Triton V10
Just thought we should have some input regarding
the V10!!
the V10!!
Yee-ha
I know the Dodge has more HP but HP is'nt everything!!
Comments anyone???
moe7
I agree 100%!!!!
moe7
Look at the number of TSB's for this year's model. At last count the Ford had 1 and it was of no real signifigance, while the Dodge had 10! I also looked at Dodge before I ordered my Ford. The problem was that most of the Dodge owners that I talked to always seemed to have a bit of hesitency about their truck. While reading about the Ford, I did not read so much as a suggestion of regret. Now that I have my own F250 SD I can honestly attest that it is more than I expected. But you have to make up your own mind. I'de thought that I'de put in my $.02 worth.
I've had this 99 SD F-250 V-10, EOD 4speed since August . Towed a 26 foot 7500 Pound Tag-along Travel Trailer from PA to California to Texas, 12,ooo miles on it now.
Rear axle is 3.75, and tows fine as long as you remember to lock out O/D. Otherwise, it will downshift way too much.
O/D is for empty highway cruising, not towing. Fuel consumption towing in O/D is no better, and tranny strain is certain to cause problems down the road.
Fuel consumption has averaged 9 MPG towing
12 solo
Factors such as mountain grades, headwinds, and hammer down speeds will definitely have an efect.
Altitudes varied from 285 feet below sea level to 10,000 feet.
Overall, I am satisfied with this engine,towing load combination. If I decide to buy a larger, heavier trailer, I will definitely upgrade to the PSD and install a Jake Brake,and opt for the Manual tranny.
Logic is that for serious towing, do what the trucking industry has done for the last 100 years.
Where can we find TSB's for Chevy, Ford, and Dodge? Is it available on the web?
It would be great to have access to them!
I ordered my F-350 4X4 V-10 cab and chasis XLT package on 2/2/99 and it arrived on 3/4/99 to my surprise. The flat bed will be installed during the coming week. I inspected it on 3/5/99 and was impressed with the quality in the engineering of the unit. I crawled under it to look everthing over. I was impressed. I noted the lift blocks between the rear axle and the frame. I may need the truck lowered to fit my gooseneck trailer. My dealer said it was a warranty item and they would lower the truck if needed at no cost to me.
Is there an after market chip that will improve the V-10 engine performance??
The TSB's are available on the web. www.nhtsa.dot.gov/cars/problems/tsb and www.alldata.com
Yes, that is dot between nhtsa and gov. You can find info on recalls and tsb's on any auto
Tom50
Thanks a bunch!
Thanks! Good Luck!
JB, aka Singer4
