Any battery problems after vehicle sits unstarted for long periods?
ronerhodes
Member Posts: 3
Went on vacation for 2 weeks and the battery was drained upon return. Dealer said this is normal for this car. So, you can't leave a car unstarted for long(?) periods unless you have a method to jump start. Any solutions?
The charger crack was a little bit off, but you might want to look into one of those battery pack jump starters to keep in the trunk, just in case for the next time you have to go away with your car in the lot. There are also solar chargers that sit on the dash too, that should maintain a charge. You can find both at different places, but to get an idea on cost and what they look like try http://www.jcwhitney.com
Batteries can be load tested for defects. This isn't rocket science, and the dealer should be able to tell you the condition of your battery.
If it goes off enough times during the two week period, you will have a dead battery.
TB
They ended up having it in their shop for 8 days and finally isolated the drain to a faulty rear hatch power locking mechanism. Took 2 days to get the part, and then they forgot to reprogram the keyless entry so that my key fobs would release the rear hatch. (I found this out *after* loading the rear cargo area clear full and then couldn't get the lift gate open).
I don't know if my problem was just a quirk, or if there is a batch of bad rear power lock out there causing your problem, but it might be worth mentioning to your dealer......good luck.
it also raises the most alarm when the security pukes started re-evaluating things in the past year.
so you just park up on sniper's row, put the solar battery on the dash, plug it into the power socket fka lighter socket, and turn off the sirens etc. on the alarm box.
or, yeah, get one of those gelcell battery backs that is supposed to get you back in action fast and try that once. in my personal humble opinion, that's too small a battery and too thin a wire to crank your car.
the auto equivalent would be to fire it up weekly, run a minute or two, and top off the battery with the charger.
for long-term storage, it would be disconnect the battery after pulling the plugs and spraying a little mist of fogging oil into the cylinders. also tie a bag across the air intake to help keep the mice out.
is also not recommended. Running for only a minute or two will dump combustion by products (like water)into the oil without the oil getting hot enough to cook them off.
New car batteries should be able to keep their charges for long periods of time. My '93 Saturn sits for periods of up to a month and never has a problem starting. It's battery is about 3 years old.
I'm not sure of the cause of the battery drain. My gut feeling is that the problem is related to a door or hatch not being fully closed.
