Frosted over Antifreeze
fleetwoodsimca
Member Posts: 1,518
Kirstie (properly) shot the previous title concerning this topic in the... foot because it referenced the Corolla automobile in the title, so I am hoping to get some information flowing where coagulation reigns! Here is a cut and paste of my only entry in the now defunct antifreeze conversation-- only slightly modified for clarity:
Do some other folks out there feel a bit put upon, as I do? Several years ago, I bought a new car that I came to realize had come out of the factory with a "special" antifreeze in it. Probably to help identify it, there was a distinct orange color to it. A friend at NAPA warned me not to mix green or yellow with the orange. He wasn't sure what the technical reason for that was. Here in 2002 I have only recently found out that the two groups of antifreeze REACT with each other in some variety of chemical way that may coagulate your cooling system! I am more than just a little displeased that this horrific circumstance has been treated in such a casual way by automobile manufacturers-- or am I the only guy in North America to miss out on the information from the beginning? I would really like to get to the nitty gritty on this topic. Can you supply definitive information, and/or opinions?
Anyway, I was always led to believe, obviously falsely, that antifreeze was antifreeze -- basically the same active ingredients. My Jetta manual doesn't say anything about a specific antifreeze. Odd, considering it's about a 10-part manual. Guess I'll have to go to the dealership for a flush & fill rather than a top up.
kirstie_h
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
playing around with Da ISH today, I find that ChevronTexaco Inc. says that ain't the case, at least about the purity requirements, it can be mixed if you want the corrosion protection damaged.
the link is below... note the only differences between Dex-Cool and standard green, yellow, or red ethylene glycol antifreeze is the corrosion inhibitor chemistry and the squirrelly orange color.
now I'm getting confused as well.
as always, because of size limits on links here, this will need cut-and-paste to get into your browser find window.
<http://library.cbest.chevron.com/lubes/ - compprd9.nsf/c88c682625e06af6882568db00737ce8/ - ab30f4d48c33f01a88256b53007f1f4c?OpenDocument&Highlight=0,dex-cool*>
I'll check it out.
A few minutes later: Nope! I can't do it that way. I'll spin cast for it... (:o]
And even later: Check this site. The coolant is getting less clear yet!
http://www.peakantifreeze.com/faq.html#I
let's see what else is on Da ISH about orange cement. it's for sure that if you have a low level, aka not being refilled from the overflow jug, half the radiator core is uncovered, etc, you get the uglies in the system.
http://www.penray.com/bulletins/ -
compatibility.htm
cummins engine has had a slug of leak issues, and put out co-branded advisory letters to mix a special supplement into any cooling system on their engines that used texaco extended life formula DexCool-compatible concentrate.
noat_failures.htm
got pointed to these items from the first DexCool link on google! there are a tubload of "ruined my engine" items following below.
I think the best thing is to READ THE LABEL!! the big diesel guys are basically saying, if you mix the organic acid (red or orange) coolants with anything else (yellow, blue, green) you get precipitates.
noatcomp.htm
http://www.penray.com/organicacid/ -
evolution.htm
-0-
I expect that the full site at www.penray.com is required reading if this interests you... and certainly doing a google search on "dexcool" to see who else has staked out ground for a bar fight.
my local newspaper/TV autos reporter had this article in may, 2000... where GM also warns of issues, and his basic response is, no such thing as a free lunch, change it regularly anyway.
http://www.startribune.com/ -
stories/435/21199.html
and here's another web site where 3 pages also contain information that DexCool also causes issues in Ford V8s. my, them boys get around....
http://autorepair.about.com/library/ -
weekly/aa052601a.htm
My preliminary findings are that America's drivers would be better off with only the green and yellow varieties, and no complications!
