If you're just going to use your truck for light duty, consider a molded marine carpet bedliner. Cost is $199 from Cabela's or Bass Pro Shops ($259, but they'll match Cabela's). I just this evening put one in my 99 Silverado LT and I think I'm going to like it, especially once I get my Pace-Edwards roll top cover installed next week.
The carpet liner doesn't rub the paint off, can be removed later if you wish with no damage to the truck and is sturdy enough for light to medium duty usage.
P.S.- I have also heard from folks in the used truck business that a spray-in liner decreases the resale value of a truck.
I recently started shopping for a sprayed on liner for my truck. Around here, there are dealers for Ultimate, TOFF and Scropion,along with Rhino and Line-X. Does anybody have any experience with the other liners? If so, how do they compare with the "big two"?
Had my Silverado sprayed today! $369 + tax. Looks good! Had a Pro Liner sprayed, they had this other dealer that has this super duty stuff with kevlar but it is very hard and rough for $450. I think stuff would slide more on it. If I used my truck to haul alot I would have gone with that, but just every so often the Pro Liner will do the job fine!
Hello folks Just my two cents in here Remember if it is Rhino-liner, Line-X, Arma-Coat or any of the other seemingly increasing numbers of suppliers. There are small differences in their procedures, but they all are franchises. So one of the most important decisions is finding a good franchisee. It does not matter if they have the best system if their people are not trained well. Good people, good service, usually means a good product and happy customers.
I have a '93 Mazda truck that I bought new. It has a Rhino lining that was installed at their HQ in San Diego. It has been money well-spent. The material is indestructible and does an excellent job of holding things in place that would slide around in a drop-in liner or bare bed. I have noticed that it does oxidize, but Armor All or STP Son-of-a-Gun should protect against that. Very important: have them remove the tie-down loops before spraying, and re-install them after it dries. Rhino Lining does not stick very well to stainless steel as I found out after running rope thru the tie-downs a few times.
I have an 99 F150 I have a Leer Cap comming in and am considering a Line-x spray in liner under the rail or course. Anyone had a cap put on an F150 after having a spray in liner put in? Does it clamp on OK? Any problems?
The drop in liners will scratch the paint and even the textured tend to allow load shifting. The spray in liners can be a nightmare for a body shop to work on. The spray in liners will to prevent the dents in the bed. Think about it, it's only a thin coating of rubber/vynl that the bed itself shapes. Hold a piece of that material in your hand and see how tough it is. For some the appearance and load holding capabilities are well worth it. But don't fool your self, it will not stop any dents or dings. I used a heavy rubber mat to redudce load movement and prevent scratches. The tailgate has a bedliner-type cover. I custom made corner boxes that will protect the sides and store the misc. items like tie downs and hitch insert.
My drop in liner from G.M. Goodwrench has anti-skid compound molded right in. It works great. Rubbing the paint off happens when dirt, grit, sand and debris gets under the liner. I stick a mop sprayed with wax under the liner, and work it back and forth to clean underneath periodically. This cleans debris from the bottom of the liner as well. I have no problems with paint rubbing off. But you can't lift up a rhino/line-x liner! It's permanent, and I'd be sorry to see that paint underneath gone forever!
Bought thru Cabelas for my 99 silverado. Fits great, good and sticky. Easy to remove. Will probably buy Daws better-built aluminum diamondplate covers for tailgate and front of bed.
I like bed mats much better than PE liners or sprayed on PU.....
I've just read through the last 30 or 40 posts on this topic and was wondering why a sprayed on liner would reduce the value of the truck?
I myself, don't need the dent/ding saving features of a drop in liner so am thinking of a sprayed on liner. I looked at Line-x and Rhino liners yesterday. Thought both would do for my purpose. Does anyone have any negatives or positives about either of these companies?
What about any comments on over the rail vs under the rail? I know if I don't protect the rail it will eventually be scraped up. Whats everyones preferred method of protection.
