Odyssey Remote Engine Starter
I have a 2000 Odyssey EX. I have have played with the cars remote control and there is a sequence of buttons that will start the car remotely. I can not figure the sequence out and reproduce the starting on a regular basis. Does anyone know how it works. Any dealer I ask denies that the car has this feature. Thanks
The kit was $80 shipped to my house. It included the additional relays needed for my trunk release and the positive lock system GM uses. (The module supplies a ground when you press the button, so you use the ground provided to trigger a relay that provides the positive to the power lock or unlock circuit.) Another $10 for connectors to splice into the wiring harness and I'm done.
This kit locks the doors before you start the car and will kill the engine if the brake pedal is pressed, the hood is opened or you press the start button the key fob a second time.
If you can do it yourself, it can be done for well under $100
TB
