A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Pace Edwards Roll Top Covers
They say snow dosen't hurt it. They have more info
I heard these covers tend to vibrate and be very noisy. Any truth to that?
Stephen
http://www.calconcepts.com/SolidBedCovers/Retractable/rollnlock.html
Please keep me posted I am getting one in the spring. Since I don't have any dealers in my area, will have to make a decission and mail order it from the manufacturer.(stevek@bestweb.net)
Here is a link to where I bought it from:
http://www.salesco.com/truck/aerocover.htm
Thanks to clappj for the link to calconcepts in Post #10. I first found the Aerocover there, but their price was about $20 higher than Salesco.
I'll post the results with it after I have it a few weeks here in the snow, sleet and rain of Pittsburgh.
Terry
Please keep me posted, at this point I gave up on which one to get, got totaly confused. They are far between to have a good oppinion. I am keeping my soft cover for now.
r-n-l works better because of less flex in the top. Both appear to allow some (amount unknown)water in around the tailgate? I think the pace edwards would certainly do the job if you knew someone wouldn't jump up on it. They look almost identical except the pace edwards has a vinyl type cover over their aluminum compared to the black aluminum of the r-n-l. I would compare the pace edwards to a tonneau cover that locks and the r-n-l to a fiberglass cover that rolls up. I haven't decided yet. It was nice that I got to see both on new silverados. The custom shop had five silverados in for various accessories. I did get to see nerf bars, bug shields, different bed liners, and a fiberglass cover. It gave me a few ideas.
Considering the respective prices of each, which would you choose (if either) for normal, everyday duty?
Thanks for the info, I am looking to replace my current soft cover for some security. Sounds like I can go with the cheaper one.
I think I could live with the Pace Edwards and $400 dollars towards other items. This dealer has been around for years and is well respected. He apparently sells a lot of them. They were adding one to his brothers truck when I was in. I can't see doing that if they didn't work.
Where is your dealer: I am in upstate NY. Do you know of any dealer around this area? Thanks
If you buy the Pace Edwards(which I may also) just put a 90 degree latch on your tailgate with the other end attached to the side. You can do this on both side or just one. Dont forget to put some rust inhibitor in the drilled holes before you install the bolts for the latches. You can buy a latch in any hardware store for less than 5 bucks.
What did you end up having to pay for your cover and what area of the US do you live in? I am seriously looking at getting one for my 1999 Silverado to go with the molded carpet bedliner I just ordered from the Bass Pro Shops Truck Acc. catalog ($259).
Sure would've been nice if GM had made the gate lockable like Ford does. (one of my very few complaints about THE TRUCK)
Also, I ordered a carpet bedliner (Steel Horse) from Bass Pro Shops for $259. I'd seen the same thing elsewhere for $299. The day it arrived, I got a Cabela's catalog in the mail that had the same liner for $199! I called Bass Pro this morning and told them about Cabela's better price They refunded me the difference with no argument whatsoever.
Installed the carpet bedliner this evening. It took a couple of hours, but I've got it in except for a few minor adjustments at the front corners to take out some wrinkles. Overall, I'm pleased and think it will make a great combo with the Pace Edwards. Also, ended up saving about $150 compared to the BedRug liner which appeared to be only moderately nicer in quality. Besides, nobody will see it with the cover closed.
Keep me posted the pace is a lot cheaper and I plan to get it in the next couple of months. There is no dealer in my area and I will have to install it myself.
I was deciding between the Pace and a hard tonneau like the A.R.E. which was around $750 in this area. The fiberglass tonneaus are prettier, but I went for the functionality of the Pace. The price difference wasn't really a big factor.
I watched the install which took about 100 minutes and advise anyone who is doing it on your own to take your time and be careful since the process requires the drilling of about 6 holes on each bed rail. If at all possible, I'd have it installed by someone who has done it before.
The cover moves pretty easily. The shop said that it would improve a little with use and to put a little petroleum jelly on the rails monthly to keep it smooth.
It looks better than I expected and I am pleased that I went with this option over a hard tonneau since the Pace seems much more functional. Now I just have to decide on a lock for the tailgate (Chevy should take a hint from Ford in that area). Pace offers a Powerbolt lock which wires into the electric door locks - about $100 installed.
