I'm looking for a real thick rubber mat for my F250 bed. Most are about 1/4" thick. I've heard some are 1/2" thick and won't blow up on the highway. Can anyone help with a brand or dealer. Thanks
I have one from Tractor Supply Company I bought in early 97 to save my knees. It is 1/2 inch or better, but it still blows up a little if I don't have weight on it. It was around $65 if my memory serves.
I think the difference between these two applications is pretty well self explanatory but I'd appreciate if someone would verify the meaning of these terms and any less-obvious advantages/disadvantages of each. Thanx for your time!
1.) you can get the rhino liner anytime, so when i get my new 30k truck i'm going with a drop in, if it doesnt work for me in a few years i'll sell it and go with a rhino/etc spray type. I guess you might go the other way as well ? 2.) Tractor Supply Company (aka T.S.C) Is a midwestern store with a lot of places. I know one such fine store in Decateur Indiana (if you go there, drop by and visit a guy who builds, amoung other things, nice corvettes names (john) lingenfelter! Find their phone on any website w/ yellow pages (e.g., www.bigfoot.com) :=)
To trambitis; For what it's worth, I have a 95 Ram 2500 that I put an under the rail bed liner in. ALL DROP-IN BED LINERS RUB AND SHIFT going down the road. A friend of mine had an over the rail liner and when we removed it, it had rubbed all the paint off the top rails of his pickup. Each year I remove my liner to get the dirt and other debris out. The floor sustains the worst damage, the sidewalls show varying degrees of paint being removed. All of this needs attention otherwise the pickup bed will simply rust out. The drop in liner has definitely protected my bed from the drop ins of fence posts and driver and other related ranch type activities, but I just don't like touching up the box so it won't rust out. I buy for the long haul, hate spending the money. Look to whatever will help me protect my investment.
I'm personaly looking into the spray in liners and have gained much in the way of reviews posted on this site. I would definitely advise you against a drop in liner, unless you are willing to do the maintenance that goes with it.
Whatever you decide, let your application guide your choice. Heavy vs light hauling, long vs short term ownership of the vehicle, and in the bed hitch vs frame or bumper. I have found all of these factors and more influence at least my decisions on what to look for.
If anyone is interested, I just got my 30k Silverado, 4x4, extcab, LB Line-exed, & I highly recommend it,if your going for a spray in. I shopped around first for Rhino, but finally decided on Line-x. Looks like factory installed, not that cottage cheese look, & I got a good price of 395, over rail. At first I wasn't going over rail, but glad I changed my mind. It looks absolutely fantastic. I had mine done in Sacramento, Ca. on Auburn Blvd... Rhino is OK too, but Line-x looks much better. If you want softer, go with Rhino. It took five hours from start to finish, whereas Rhino wanted to keep it for a day & a half to two days. Hope this helps anyone looking for a spray-in.
Average cool down and warm up is about one minute, Block heaters for the cold are wonderful and so are Pyrometers for cool down. If you do the math you will notice that upkeep is not much of a cost difference, Spark Plugs, Wires, Rotor, Cap and more oil changes and an Air Filter (Gas). No Plugs, Fuel Filter every 15,000, Oil change every 7,500 (11 Qts.), Air Filter, Valve adjustment 150,000. V-10 average 10-12 MPG, My Diesel 16 city and 19 Highway at 75MPH. Average rebuild 300,000 to 400,000 miles, V-10 200,000 if you treat it nice, Diesel fuel average here $1.19 Gal. Mid Grade gas $1.20 Gal. Put a large load behind that V-10 and your mileage is gone, put a load behind mine I still get about 16 MPG @460 ft. lbs of torque, V-10 450 ft. lbs. The new sound proofing is awesome in the new Y2K Rams, my truck is pretty quiet inside even compared to my old 1998 Ram 5.9 gas engine that I traded in. You make the choice, that is why I now own a Diesel.
I have an 5 star liner(drop in) in my current F150. It is great for loading bricks and lumber. Fork lift can slide the load around but at the same time, the load does not shift during driving. Anyone have any exp. with similarities on the spray in's? Got a '00 F250 due on 12/20 and need to make sure its "protected"
We're getting a little off the subject here, but most people I know who own diesels change the oil about as regularly as the people who own gassers. How often do you change plugs and rotors each 100,000 miles? The Ford V-10 doesn't have spark plug wires.
