New Toyota PreRunner
The gas mileage is a good plus for the prerunner.
choice with the prerunner. Is it normal for the shift selector to vibrate
while driving? It's not a violent shaking or anything - just constant
movement.
Scott
I would recommend this truck to anyone and especially in place of the 4wd if all one needs is clearance.
-Mike
diego
Check out Kelly Blue Book
http://www.kbb.com
or NADA
http://www.nada.com
I have heard that jerking or thumping as some say is due to the rear brake adjusting themselves when stopping.
thanks in advanace
dan
I NEED SOME ADVISES PLEASE.THANKS FOR ADVANCE.
I am looking at a new 2000 and wondered how one would look with Brush guars etc.
Well, if you get the PreRunner TRD, you get progressive rate springs, bigger sway bar, locking rear diff, heavy-duty gas shocks, higher ground clearance, big offroad tires, etc. That *does* give you better handling and the ability to take on rutted dirt roads, muddy roads, offroad areas and even sand with confidence. You just can't go climbing boulders like you can with 4WD.
That does not add nearly the weight you get when you have true 4WD and the extra transfer case.
Also, you aren't paying for 4WD. 4WD adds a lot more to the price.
I think of the truck as being between a 2WD and 4WD. Just because the truck addresses needs that certain people don't think are important, doesn't mean the people who buy it are "fake".
dj116a
www.tacomaterritory.com
On the web site there's a message board as well as every Monday night beginning around 8:00 PM Central time there's a chat. Topics cover anything and everything about Tacomas.
Paul
'99 PreRunner TRD V6
this topic is being "frozen." It will be archived or deleted in the next 10 days or so.
Front Porch Philosopher
