Pickup bed liners
                    Have ordered a 99 F350.  will be hauling a
gooseneck trailer. Anyone have opinions on which
kind of liner best? And, if I get Rhino liner, do
I have it installed before or after they install
the hitch for the gooseneck trailer? Many thanks
An interesting thing about the Line-X bedliner. Today I carried a cardboard box with about 60 Lbs. in it. The box was difficult to slide in and out of the truck due to the friction between the bed liner and box. In my old truck with a drop in liner, the box would have been sliding all over the place.
I'm sold on the spray in Line-X.
Rich
You might check out the "truck accessories sections for some additional comments on spray-in liners. We had a pretty good conversation about it a few months back. The two most talked about companies appear to be Rhino and Line-X. The Line-X appears to be a little smoother. I know people with Rhino liners who really like them. Actually, I haven't heard any complaints by people who have them. In addition to the protection, the liners limits the amount your cargo will slip around, compared to a normal bedliner or no bedliner at all. I'm leaning toward Line-X when my new truck arrives. The cost appears to be $400-$600.
Now, about paint scratch, it's amazing to me that people who want bed liners are worried about plastic ones scratching, when --once applied-- the spray on liner can't be removed, so it's irrelevant if the paint is scratched. I know I plan to get a sprayon liner, but more for utility and resale than for paint scratching.
My two cents.
Ryan
The Rhino liner is a more rubbery than the Line-x and is about twice as thick. The guy said that he sprays around 65 lbs in a short bed and 75 lbs in the long. The drain holes are open, and the tie down bubber boots still fit the holes.(Dodge)
My son-in-law has the Line-x and he likes it.
I would like some feedback for commercial users. Conventional bedliners never held up for us.
Have you checked (with the manufacturer or supplier) whether you will be able to slide the camper into the bed with a spray-in liner? They supposedly grab so well that nothing is supposed to slide on them. I'm sure the plywood would help.
(This seemed pretty obvious to me from the earlier comments, but maybe I'm missing something here.)
http://www.line-x.com
Thanks..
If I had to do it again, I would.
BTW - Get your dealer to quote a price for the liner. Mine was $325 (Long Bed) from the Ford dealer or $385 from the Line-X dealer.
Rich
Can you give me some idea what costs are for Rhino type liners and dealer installed Duraliners?
Have a 1999 F150 SuperCab shortbed ordered. Dealer wanted $299 for a Duraliner and felt I was justified to shop around and explore all the possibilities until the truck arrives.
I sent for the Rhino brochure and they are interesting and will take a look.
This is my first pickup and am really indicisive about type and what costs should be. Dunbarton
As an addendum to the post above I would like to ask you pickup truck guys a dumb question or two.
I have looked at the new F150s and don't see any drain holes in the bed for water. Why not?
Do you guys drill a hole(s) in the bed? Is this a good idea to break through the anti rust undercoats?
If a drop-in liner has drain holes, and I don't know if they all do (Duraliner), I would think you would have to drill the bed to keep the water from remaining between the liner and the bed?
Dunbarton
They're there, you just didn't see them. The floor and the front wall of the bed of the F150 are separate units of sheet metal, and the front wall is a waffle design which provides aproximately a 1"x1/4" gap approximately every 6". Mine's a '98, but I doubt if the bed of the '99 is any different. Try bringing a can of water next time you look at an F150. I think you might find the water running out almost as fast as you can pour it in. I have a fiberglass lid on mine now, but I didn't for the first 8,000 miles and I never collected water in the bed.
A sprayed-in liner will plug those holes, however, and that was one of the things I didn't like about them. The demo pickup at the Rhino-Liner dealer I went was parked on a hill with the front end pointing to the bottom of that hill. That pickup had about 5 gallons of water in the bed from a recent storm. Seeing that didn't help me to decide in favor of the sprayed-in.
I ended up getting a Pendaliner set-in. It cost about $180 with the tail-gate liner and the Rhino would have been about $300 to $350.