As for mpg, the difference is usually about 5-7mpg running empty and closer to 3-4 towing. Of course, it all depends on what you tow. If you're towing a 5,000 pound boat, you'll probably stay closer to the 5-7 mpg difference. Trailer Life recently used a new Dodge 24V Cummins with the 3.54 (or is it 3.55, I forget which) on one of their tow test. They towed a heavy trailer. I'm pretty sure it was a conventional tow trailer that weighed right at 10,000 pounds. For their test, the truck got a little over 20mpg running empty. Towing, they got 10mpg.
That's right in line with my dad's personal experience. He's retired and gets to spend thousands of miles on the hwy talking to other RVers who tow with Dodge and Fords. He owns a 97 F-350 dually PSD with the 4.10 and manual transmission. He tows a 35 foot high profile fifth wheel. The total combined weight of truck and trailer is 18,500 pounds.
He's put over 40,000 miles on the truck in the few years he's owned it, most of it towing. He averages 16mpg running empty and around 10 towing. The best he gets towing is 12mpg and that is in ideal conditions on flat hwy, but there is also the occasion where he drops below 10mpg depending on terrain, road conditions, and headwinds.
On his most recent trip this Fall, he drove from northern Ohio to South Carolina then up to Maine, back over to Ohio and the over to Seattle where the truck and trailer are currently stored. He averaged 9.5-10 on that trip. My guess is the V-10 would get 6.5-8 towing the same load.
He said that his tow mpg is the same as the other RVers report, regardless of whether they are towing. The Cummins generally gets a little better mpg running empty, although some of that is related to the axle ratios. I don't see a Dodge Cummins with duallys and the 4.10 getting more than 1-2mpg better than the PSD running empty, and probably close to the PSD in towing mpg.
If I were towing, the advantage of the diesel is the towing power, especially in the mountains and at altitudes. The mpg advantage, especially running empty is a secondary advantage. If you're not towing, the selection of a diesel is preference. I'd certainly buy a diesel if I was towing regularly and may eventually buy one for the amount of towing I do now.
You can work the numbers to support either decision. Don't forget to factor in that you are paying 7%-8% interest on the $4,000 initial investment you will pay for the diesel whereas that money could be earning interest in a CD or mutual fund for you. You'll definitely expend some additional money on routine maintenance. both of those have to be factored against the mpg difference. As far as engine rebuilds, how much does it cost to rebuild or replace a gas engine compared to rebuilding or replacing a diesel engine? If the cost is twice as much for the diesel, it's a wash, and that's based on the assumption that the diesel will last twice as long.
As far as resale, I know a lot of people who don't want anything to do with a diesel that has over 100,000 miles on it, mainly because of fear of the unknown. A properly maintained diesel should last 200,000+ without too many expensive repairs, but if it's not been properly maintained, high cost problems could occur sooner. With a gas engine, they generally know how much longer they can expect to drive it before they have to start throwing some money into the engine, and they generally have a decent idea of how much money they will have to throw into it. Most buyers will probably use Kelley Blue Book or something similar. Kelley Blue Book identifies the resale of a 94 Dodge 1 ton with the V-10 and 100,000 miles to be about $2,250 less in retail and $1,100 less in trade-in value than the same truck with the Cummins. I still think it will be tough to sell any vehicle with 100,000 miles on it for over $15,000, which is what you would have to get to meet their retail figure with the Cummins.
Just to tie back into the topic, my dad is a Rhino Liner in his diesel truck and I have a Line-X in my gasser. We both are very happy with them. Neither of us thinks the difference between a Rhino or a Line-X will impact resale value or longevity of the trucks.
