Visitor Agreement.
Great job smoking another coffee can exhaust & wing idiot.
Just do the intake, throttle body and exhaust. That's my theory at least.
RJS - 14.9 is pretty darn fast. Something had to be up with that.
BTW - I glanced through MT's review of the new Accord. 60 in 6.6! Hmmm. I know, I shouldn't even look. Somehow it's faster than a SC 3.8 with the same HP and almost +70 lb-ft of torque (at a WAY lower rpm too - like half the rpm's). I think it had a really goofy 4+ transaxle though, but still.......
Even if the chip does add that much power, or drop times that much, I still wouldn't be interested (if they made one for my car).
6.6 seconds for an Accord... What a joke. When I looked up numbers on my Corvette, back in '87 it did a 6.1 second 0-60 (and that feels about right). So with an automatic, it would probably be about 6.5-6.6. But hey, they both make 240hp... You are absolutely right, there is no way in hell that damn Accord would beat a GTP. I haven't read the MT yet, but now I'm not looking forward to it. C&D pretty much made me sick. They even praised the new thick steering wheel the Accord sports after bashing the idea in an Aurora.
That Accord may have been a manual. I can't remember. I'll have to check the C&D. Anyway, what did your vette have in torque + 120, + 130, + 140 lb ft?? (@ < 3000 rpm?) The Accord is 212 @ 5000+. It weight around 3400 lbs now too for 2003. Unless it's torque curve is really flat (like the Aurora or Intrigue 3.5) that 212 way out at 5000+ is weak. Even if it is flat, that's still not a lot to launch a car from 0. Ever since the Altima and G35 flap, we are going to all sorts of crazy stuff.
He said he got the Superchips chip, and then sent the whole PCM in to be reprogrammed (apparently they change the shift points and such too). He also cut the cat off and replaced with a straight-pipe (although he might mean the resonator as many people confuse the two). He also cut out the bottom of the airbox and has a K&N. He said the day was cool. 80 degrees max, but I don't think he remembers specifically what the temp was.
The 'vette made 345 lb-ft at 3200 rpm (maybe 3600?). Only the 2-door Accord V6 will have a manual option. But maybe that's what MT tested. Yes, I think the Altima has made it more of a necessity for competitors to lie/cheat too.
Finally finshed painting my shield today, took pics of everything, I'll take a couple more at the track tomarrow and get the roll devolped ASAP. Pics by the end of the week for sure this time.
Taylor
http://www.cardomain.com/id/800wattaurora
Mike98c, that's pretty interesting about the cat. Were there pieces that were rattling around in it? That sucks when that happens. It sounds so annoying. Well, now you've got some free extra power. I imagine it will have a pretty insignificant effect on your emissions.
Mike98C - that is really interesting. Now I wish I didn't have that cat. If it was removed or gutted, would this hurt the operation of the car in any way? Of course this is not legal, so this is all in theory - right?
I did see one out of the box and there sure seemed to be a lot of screens or whatever for the exhaust to pass through. It sure seemed restrictive.
Mike - how did you get it off to work on it? Any special tools or ramps?
High flow cat - yeah, I'm pretty sure they are all the same except for maybe a better inlet and outlet design. You have to pass the exhaust through a certain amount of media to meet regulations. There doesn't seem any way legally around that. That's my understanding after looking at one.
Mike - let us know how you accessed your converter.
Garnes, I dont' know what they measure or how they work, but the second O2 sensor behind the cat is specifically to make sure the catalyst is still working. That is part of the EPA's OBD-II. The car has to be able to determine if the cat is working. Most of the OBD-II is environmental stuff. It's just that it involved so many sensors and such that it also means the cars can track much more. That's why not tightening your gas cap can trigger a light. The EPA requires this so that fuel vapors don't pollute the air.
A car length?? That's not much. As fast as the G35 is SUPPOSED to be, you should have been crushed like a bug. Maybe I'm wrong, I didn't do any calc, but at 60 mph, 200 inches should go by really quick. Hmmmm. Something is up with your 97 with the 3.48. It sure holds it's own pretty well. You have the best stop light olympic stories.
To bad it wasn't a black 98, with the 3.71, airbox mod, K&N, throttle body, and Corsa. Heh Heh Heh. I'd love to see that "look" you describe from the other driver.
Garnes, you need to take your car to the track.
