A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
ANY QUESTIONS for dave40 aka CHEVY LOVER
I will soon purchase a 2000 Silverado Z-71 Ext Cab in November. I have seen 1999-2000 Silverados with larger tires 305/65R16 Goodyear Wrangler ATS tires on them with stock wheels. The modifications made to the truck to squeeze in the tires were to crank up the torsion bars to lift the front end about 2-3 inches and for the back they added a leaf or took and existing leaf and had them re-bent to adjust the height 2-3 inches.
My question is for the front end adjustment. Is this modification going to void the warranty and is it safe to do?
1. I have a 00 reg. cab with an overhead
console....how do I get to the inside of
this console to be able to wire in a radar
detector?
2. I also need to know how to remove the
inside trim around the windshield and
post to be able to run wires for remote
sensors for this same radar detector.
3. Next, I would like to remove the front of
the dash to install a LED for an after-
market alarm.
Later ~~~~~ vetzs
The dash pulls off like the c/k trucks did, carefull not to pull to far and rip wires.
the post trim piece also pulls off like c/k did. Trust me this one is a [non-permissible content removed] to get back in again without cracking something, be patient and try different methods of putting it back. comes out easy.
A few things about diesels. There seems to be a diesel fad going on. Unless you are driving a million miles every day or are hauling HEAVY loads every day a diesel is not the way to go. They are very spendy to fix. The price of diesel is not cheap like it used to be either. At least not in the west.
If you still want a diesel GM will have a new one coming out in late 2000-2001. Duramx diesel built by Isuzu. Looks very good on paper will have to see what it really does
-powerisfun
say to check the bolts after a few thousand miles
after installation, but no mention of regular checking or anything. Anyway, if that's the only thing, that sounds rather minor. Thanks for the quick answer.
-powerisfun
P.S. I made a new topic called "Headers in late model trucks" if you'd like to contribute to it. I'd appreciate it and I'm sure many others would too.
I was out waxing my 5 week old 2K Silverado yesterday and noticed rust on the factory hitch. Is this normal? Are all of the trucks doing it?
- tuckyboy
Thanks , Park
of hot gases rushing through the primary tubes. Anyway, I'm going to take them back off and send them back to JCWhitney. Not because I mind the sound, but because I'm totally unsatisfied with the quality of the PaceSetter headers. The welds are sloppy, the bolt holes aren't aligned well, I had to put one of the headpipe bolts in backwards because the bolt wouldn't go in the correct way, the EGR tube is not properly threaded so I'm not getting a good seal there (I had to tape it with a [non-permissible content removed]-load of exhaust tape just to make sure it was sealed). The paint job is absolutely horrid. It looks like they painted them and then immediately packed them off to ship. One of the headers still had a sticker of some sort on it... and it was painted over. Whatever you do, DO NOT buy anything from TFX-PaceSetter. They have a terrible quality control problem.
I'm going to try a set of Summit Racing brand shorty headers. I know they're not as high quality as Gibson or JBA, but they're quite a bit less expensive (by a factor of two or more). I'll let y'all know how they are.
-powerisfun
I don't know why I didn't just order the Summits in the first place. I saw ads for TFX-PaceSetter in many of my truck magazines, so I figured they may be a decent name, but not at all.
One thing great about JCWhitney is that if the product is defective (I think the badly threaded EGR tube and the non-fitting header-pipe bolt qualifies as defective), they'll reimburse you for your shipping to send it back. I still had to pay for the shipping to get it here, but that was minimal since I ordered a few other things as well.
-powerisfun
I've asked this question on other topics and everyone that responded had a similar situation. Do you know why the 6.0 does this? (I hear the 4.8L isn't any better.)
-powerisfun
Rob
Additional Discussions with dave40.
Front Porch Philosopher