Brutus I understand the Topic here, but someone inquired about Dodge V-10 vs Cummins so excuse me for providing input to someone with a question (response 201). The topic was not even about a V-10 Ford which would get even better mileage than a Dodge 488, If you go 100,000 miles between Spark Plug changes I wonder about your maintenance practices, do you in fact drive large vehicles with large diesels daily? I do. I am glad most people you know only go 3,000 miles between oil changes in a diesel, I guess that is what you were trying to say, but most people I know (Diesel mechanics included) recommend 5,000 miles on the ISB between oil changes depending on how hard you worked your diesel. You refer to THEY who is they? If someone knows Diesels they will also know what to expect for maintenance and repairs, it is evident that you have not been around high mileage diesels for extended periods of time, where I live alot of people run Hot Shot and it is not uncommon to have never shut off your Cummins except when an oil change is due, around here you cannot keep a diesel on the lot very long even with 100,000 miles on it. When Trailer Life tested that Dodge was the engine broke-in 10,000 miles+ ? your mileage will increase on a Cummins after the break-in period. It comes down to perference and application, people ask questions because they desire others opinions and viewpoints, don't give me your opnion I did not ask for it, give it to Response 201, it does not matter to me I have a Diesel and a Gas Engine.
Thanks for clearing that up, how is the duallie doing in Alaska? do you any special items for the cold weather? I just started using my Block Heater last week.
hey i live in sacramento, too, and have been considering a spray in liner. did line-x do any color matching? i heard rhino can color match and i'm looking for a silver spray. what made you go over rail? thanks for the help!
The duallys work fine in Alaska in 4wd. If I'm in 2wd, I get more slippage sooner on icy roads. With an empty bed, no pickup gets good traction in winter conditions. I don't find the duallys to be any more of an issue in the winter than an SRW. The traction is really good in 4wd.
I've got a block heater, the all-terrain tires, and the 4.30 limited slip. Those are about the only winter related options on the truck.
jlee,
line-x can match, but it's up to the individual dealers whether or not they will. Some of them don't want to hassle with anything other than black. I think there is a pretty thorough cleaning process of their equipment when they change colors. That's one of the reasons it cost more to get colors. I went under the rail. My truck has a hard plastic cover on the bed rails. A coworker went over the rail on her Dodge and it looks really sharp.
jlee7, Most spray in liner dealers will advise you NOT to do a color liner. The shop really doesn't want to do the color because the equipment has to be cleaned before and after. For that, the shop will charge between $100-200 extra. So the cost for color is steep. To make color, the shops have to put more color in and therefore less polymers. The color liners also require a UV coating to protect it from the sun. Most shops say that the warranty is only one year for color spray jobs. Actually, color is a really big pain for most shops. I considered it for my truck but the shop talked me out of it.
I'm stationed @ Travis AFB. The local line-x dealer wants $400 for under the rail, $440 for over the rail, plus another $40 for the tailgate. I think he's gouging a little because he's sans any competition. Could you please give me the # of the Sac line-x guy?
Check out post#221 on this page. Number is there.WhenI was getting my truck done, there was another 2K tundra getting the spray in. The price was $395 under, & $70 more for over rail. This of course included the tailgate. My truck is an 8' bed, & I paid $395 + tax on a $150 = $406 out the door. Great price, great job. I did do a little bargaining though. Each dealer can set there own price. The guy with the Tundra paid the full price. If I were you, I would mention your in the military, & if he could possibly give you a discount. In my case, I asked if he gave a senior citizen discount, & he kind of laughed & said I'll tell you what I'll do..I'll give you over rail for the same price as under. Done deal..$395, opposed to $465. Sounds good to me. Ask for Jesse, (the owner). They did a great job too. Took 5 hrs. Good luck! Let us know what happens.
The Sac linex gut wants 436.63. That's for over the rail and includes tax. I have another interesting option to ponder. Seems a product called herculiner is making a DIY kit for $99.95 at NAPA. Anyone have any experience with this type product?
I have seen several new roll on/ do it yourself liners as of late. Petersons 4 wheel and off road did a review of one a couple of month ago and gave it an excellent review. I do not remember the brand though. Some of the DIY roll on also come in colors.
However, My brothers boss tried it and said it did not stick well and looked crapy. This could be do to the prep time and care taken, he is not a patient man nor a do-it-yourself kind of guy.
Both sources stressed care when dealing with the product because it will stick to the sides of the vehicle, tai;ights, hands, ect....
