audio weak by any means.), it's just a bummer that the `08's are a steal with the 1000 cash back and 0.0% financing (which I was told I can get)...
So, we're hoping that on the 4th we have at least SOME type of incentive to buy an `09 Legacy. If not, we'll still probably get one anyway.
With the Honda, I finally went to the dealer (Coast Honda in Wall, NJ - they do fantastic service) and although there's a TSB about the speedometer, the fix they tried didn't work, and I'm replacing the speedometer head at about a price of $300, they also fixed the A/C squeaking sound (I was right, it was the tension in the compressor belt...) so my cousin will have it in the best order it can be. Thanks for all the comments & suggestions for troubleshooting.
Only 2% holdbacks? Yuck.
I don't understand how dealers that have an MSRP only about 1,000 above the invoice price that come right out off the bat and offer invoice price can make any money if they're making about 400 per car. I mean, I understand the theory behind volume, but there's got to be some type of quota system for bonus incentives (IE, SoA gives an extra $50 holdback if you sell 1-49 Subes in a month, but it becomes $100 if you sell 50-99, etc, etc.). As far as I know when I was in a financial pinch about a year ago that's how Hyundais worked, they were trying to sell me a brand new Elantra fully loaded for 12,000 out the door... But alas, no Boxer Engine and no AWD. I thought that the Sub dealer would have similarly "better" offers towards the end of the month since they had a quota, but perhaps not.
Funny, though, that the new Legacy would put out less emissions than my Honda Civic! PZEV is a nice thing (and from what I understand 3 more horsepower and a better warranty!)
Uhoh, I'm a Subaru fanboy for life now.
Good luck, I hope those incentives do appear for you. It is a last year model, so let's keep our fingers crossed for you.
My Honda Civic is/was also the last of a major model design before an overhaul, and it's been extremely good to me. It seems like they get just about all the kinks out towards the end, then start the whole process again with a new look.
Fingers crossed!
Just bought some Subaru "gear' to go with the new car!
-mike
Kenilworth/Cranford/Rosell Park Area.
We usually hang on Saturdays and Sundays and some evenings. Working on customers or our own cars, more shooting the breeze than work sometimes.
-mike
I'll have to make the drive when I eventually need to do some brakes or something, I guess. I haven't changed motor oil in a few years, actually. Not since I owned a `90 Wrangler anyway, sold that in `00. Hopefully the Legacy will be more roomy inside than the Civic!
-mike
One thing I'm reading up on now is the break-in period. I'm seeing some forum garbage floating around regarding different break-ins... Some say don't rev past 4,000, some say rev past 4,000 once you're 2/3 of the way through the break-in and this'll improve mileage, etc.
First new car here, so, thoughts?
For the Amsoil, I do 7500-10,000 mile oil changes on my cars or 1x a year whichever is first.
-mike
paisan can set you up. Get tints while at it.
That would buy some good times to hang out at the garage
-Dave
Here is the issue: At cruising speed in automatic mode, in top gear, at about 2000 to 2200 rpm, there are repeated sensations as though the vehicle were "missing". It feels like a skip in the firing of a cylinder. I have been assured that there is no evidence for this and that the problem is in the transmission. The transmission has been "reprogrammed" over and over again without any improvement.
It is most annoying, and unlike any car I have ever driven, and I have had many!!
Likely my FIRST AND LAST SUBARU!! :mad: :lemon:
Any one experience anything like this?
So it was a cheap fix, and it runs great now. Not sure if any of this could be your problem, but I hope so!
Subaru modified the Tribecas' engine for 2008 so it could burn regular fuel. However, its earlier engine incarnation wanted premium.
I had been smelling a burnt oil smell but I attributed it to grease from the broken rubber boot)
I went to a local garage who suggested cutting out the flange and replacing it with a flexi connector. They did the job for $125. While I was happy about the cost savings I now wonder if this will effect me getting the car through inspection. The car seems to run much better now. Your thoughts?
We had a 626 and the same thing happened, and I spent a similar amount.
Later friends here told me about the solution you mentioned. I believe it's fairly common, mostly it saves a lot of labor on the job. I wish I'd done it.
For the clock search for Peaty's instructions and photos on ScoobyMods.
I own a 1999 Subaru Legacy Wagon (Brighton). Over a period of 2 to 3000Km a noise coming seamingly directly through the stick shift has gradually been getting louder. Sounds like a bearing noise to me. In neautral the sound is there but not as loud as when in gear even when clutch is disengaged. Same in all gears and reverse. Have taken it to mechanics to see about a diagnosis but they tell me what I already know. Is there a further specific diagnosis which could occur. I am very strapped for cash and need to run it for work. Checked Differential fluid and it looks perfect. Should I check drain plug magnet for a type of metal? Any advise would be appreciated. Thankyou for your time.
That's the first I've heard of that sort of problem. What a freak occurence. Odd. The pistons on the 04 XT were forged, I believe, not sure about the con rods. The block was also exceedingly strong - they used the STI semi-closed deck block in 04 and 05 IIRC. 04-05 owners tease 06+ owners for not getting the same robust engine block. It was an inside joke of sorts.
I'm shocked. :confuse:
See if they can find a wreck in a junk yard that was hit in the back, and swap engines.