One final comment, I've got a slide in camper and the service department of the camper dealer said he does not like putting the campers onto drop in liners. He thinks the friction between the camper and the liner is to small. I asked about sprayed on types and he didn't have a problem with those.
I think most of you questions have been discussed earlier on in this topic. Youmay want to go back to the top and read all the posts to get thos answers.
My Line-X has been installed in for 10 months. There is one minor negative. The color has gone from the original bright and shiny black to one of charcoal grey. The truck is always parked outside. Between that and the carwash soap it has turned color. (It's the crud on the liner and NOT the liner itself.)
Just took delivery of my 99 Silverado LT Z71, and need to make the agonizing decision of drop in vs. spray in. One topic I have not found discussed is the protection pads that can be installed under the drop in liner to prevent the liner from scrathing the paint. Anyone have any experience with these?
Bogrady, I was just going to suggest those. I saw them for the first time, and I believe it is definitely worth a try. It is stated they don't absorb water. But you be the first to report! I've been mopping under my drop-in after it gets wet. It's work because I do it so often, but the bed does look nice because of it.
It is often said how easy to repair a Line-X/Rhino is. Not disputing that. But I wonder if it isn't more simple still to just re-spray the automotive finish damaged by a drop-in liner.
Just read through the posts, and have my 2 cents to throw in. Ive found the spray ins just are not worth having. They sound great but they dont pan out. We run snowmobiles in and out the back and the Rino chips and cuts something terrible. Just a few trips and the edges of the tail gate and the rear of the bed are all chiped out for 4 or 5 inches and look like the dickens.
On the other hand, Ive a drop-in (Leer, I dont think they make it any more) in my Ford ('94) and it looks new after countless loads. Scratches from carbide skegs, but no chips and gouges along the edges. Its lots better for sliding barrels and tools into the truck. The Rino's a pain, you always have to climb in and move it back. When you have a shell on and have to work on your knees its a pain. Just bought a new Dodge 2500 and Im putting in a drop-in.
Here's an idea I haven't seen in the old posts. It works really well for compact trucks. Go to a local farm supply store. Ask for a stall pad for horses. They are a 4'X6'recycled rubber mat about 1 1/2 inches thick used in stables to keep horses from slipping. I cut out about 4" from the center of each side to fit the wheel wells. Perfect fit in a Ranger, very durable, prevents dents, and ads about 80 lbs to the rear end for traction. Best part is the price - cost me $30, less than the 1/8" rubber bed mats at Walmart that bunch up, alot less than brittle plastic drop-ins, and 1/10 the cost of a spray-in. Anyone else use one?
I just bought a 99 Tacoma and am thinking about putting a spray on liner in it. Does any body know if this voids the corrosion warranty? Technically, you are altering the surface finish of the vehicle. Also, has anybody had any luck with the do -it - yourself Kits?
I hope it doesn't cause a problem with your corrosion warranty, and doubt that it does.
Still, some of the reasons in favor of the spray-on are mooted, like ease of repairing a chip, compared to ease with which you could more easily re-spray a painted area damaged by a drop-in liner.
Get what you like, is the best advice. Still, my buddy's Line-x was chipped/scuffed up pretty good by some sharp-edged cargo he was carrying. With a drop-in, the paint gets rubbed off in a few places. You can mitigate to some extent by mopping underneath the bed-liner to keep it clean. And if you want to see the factory paint, at least SOME is there, unlike the spray-on liner where they have to sand the painted finish before they can apply. Ouch!
Heres another option for the bed and I know alot are going to be saying ,"carpet,for hauling junk and wood?" I just put a Bedrug in my truck and all I can say is its look great and they claim it won't scratch you bed and you can use it just like any other bed liner.I will not be using it for heavy work but for some of you looking for another route to go it might work.It fits like a glove and you can remove the sides if you want.It is held in by HD velcro.Also comes with the tailgate piece attached to the rest of the liner sealing the section between the gate and bed.