I am actually considering a DIY roll un to protect the bed from scratch/rust under a drop in. drop ins are hard to beat for heavy duty use.
OK! I'm gonna do the roll on herculiner. However, it will be my 78 Toyota that gets this expirement. I've got the canopy off and I'm starting prep work. Should be rolling it on friday. I'll let you know how it goes.
My buddy applied a black DIY roll-on in his 1999 Chevy Z-71 and it LOOKED pretty good. It is not as thick as the spray-on liners I've seen. Another friend just bought a 1999 Toyota Pre-runner and had his liner sprayed-in to match his paint job. It is much thicker and seems will protect the bed better. The roll-on looked thin and had chunks of what seemed to be rubber embedded. These chunks kept falling off as you rubbed hard with your hand. I doubt it will last long if you have heavy cargo moving around the bed or are filling it with dirt and using a shovel to scrape out the back. I just bought a 2000 Nissan Crew Cab with a plastic liner. I'm considering taking out the liner an putting down a spray. Just my opinion.
Did the herculiner. I don't recommend it. It cost $100 and is thin even after the second coat. It might be worth it if the cost were much lower. It sticks real good to rusted metal if you clean all the loose rust off first.
I'm planning to buy a used 90's Chevy full size (1/2 ton) 4x4 soon and I was doing some advance research on bed liner possibilities. I've heard of several brand names (Rhino Liners being the most predominant) and quite a few local companies claiming the same quality and durability as the big boys. A friend of mine had a spray-in done by a local company in Jax, FL. It looked good at first but soon began to fade to a dark grey (it was black when applied) and it also began to lose it's original finish and shine (although they said it included a UV protectant film). It's to the point now that when you touch the surface, your hands are covered with this black powdery stuff.
I'm trying not to make the same mistake as he did. The place he went to charged him around $400 for a 1999 Toyota Tacoma 4x4 short bed. I'm not sure if that price is reasonable but the quality he got out of the deal sorta sucked.
I'd be interested in anyone's inputs about brand X versus brand Y and why they're better than the other guys out there. Like I said, the only one I've really seen advertised heavily is Rhino Liner. Any comments or inputs would be appreciated. Thanks in advance for your help.
Has anyone gotten a sprayed-in liner from from Line-X of Baton Rouge? I just bought a new Silverado and want to get a sprayed-in liner. I looked at Rhino and Line-X. I like the looks of the Line-X a little better and the quality seems to be a little better; however, I'm sure the Rhino is a good liner too. I think it's mostly personal preference. They had a truck they had just finished when I stopped by there. It was an over-the-rail job. It looked great but I didn't inspect it really close. I was just wondering if anyone had any experience with Line-X of Baton Rouge.
just thought id throw in another product. I have a 99 z71 silverado and got speedliner sprayed in my bed in a metalic blue. I love the way the bedliner looks and performs. Their web site claims minimal to zero fading. I know that some dealers will even warranty repair for excessive fading of this product. they also have like 7 regular colors, but they can also just use regular automotive pigment allowing them to match any color. Like all the others they have not perfected white and yellow. Just as a note of caution talk with the place that is going to spray your liner and make sure they spray the product to the thickness that they say they are going to. Really all it does is give you a little extra impact resistance and pretty much nothing else but your paying for usually 1/8 to 1/4 inch coverage so if you dont get it they are just pocketing extra money at your expense.
Just had a friend roll on a Herculiner. His labor was $75 and I got the kit for $79 on Ebay. Seems fine so far; we'll see how it goes. It's pretty thick and you can always double the thickness with a second kit.
Can anyone give a web address or 800 number for Line-X? I hadn't heard of them until reading these postings and could not find one. Have a '98 S-10 w/ 6' bed. Anyone have spray-in experiences with similar??
I had a Line-x installed in my new truck in October 1998. No complaints at all. My folks have a Rhino liner and they have no complaints either. I don't think you can go wrong with either. The application is a little different between the two brands. Take a look at some examples from the shop that you are considering using and then decide which you like best.
The only thing to remember is that the job will only be as good as the person doing the spraying. Make sure they've been doing it for awhile and/or can show some trucks they have sprayed. I had my sprayed at the Texas Trick Shop just outside of Dallas which is where I lived at the time.
