Tree-sap , It will not come off. Can anybody help?
Is this stronger than Kleen Strip Surface Prep, or 3M General Adhesive Remover?
My big concern is that last instruction that says "6. Allow product to soak surface. Pressing hard will cause cloth to dull surface..."
It's worth a try if your other stuff isn't doing the job.
peanut oil is wonderful against pine and spruce sap. when that ran out, butter worked. stoddard solvent also works, but if you're way up north in the piney woods over an hour from civilization, you use what you got. and it turned out that edible oils are just about as good as stoddard for sap (aka bug and tar remover.)
also gets the glop out of the cat's fur, although peanut butter is more palatable, and the cat realizes it's not for the worst after she stops cussing you out for spreading it on. veterinarian recommended for tar and tanglefoot, by the way.
If in any doubt check the instructions. These plainly say they won't harm the clearcoat.