I have a 1997 Chev. S-10 P/U with a spray in liner, and have had nothing but good luck with it. It looks as good today as it did when it was installed two years ago. I did some researching before deciding to go this route, and discovered that the do-it-yourself kits looked lousy and were soft to the touch. As was the case for the Rhino brand spray-in. I finally decided to go with a company that sells a product called Arma Coatings. It has a finish that is hard to the touch and is 1/8" thick, but has not scratched or dinged any at all from my personal experiences, and I would highly recomend this product. it is more expensive than others, but the lifetime warranty and the sound deadening properties make it worth the extra expense. By the way, I am a GM body/design engineer, and as for the paint warranty being viod by doing this-no. This is the case for GM vehicles, but I don't see why it would be different for Toyo. Good luck!
I have just purchased a new S-10 pickup. I am interested in the Line-X spray in. I have read the postings here and am interested to know if the over the rail application will look OK. Not only am I concerned about it fading and looking bad but also it being a straight application that is clean cut. I know that I need to protect the rails in some way and I am not sure if the spray in is a good idea for this application.
I have a friend that has Rhino coating on his 97 chevy work truck - he is a tree trimmer and beats the hell out of everything - except for the dirt his bed looks great
giff: I got the over-the-rail Line-X treatment for my Ranger. It looks great. Check out your dealer's shop and ensure that they do a quality job. Ask for samples to see how sharp the edges will be and how they mask. Mine are nice and straight.
I got the Line-x spray in for my Toyota Tundra about two days ago and the liner looks just fine. I checked out the shop's work and it looked great so I figured they would be a safe bet. Well, they ended up scratching the paint around the edge of the rail when they sanded prior to spraying. They also spilled some cleaning liquid down along both sides! The spilled liquid cleaned and polished right off, on site. The scratches on the other were not as easy removed. They tried but you can still tell where the wax (not the clear coat- thank god) is pretty scratched. Needless to say I am royally pee'ed off. They want me to come back in order to work on the remaining scratches but I want a professional to take care of it. Its going to take a buffer I'm planning to get an estimate and present it to the Line-X guys tomorrow. If they don't pay, its going to hit the fan. Be wary my friends.
That sounds like something that would happen to me leew. I think for the money I will invest in a drop in liner that goes under the rail. I think the drop-ins will offer more protection from dents. There is a shop in my area that carrys a brand name of BodyGuard. Has anyone heard of it and if it is good quality. The price is 169.00 installed. Oh, good luck leew, hope things work out for you.
I spoke to a two body shops and one detail shop about the scratches on the paint. All agreed that with a little elbow grease, some polish and some wax that I could take care of it myself. Well, I worked on it on Sunday and it looks much better. While not exactly mint, you have to get pretty damn close to see the scratches. I decided that distancing myself from my local Line-x idiots and taking care of the problem myself would be better.
I bought my 1999 RAM with a bedliner that does not extend over the top of the bed, but tucks underneath. So, how do I protect the top from scratches when I haul brush ? Does somebody make a thin removable top strip to cover the rails ? Right now I put a dropcloth over everything, but there must be something better.
Also, I bought a toolbox on clearance sale from Lowes. Again, how do I protect the top of the bed ? The boxes I see on other trucks look like they have a strip of foam or something under the sides of the box. Where can I get this ? thanks, John
someone paid $369 plus tax for a sprayed on bedliner????
I know they look pretty sharp, but I don't get the appeal of these products. an under rail bedliner really doesn't affect a truck's looks. I got a pendaliner for $129 installed after rebate recently. It seems to me that a traditional bedliner would be much more effective at protecting against dents than a spray in, due to the corrugated design. That's my main reason for getting one in the first place. I know a bedliner may scratch paint, but I've never had rust problems in any of the trucks I've had liners in. And if you periodically inspect and clean it, I don't see any major problems arising. Perhaps some people have had problems in that area. My guess is that as trucks become more popular and "cool", there will be more attempts to lure $$$ out of our pockets for "must have" items that don't really do anything functional. (cab steps on 4x2's, chromed bed rails you wouldn't dare scratch, silly plastic tailight covers, etc, etc)
Although I don't have a sprayed in liner, I do understand the attraction. The surface has enough texture to hold or grip a load from sliding around yet if you dragged a load over it you would not damage it. I went the cheap way and put in a rubber mat.