Thanks alot, Brutus. I looked it up and the nearest dealer to me is pretty far away for the Line-x. I think that I'll go with the Rhino at $360 for the over the rail. Thanks again for the info.
I sell spray-in liners, and have had many experiences with them. I love the spray-in liner for ligt to medium duty work. Plastic or steel liners are still the best option for te heavy-duty work truck(cement contractor). Prefer the Carefree or Line-X linersover the Rhino liners. TheRhino liner is thicker, but it is also a softer compound, causing it to peel away easily. The Carefree or Line-X product is better looking and it is much tougher. It may be thiner, but it has a harder compound than the Rhino. Highly recommend Line-X or Carefree of Chicagoland!!! Also, stay away from colored liners, stickwith good 'ol black.
The spray ins are great except when you dent a surface that has been coated. You can expect some of it to be cut out in order to allow for repairs. Always give and take.
Make sure they put it on at least 1/8" thick. Mine is only about 1/16", and I'm not happy about it, because I don't think it provides any dent resistance. I am hesitant to "throw" heavy, hard objects into the bed, unlike with my prior drop-in. Also, it may cut or scrape off more easily. I have two small cuts, to the paint underneath. The stuff is very expensive. I was told about $1200 to $1400 per 55 gallon drum, and at about 15 jobs per drum, they can save lots of money by putting it on thin. Maybe I'm picky, it is a truck after all, and some may laugh that I don't want to mess up the bed, but, I paid $23K for it, and I'd like it to look new for as long as possible.
Line-x is not intended for dent protection. It would not make any difference if it was an 1/8" thick. The dent protection that is provided by the drop in type is there because of the ribbed construction. It allows the force of impact to be spread over a lager area while cushioning because the ribs will flex under pressure.
I have mine on a 95 ranger and it does its job well but I don't like the looks of it. It's an over the rail, but it seems like it protrudes way more than the ones I see on other models. I like an over the lid liner but would prefer one that is lower profile. Also, it's lost its grip on the bed in a few places. Do any other ranger owners feel the same way? It doesn't look that great with my soft bed cover but I needed the cargo protection. I was thinking of maybe selling the liner and getting a spray in or an under the rail liner with bed rail caps instead
I purchased a Duraliner brand bed liner for my new Z71 this last weekend. It was between it and the Allstar brand both had lifetime warranties. The only real difference was the non-skid option of the Duraliner at $199 and the Allstar was priced at $149. I chose the Duraliner for the non-skid option and it is an under the rail style. The Truck Accessories salesman said it also had a better fit than the Allstar. I did like the look of it better anyway. I asked why the trucks on the new truck dealer lot had Bodyguard brand bed liners in them and the truck accessories person said they put cheaper bed liners in for selling them off the lot. I hope this information helps.
I'm getting a permatech liner sprayed in my club cab Dakota this weekend. Black texturized polyurethane 1/4" on the bottom and 1/8" on the sides for $375, and I can go over the rail for another $25. You can learn all about the product on their website (perma-tech.com) as well as search for a dealer in your area.
I have an Ameraguard spray-in liner in my 2000 Ford Superduty. It is a good quality product that is sprayed in a more precise process than some of the other spray-in products. It has a consistent surface quality and appears to be very durable with a high tensile strength. It compares favorably to Line-X and I like the appearance much more than the Rhino-liners I have seen. From my experience, I would recommend any truck owners considering a spray-in liner look at Ameraguard. As is the case with ANY spray-in liner, look at work samples of the shop you are dealing with. The product is only as good as the technician who applies it.
http://www.ameraguard.com/
Click on the "link to Armaguard" button and follow the link to the bedliner page:
http://www.armaguard.com/pages/armtp.htm
Apparently, the TM Ameraguard is what they market here in the USA with, in Canada it is Armaguard.
Hope this helps.
Gary-
last week.
jlee,
Rich
Gary-
I'll call tomorrow.
Gary-
Turbo
Thanx
Superman
They have a dealer locator on the site.
this topic is being "frozen." It will be archived or deleted in the next 10 days or so.
Front Porch Philosopher
re-opened for business.