My slide in was around $180 for short bed. The Rhino was $375 for short bed.
With the drop in liner, I noticed friction points where the liner was rubbing. These rusted. The spray in doesn't have any rubbing points. The spray in is $150-200 more, but worth it. Nothing slides around on the spray in liner.
Rich
I have been enlightened and thanks. Big help.
I am not happy to hear about rusting friction points and this sounds like a logical occurance with a drop-in.
Now I realize where the water drains LWF .....
Not trying to be a cheapskate and I realize the set-ins are probably cheaper but we have a Rhino autorized very close to me and will check them out. I have about 6 weeks until the new truck arrives.
Since to F150 has top guards on the bed a Rhino won't have to be "over the rail."
Looks like it will be just a matter of personal preference when it's all over.
I can live with water laying in the bed until it all runs out when I floor it!
Thanks for all the tips guys. I want my first pickup to be perfect!! Dunbarton
We have a local Rhino dealer close by and I stopped to look at his work and it's first class and $380 for short bed under the rail.
Thanks to you guys who commented to my questions regarding both types of liners. Big help for a novice pickup truck buyer.
By the way, I am pleasantly pleased with the '99 F150 ........ Dunbarton
I'm new to trucks and never had a slide in camper before. Any info would be helpful. I also like the spray in liner with the thought of having it over the rails for putting misc. gear in the side of the box where the camper doesn't fill. If I just use a rubber mat then I lose protection where the bed is still exposed. Finally, I've read both - are the drain holes plugged (or not) by the spray in process. I'd rather not loose the drainage. Thanks for any help.
While I can't expertly comment on your requirements with the camper, the fellow who is doing my Rhino will some leave drain slots in place by sticking plugs where it drains at the front of the bed and remove them after the job is done.
Be advised, the Rhino type liners are no better than the preparation and the people doing it.
I went to 2 franchised Rhino installers and the difference in workmanship was astounding. Dunbarton
But like I said, always check with the camper dealers of the brand you are thinking about buying. They make a living installing the slide-in campers and have usually seen just about everything.
Rhino liner installed and am pleased with it. A first class job and workmanship. Apparently there are no Line-X franchises here in New Jersey close to me so I didn't have one to compare to Rhino. I am sure they are comparable.
Another question and I know this is not the correct forum to ask it on.
Has anyone done their own decal type pinstriping here? The truck needs something along the side to set it off.
I prefer the decal type as I have seen the painted stripes wear off in time. I guess they both can wear off in time. Any recommendations?
I have a good eye and touch but certainly would not attempt to paint them on. dunbarton
-Mike
Mine's a Pendaliner in a '98 F150. No holes that I can see after it's installed. There are 4 tie-down brackets in the side walls of the bed. These were removed by the installer (2 screws per bracket) and re-installed after the liner was in place. There were a couple of holes in the liner at each bracket location, but the brackets covered them completely after each was replaced. I'd have a hard time believing even the smallest grain of sand or chip of wood could get under the liner through those openings.
I too looked at the Duraliners before getting a Rhino and the new slip resistant Duraliners didn't have those large holes there or any holes at all. Tie downs would have been removed and installed the same as lwf's Pendaliner.
Something doesn't sound right here about the dealerships' drop-in liner ..... Dunbarton
--Mike
I may have misunderstood your post due to "mikef150" and assumed this is what you drive.
I only looked at the F150 Duraliners so I cannot expertly comment on the SD liners. I have an F150 SC short bed.
My Rhino cost $380 vs. about $235 for the Duraliner. A Rhino for yours would be more due to the sheer size if it.
Depending on your lease length, I don't recommend the Rhino. It's permanent, you won't get anything for it at turn-in time, and no sense spending the extra money just to give it away IMHO. Dunbarton
One thing that I found out in my area is that the Line-X shop is the only one that puts the liner on with HIGH PRESSURE application. This dealer is convinced (of course) that high pressure application is the only way to go. He said it was much easier to control the application process. Does anyone know if going the high pressure route makes a difference?
