Chevy Silverado: Problems & Solutions
Open your e-mail on your profile and I can send ya
a diagram with locations................
http://gm-trucks.com/home/content/view/123/25/
-David
-David
NOT a pushbutton correct?
Have you checked all the fuses?
BTW: Your e-mail link DOES work now !
You have mail !
kcram - Pickups Host
No the radio is not junk... You can bring the truck to your local chevrolet dealer and for about $10.00 they can reset the code and write it down so you have it next time you take your battery out.
Ray T. :shades:
at the bottom.. once it was replaced it hasnt died and its been over a year.. and it also stopped my belt from sqweeking
Maybe this will help you..
They quoted 566.25 for the part and 170.00 to install .
I said no thanks because it doesn't stay on all the time.
Any thoughts on this or where I can get a cheaper part.
it is an automatic
only. I can send you instructions on how to unlock
your NON- RDS GM radio............
If it is a RDS unit you must take it to the dealer.
It sure has a lot more pep along with a few more mpgs.
The only thing I do not like about it is it does
not modify the torque mgmt. system in the GM 6.0/8.1s.
With both handhelds you can change settings at will
or remove the tune entirely if a dealer visit is
necessary.
My next tuner will prob. be a Diablo Preditor which
will disable or modify the torque mgmt. settings.
I did consider a PCM burn tuner but have read that
the GM Tech machine can detect the altered settings
and erase them if a GM updated mod program is
programmed in by the dealer..................
Tough choice..........But happy with mine !
I finally got my truck back into the dealer. My speedometer was stuck at 130! I had the extended warranty and so they replaced the whole instrument cluster. Problem solved. Not sure what this would actually cost if you have to pay for it.
Patrick
Thanks Trucky
People tend to clean the cable terminals at the battery, but often forget the other cable ends, which are just as important. For example, if the negative battery cable connection to the engine block is loose or corroded, current will not flow properly and starter needs a lot of current.
There is some info on the web (try searching for NV3500 gear rattle). You might also check Dodge forums as the NV3500 is/was used in the Dakota and 1500.
The NV3500 is the weak link in a 1/2 ton truck drivetrain (really a mid-size truck tranny, GM won't even install it in an extended cab 4x4). Look at the tow ratings with 5 speed vs auto. The 5 speed is ~2,000 lb less (limited to 10,000 lb CGVW, if I recall correctly). Perhaps if GM installed an adequate transmission, it might operate a little more smoothly.
Why don't they just use a heavy duty manual 6 speed transmission that they use in the 2500 series, in the half ton version? The 6.0, 8.1, and Duramax engine trucks are all available with heavy duty 6 speed manual tranmsisions (and I assume heavy duty clutch too). The clutch is typically the weak link that limits the tow rating capacity with a manual tranmission. The best manual transmission in a pickup truck IMO is the Dodge Cummins pickup 6 speed manual. This Getrag tranmsission is supposedly also used in larger commercial trucks and the tow rating is something like 13,000 lbs.
Any suggestions?
It's unfortunate that GM uses a transmission unfit for the power or CGVW of a well-equipped truck. Let's hope they address this in the 2007 redesign.
It's clear why the weak NV3500 is only available on small-motor, regular cab trucks, but (somewhat off-topic) Can someone please explain why they don't offer a plow-prep package on 1/2 ton, extended cab models?
Most of the time the shift from low to second is very hard. Very seldom the shift is so smooth you almost can't feel it. Harder acceleration will usually make the shift smoother but no guarantee. Hauling a load will usually give a smoother shift. I've tried for 40,000 miles to learn the "trick" for getting a smooth shift but can't figure it out. As usual the dealer service department does not have a clue. Anybody got any ideas on how to make this transmission shift smoothly?