OK, I did the math. Using 200 inches as an approximate car length (bigger car), at 60 mph, that's about .2 seconds. Just goes to show that every little bit helps too.
Own a G35? I don't think so! I'll keep my Aurora and work to improve it. Greg is way ahead of me there, but I have the air inlet improvements. One of these days I'll finish installing the MSD capacitive-discharge ignition.
MSD makes a wide variety of automotive ignition systems for street and competition. Take a look at their website www.msdignition.com. I bought their DIS-4 part number 6615 capacitive discharge ignition. It provides higher primary voltage to the stock coils and delivers multiple sparks for about 30 degree crank rotation. There are reports of lower emissions and increased power -- which is obviously of interest, but I am not convinced.
For me it is an experiment, like working to improve the air intake. Plus, I'm an electrical engineer and love to try new technologies.
Taylor
Keep it up.
if it was stick shift even faster
what do u think about putting nitro on v8
i wanna try.
anyone timed 0-60mph?
let us know ,,,
As I mentioned on another discussion, I am seriously pursuing an RSM Racing throttle body.
Does anyone have experience with blocking off or rerouting coolant flow through the throttle body? The added heat is needed for good drivability in cool or cold temps, but seems to be a detriment to performance at high temperatures. I'm looking into some kind of a manually activated valve that I can insert into the throttle body coolant inlet hose.
Go for the 80mm throttle body!!! Get the plate behind it. I think all 96+ caddies have the same TB. Needs to be an obd-II 4.6 to be identical to our 4.0 classics. Check with RSM to confirm this though.
Coolant by-pass, It would be a very easy to do. Having taken it apart, all you would need is a say 4-5in piece of metal tubing, the same size as the tb connection, probably 3/8in or close to it. There's 2 good clamps holding those hoses on the tb right now, just unplug the lines and hook up both coolant lines to your tube. Just thinking about it makes me want to go do this mod now. Think I will once it gets a little warmer, the heat has to hurt the performance in the summer, I will also swap back to it's next winter. Good plan 97!
There I was, first in line at a red light. To my left, an Accord coupe, black with tinted windows and some chrome aftermarket wheels. Nothing outrageous, probably 17's. He had weaved through traffic a bit to be up front next to me.
As we sat there, I got the feeling he was going to try to take me. I don't know why, I just knew he would. When the light changed, I gave it about 1/2 throttle just to see what he was going to do. He hammered it from the light and put my bumper about next to the back of his door.
No way that was going to happen... I cracked the throttle to about 3/4 and felt the wheels scrambling to put that 260 lb-ft to the ground. At this point he was getting a solid earful of each one of those eight 1/2 liter powerhouses, and was probably wondering what he had awoken. As I feathered the gas further open I could feel it slipping and gripping. Even at about 40 mph the motor was still pulling those 235's loose. Amidst this scrambling, I put my car even with the Accord. By 65 mph I was walking away from him, and by 75 mph I started coasting and lightly applying the brake.
He flew by me after that, but I'm sure he felt no joy in having to do so. I caught up with him at the next light, and he never saw the front of my car again...
Yeah, it does get me. I never get a chance to do that. Oh yeah, I blew out some obnoxious rust can Astro van that was really asking for it. Oh boy. That does not count.
So what to I do? I change lanes to pass him, only to have him speed up again so that I could not pass him. Forgetting what I was driving I hit the gas to put an end to his nonsense.
BUT BUT BUT
I was not driving the Aurora.
While not an Astro Van, being toyed with by a Grand Am is no fun. MAN O MAN did I miss my car!
Henri
I've gotten various cars to 130 mph (haven't tried with the Aurora though) and it's not difficult for any reasonably powerful vehicle. But I think the lack of traction in the salt, and possibly reduced horsepower from the elevation, really kill a car's performance.
It does sound like a blast though.....
When he eventually caught up at another light, I noticed him in my rearview furiously pushing his remaining hair over his increasing bald spot. He was travelling the same way as I was for a while, and I continued to drive safely aggressively while he continued to struggle to try and keep up.
I just found it a bit amusing, and I think the moral of this story is that if you are a middle-aged guy who wants to play boy-racer, don't buy a V6 Accord unless you want to play boy-racer-in-second-place everytime you go up against me...
Hey, doesn't your Aurora know that new Accord is SO fast? After all, it's in the magazines.
