Visitor Agreement.
Thank you,
Tia
I have a 95 grand prix gtp. Had a coil replaced before that, wish the guy would of told me the igination control module module was weak. Could of replaced it at the same time.
Does your AC fan work or is that not coming on as well?
Any computer error codes ahowing up?
The only way i can get the motor to smooth out and run is to crack the air filter box about a quarter of an inch. As soon as i close it back it starts sputtering and jumps up to about 3000 rpms and then stalls after about 15 seconds. When put on scanner it codes purge valve. Does anyone know what and where the purge valve is and it's purpose. Any info at all would greatly appreciated Thanks D.T.
Thank you for your help.
JJ Pierce
I am also experiencing this problem too. It started for me on July 2nd. I could not put my 2001 Pontiac Grand Prix GT into park; it was stuck in reverse. I had to put it in neutral and put the emergency brake on. My key was stuck in the ignition. I could not get into the trunk until I got home and used my spare key to open the trunk. I took my car to my usual mechanic. We could make the gear get not go into park. THen it went into park and got stuck there. My mechanic thinks it may be a solenoind that needs replacing. However, the mechanic was unable to replicate it again once it was in the shop on Friday. I picked it up today and am driving it for another 2 days to see if it comes up again. Have you got any further information? I recently had a problem with my key not turning all the way to the position to get the key out of ignition after turning off the engine. That went on for 3 months. I finally had the key lock indicator replaced and that did the trick. But now, the not being able to put the car in park problem has creeped up.
Any ideas???
If anyone has any suggestions I would greatly appreciate it.
I am having hesitation problems with my 2000 grandprix GT
when excellerating at about 10% throttle i get hesitation any where from 50km to 100km/hour. It does this between 2000 and 2400 rpm when it get's to 2400 it drops to 2200 even with the same amount of gas (foot has'nt moved). I have run fuel injection cleaner thruogh it as well as changed the fuel filter. I have taken it to the dealer(I have a friend that works there) we took it to for a long test drive with there scanner and nothing came up no codes at all.
any body have a solution to this problem?
thank in advance
Thanks!!
Today, the problem wouldn't clear and I noticed the following. With the fan switch set to positions 1 through 4, the lights don't come on and there is no air flow. Turn the fan switch to off and the lights come on. Turn the fan siwtch to 5 and I get air and lights.
Would sincerely appreciate any ideas.
I have the same problem with my 01 grand prix, did you find a solution? these crazy locks are driving me crazy
The symptoms were that the car was hesitating or missing. It would miss at idle as well as driving at various speeds. We first noticed the problem a week and a half ago and went to two mechanics who were not able to fix the problem. We changed the fuel filter and spark plugs, put in a fuel injection cleaner, to no avail. When they hooked up the car to the computer it would miss on one or more of the cylinders randomly. No codes came up and the check engine light never came on at any point.
We finally decided to go on a trip to see if some miles might help clean out the fuel system, but as we drove it got progressivly worse. (It began to miss on all cylinders at different times and still no check engine light.)
After 4 1/2 hours of diagnosing, a complete fuel system cleaning, they finally guessed that it might be the ignition control module...a $200 part alone without labor. We put it in and no problems since.
Hope this helps someone later as it was a huge hassle for us.
Ken
