Chrysler PT Cruiser Owners: Problems & Solutions
my wife recently bought a 2002"WOODY" PT. MY question is what kind of wax do you put on the "wood". My dealer has no idea what so ever. Does any body know ?
The next time I refuel, I plan to keep clicking on the handle (topping off) several times to see how much more gas I can get in the tank. Has anyone else experienced this?
Also, I recently parked overnight on a slight up hill, with the gas gauge indicating 1/4 tank when I shut it off. When I started up in the morning, the low fuel light came on instantly, and the gas gauge showed in the red zone, less than 1/8 tank. After driving on a level road for several miles, the gauge was back at 1/4 tank, but low fuel light stayed on. OK, the incline caused the gauge to read low, I figure...no problem. I shut off the car, parked on level ground, and later in the day, the gauge was still at 1/4, and low fuel light stayed on. Doesn't the light reset with the ignition if it is now above the trigger point?
Thanks for any input.
DWL
I am 6'3'' and would like to lowr the seat by about 2"
While mine has not been totally trouble free, the dealer (Rancho in San Diego) has been outstanding and has made necessary repairs quickly with no hassle.
We are thinking of buying an 02 Cruiser Touring auto for the missus.I think I can get it for $12750, maybe 12500 from a dealer. It has 18000 miles on the clock. Can someone give me comments on the cost of running, servicing intervals and servicing costs and reliability. I know some think the 2.4 is underpowered with an auto, but for our use it will be fine. Coming from the UK, I will always choose auto. I used to change gear 1100 times a day on average!! Thanks in anticipation.
Ian Jennings
Mine is a 2003 GT and has had one significant warranty repair besides a routine oil change. Most owners I have spoken with say their PTs are very reliable and have been virtually trouble free.
People have complained about the PT being sluggish, I would class the automatic as adequate. My 5 speed is a bit peppier than my wifes automatic but I have no problems keeping up with traffic in her car and heavens know that enough PT owners have managed to get speeding tickets. There are very few owners that are unhappy with their PT's.
We will be exchanging from a Grand-AM 2.4, also with 150 b.h.p and automatic. We average about 24 mpg around town and about 31 mpg on a run. In true GM tradition, top gear is very high and you often have to chnage down to 3 when going up an incline,so the PT wont be too different. We will get a test drive and see.
One thing that disturbs me. I have learnt that ABS is an option which i personally feel is absurd!! This is a trend i feel needs reversing. It is the same on GM in the USA and UK where i come from. Am I right in saying that if a PT has rear drum brakes it has no ABS. If it has rear discs than it has ABS? Does anyone know this?
Thaiks and regards
Ian
My newer cars seem to tolerate the winter fuel better and so far I have not seen this problem with my PT GT even though the underhood temperatures get very high after being parked for even a few minutes.
I'm wondering if there may be some sort of delay in the fuel pump getting gas to the injectors on warm start, or an electronic malfunction in the fuel mixture controls for warm starting? I'm not very up on today's electronic systems in cars...
I was able to demonstrate this condition to the service writer at the dealer, and his comment was " boy, is that subtle!" HA! I know this car, for 20,000 miles it has started on first turn of the key everytime. Something is wrong. Maybe it's time to try a different dealer. I'll post again after refueling.
I really like this car, and this slow staring is really bugging me. Any other thoughts anybody? Thanks!
The service manual only shows a LB wire running from the fog lights to the switch (the front fog lights are operated by pulling out on the end of the light switch on models that come with front fog lights.
There is a large wire bundle visible next to the right front high beam headlight and that may contain the wire to the fog lights. I can see a LB wire in the bundle on my PT.
None on mine so far.
Anyone know how to find out what bolt is used? It has a hex head and is threaded into the car frame. There is no access for a nut, btw.
Jay
If there is nothing wrong (no excess electric draw), your battery may be weak. You might also consider installing a more powerful battery.
I have heard a number of people that claim that if just before you park, you turn off your A/C and run the blower for a couple of minutes, that helps cut down on the smells. Apparently it allows the ductwork to dry out so that mold can't form.
Sometimes where you park can cause water to collect in the evaporator case. If the drain is not the lowest point, when parked, water stays in the case and becomes a breeding ground for mold and mildew. For example, if the drain is near the back of the case and you park with the car pointed down hill, some water will remain in the case.
Brake dust? My wheels used to be chrome color. Takes a day for them to be covered in brake dust. I'd change my brake pads except the factory ones stop well and will probably last 100,000 miles.
I didn't mind the mpg until gasoline prices went above $2 per gallon. At $2.30 per gallon now common around here mpg will be a major consideration on my next car.
Brent
I got a 27" television this Spring, I had my two sons with me at the time. I had my one son up front (he was big enough) and the other son in his booster seat on the 40% portion of the seat, with the 60% portion flipped forward. The Television slipped neatly into place.
The parcel shelf is very handy as well for tailgate parties. There is also a power outlet back there for pluging in a portable radio or something of that nature.
Just the other night, I had myself, my best friend, her 2 toddlers, and her niece (who is 10) in the car and everyone had enough space to be totally comfortable. I am totally thrilled, as my last car was an 02 VW Jetta which had no room in the back seat when I was sitting comfortably in the driver's seat.
After owning this car since July 9 and for 6500 miles, I can honestly say it's the most versatile, accommodating vehicle I have ever had (out of 7 cars, from a Cavalier all the way to a Bonneville).
We have found that the Cruiser is longer and taller inside than our MDX and as a result has carried items that didn't fit in the larger car.
My old 1984 Toyota Van was only about 6 inches longer and about the same width as the Cruiser, but it easily sat seven real adults and took their luggage at the same time. It also held 4x8 sheets of plywood without removing the seats. That was my most versatile vehicle. It got better mpg than my Cruiser and turned on a dime by comparison. The Cruiser is a lot more fun to drive.
$200 worth of groceries is only a couple of bags, nowadays.
That said, as a result of Isabel, I have had to make a few dump runs in the past week or so. Between carrying branches or spoiled food or the waste from a closet we cleaned out (not Isabel related), the car has swallowed everything we put into it.
Anyone out there have a similar problem perhaps?
Solution maybe?
Jim
If you search the various internet discussions you should find discussions of the rough idle problem. I believe a number of the complaints have been cured by the replacement of the plugs, spark plug wires or both. The fact that it happened in damp weather would make me suspect the plug wires.