Glad you like the pace edwards. I am planning on having mine installed in two weeks. Have you noticed what it does when driving? (vibrate, bounce up and down) I think I read here that chevrolet has a lock for it? I will call my dealer and check. The salesman wanted me to buy the power lock too. Does your top close tight to the tailgate? Did the dealer suggest you cover the post holes to keep water out? You should get better gas mileage. Good luck with it.
I have two quotes at $599.00 installed in minnesota.
I think that I will call Pace Edwards and see if there is another dealer in my area that's cheaper.
How do you like your pace after having it on for awhile? Do you have any bounce when it is at high speeds? What did you decide about locking the tailgate? I asked at my local dealer if chevy had a replacement handle with a lock. The dealer had not heard of one. The accessory company is really trying to push the automatic locking feature for a $100.
I too have been trying hard to see if there is a replacement tailgate handle that locks. My Chevy dealer hasn't found one yet. I'll likely opt for the $100 (installed) power lock before even seriously considering the Pop-N-Lock or drilling to install any other type of lock.
I highly recommend going with the carpet bedliner unless you're going to use the bed for dirty type hauling
I was at the chevy dealer last friday getting my oil changes (they had a special) and picked up a copy of the new GM Silverado Accessary catalog (planning to buy a Silverado in near future). I noticed a really good looking locking tailgate latch near the last page. It seems to replace the current tailgate latch handle. The parts guy looked it up in the system and quoted me a price of around $49. It looks like what comes with the truck except for a key hole on the right side below the handle. I've already added it to my list of "must haves".
I stopped off at two chevy dealers and both came up with nothing with regards to a locking tailgate latch. Could you by chance get a part number from your dealer? What catalog are you looking in? Is there a separate accessory catalog? I did get a part number for a lock on a hard tonneau cover/tailgate etc. ???? The parts guy didn't know exactly what it was.
(PN 12361309) I'm planning on mailing the chevrolet customer service to see what they say.
I left the catalog at home. Will try to look it up tonight. The catalog is a separate catalog full of accessories specifically for the new Silverado. I'll try to post the catalog number also.
Anyone have any suggestions for covers to seal off these holes that would work with the P-E cover?
Aloso, ANY info on the locking Silverado tailgate handle accessory would be very much appreciated.
The "Locking Tailgate Handle" is pictured on the last page and the text next to the picture says "Rest easier! This locking tailgate handle will give you peace of mind as it adds an extra element of security to your truck bed. Molded and designed for a sleek, integrated look. For a complete list of part numbers, please see your Chevrolet Truck Dealer." Unfortunately, no part numbers are listed. The person at the parts counter at my local dealer (Al Serra Chevrolet in Colorado Springs) did not seem to have too much difficulty looking it up in his system though and quoting me a price. Unfortunately, I did not take time to get the part number from him since he didn't seem to have any problem looking it up. If everyone continues to have trouble finding this, I'll try to stop by the dealer sometime in the next week and get the exact part number.
In any case, I really recommend you get a look at this catalog. It has everything from mud flaps to bedliners to brush guards to hitch packages to a 12-disc CD player. All made especially for the Silverado. Good hunting.
I e-mailed chevrolet. They informed me that I needed to get that information (locking tailgate part number)from their highly informative parts departments at my local dealers. I mailed back stating that three highly informative parts departments didn't know jack about it. I did ask if they could send me the accessory brochure you informed me of. If you get the time I'm sure would appreciate the part number of the lock you are talking about.
kent123,
Any luck on the stake pocket covers? We have all seen the covers that have hooks in them so you can tie things down. I don't care for them because they stick up about the bed rail, but you might be able to modify them to your liking? Where you getting a lot of water inside under the cover? I was informed that there wouldn't be too much coming in from the stake pockets.
I had found some covers that don't have the hooks sticking up, but they were a smaller size than what is needed for the Silverado. The search continues.
Many thanks to jmscolorado for the locking gate info.
The catalog I referenced earlier has tie-down hooks listed that pop up or lie flat and fit in the stake pockets. The part numbers are:
Stainless, fleetside, longbox....12496071
Stainless, fleetside, shortbox...12496072
Black, fleetside, longbox........12496073
Black, fleetside, shortbox.......12496074
The picture shows them to be pretty flat but they do stick up the thickness of the flat metal, probably a 1/16 of an inch. Check them out; maybe they'll work.
