Suggested maintenance: rip-off or must do?
yes, some is a rip. yes, some is must-do. yes, some of the times are wildly optimistic and the maintenance should be done earlier.
yes, if you have a specific issue, post it along with make, model, year, and equipment, and lots of car nuts will respond.
yes, indeed.
yes, indeed.
To be honest, you asked a VERY vauge question, so the answers are going to be all over the board.
Some assumed you meant the "Suggested Maintenance" in the owners manual of the vehicle.
Others assumed you meant the "Suggested Maintenance" schedule by a dealer.
Besides, you got what you paid for. Next time, when you come looking for free answers to your questions, don't chastize those who do give an answer.
And most importantly, ask good questions with the right amount of detail.
TB
Grumpy because of a broken PC today, (^)&^*&*&&^ Windows.
The answers you get will be as good as the info you provide in your question.
Since my crystal ball has been in the shop, it makes it very difficult to know exactly what the question is without specifics.
I knew we shouldn't have fired that psychic.
He could read minds great, just couldn't fix cars. LOL!
oops, I keep making the same mistake... I don't get called by the "psychic friends" network, my calls are from the "PSYCHO friends" network. keep changing my number, but they still get through
I would get a push/pull syringe (Wal-Mart sells them, they're metal with a plastic hose). The syringe makes the job a bunch easier, especially on the transmission. You can pull the covers on the diffs, but the transmission...
I used to have to remove the diff cover on my Mustang to change the fluid. You can use a machine that sucks the fluid out of the fill hole, but that doesn't work that good. It never leaked, but that's because I did it right. I torqued all the little bolts in sequence and made sure there was no little pieces of sand or dirt between the gasket and differential case. A drain plug would have been much easier. BTW, most Japanese trucks have two piece solid iron differential casings.