I've had all three types; over the rail, under the rail and spray in. The over the rail took some tricks so that the tool box wouldn't make the liner tear up the paint on the top of the rails. The under the rail was always moving slightly and rubbing the bed paint. I used silicone glue and rubber gaskets at the rub points. The spray in (Line-X) can be chipped if you really work at it. Mostly at the right angle bend of the back of the bed by the tail gate hinge.
The Line-X looks great new. After car wash soap it turns more charcoal than black. Both drop ins did the same but not quite as quickly. The drop ins are slippery. The COF of the spray is very high and nothing slides about. Good at times, bad at times.
Which would I do again? Spray in! No question. It's only about $200 more. It's worth every penny. I've had it for over a year now and never garaged. It still looks that charcoal grey. Oh yeah, the truck is a toy and not a work truck. Rich
My drop-in is not slippery. I have a Dura-liner and the surface is fairly tacky. As a matter of fact, there are times I wish it WERE slippery, 'cause I gotta climb in to move things around!
I have a couple of friends with spray-in liners, and I just didn't like them. Maybe they were poorly done, but they looked like someone gooped up their truck beds with driveway sealant.
ladyblue, I looked at some Rhino liners. They were exactly as you described. The Line-X looks like a zillion tiny beads. That was why I picked the Line-X. I don't think that there's much difference between the two. (It's all probably in the nozzle used to spray the compound.) Neither are sticky just a high Coefficient of Friction. Rich
I still like the drop-in better. More cushion for when you drop things. You can mop underneath if it's really dirty. If you toss boxes in there, they slide to the front rather than tip over.
I might mop under the bedliner for a few months, or maybe even a year, but sooner or later that will grow old. With the spray in liners you don't have to do anything.
I don't really haul anything heavy, so I think I will leave my truck bed in the nude until it starts getting scratched up and then I will have them spray in a bedliner.
The Rhino liner is by far much the best. It wont scratch the bed and the rails. It also will not crack if you drop something in it. The liner might be a little more expensive but is also is non-slip. Hauling heavy things it helps. If your bed is scratched or dented it forms to the body and will not rust.
The Rhino liner won't scratch the bed, but the process of applying it will, since they sand your paint off!
Much has been said about the ease with which a sprayed on liner can be touched up. And while it's true that a drop-in liner can scratch the paint, it's still much easier to re-spray with regular paint, than a urethane coating like LineX or Rhino.
And if you like to have tail-gate parties, your friends will much prefer the ribbed cushioned effect from your tailgate liner, than the scratching and tearing on your butt from the spray-on.
I covered my tailgate with a liner and then put a rubber bed mat in. No sanding, no sliding of the load, and inexpensive. The only draw back is the sides are not protected. This does not affect me because most of my heavy loads are secured to a skid.
spray on liners from rhino that i saw seem to get chalky, and if you touch them they leave black marks on your hands.has any body seen this ? also i cannot find a bedliner on the web ? i am interested in a rubber mat where are these products available? any help would be appreciated.
Rhino liner- Once the liner becomes chalky, how difficult can it be to clean? Maybe they have a cleaner for liners as such. What has anyone used to get the shine back? I'm getting a 2K Silverado, 4x4, extended cab, long bed, & have been looking at the "Nerf Bars" for getting in & out of the truck, as well as protecting the sides from inconsiderate people opening there doors into the side of your beautiful truck. Any comments on this type of running board. How about the bug guards- do they help for there intended purpose? Thank You-
Terry
As I said, IT'S MINOR! Not a real complaint.
Rich
Bushpilot
Good luck!
something better.
thanks, John
email:
jmharmon33@yahoo.com
Rich
Rich
Mike
