Oil Pan Gasket Replacement
I am tempted to replace the oil pan gasket for our 92' Cont. this weekend. Has anyone done this before, or have the information describes the steps/procedure that could be of help? TIA
It's very unusual that a bit of tightening wouldn't cure an oil pan leak.
Our host gives good advise. Often the oil is leaking from something higher in the engine making it look like it's the pan.
Shops hate fixing oil leaks.
and you're unhappy with just a drip? cars leak, man.
if it's a serious leak, it's worth chasing... but do so by cleaning the engine compartment up first and then use a black light to trace the dye in the oil back to where it's coming from. fix the right thing if you absolutely have to.
Anyway, to get to all the oil pan bolts, I have to take off the starter and the fly wheel cover. That is not too bad. But to drop the oil pan, I will have to drop the down pipes and the catalyst converter. It very hard, almost impossible, to reach the nuts at the down pipe and the exhaust manifold, especially the rear one, and I also afraid to strip the nuts since they look rusty and already a bit round.
at that point, "in for a dime, in for a dollar..." might as well hoist it all the way out, put the engine on a stand, and rotate it 180 degrees so you can scrape, degrease, clean, and stickum down the new gasket real good on both sides, torque it to 70% all the way around in criss-crosses, let it sit a little, and then torque it down all the way in criss-crosses.
or, just tighten up what you can using all your flex joints and extentions while it's in place, and call that good enough. before putting in the extra dye (oil has one kind of fluorescent dye already in it, tranny fluid usually a different color,) use some degreaser and a wand car wash and get the engine clean enough to eat off of, then run it a while and use the black light to look for where the leaks REALLY come from.
The time and expense is out of proportion to the problem I think.
the good news is that all the computerized yee-hah that costs a ton to repair is much more reliable and trouble-free than the whistling old carburators, vacuum-dashpot adjustment links, spark-advance levers, relay-type voltage regulators, and scummy rubber-cased batteries of just a few years ago.
there is still plenty to go wrong on a ride, though. and they all wear out.
The high maintenance items are the 3.8 head gasket, the weak transmission, the suspension air bags, electrical things like intergrated signal switch, head lights switch, brake light switch,...
I also have a 91 3000 GT VR4, one year older then the Lincoln, so far has no leaks anywhere, knock on wood.
