ANY QUESTIONS for dave40 aka CHEVY LOVER
24567
  • cdeancdean Member Posts: 1,110
    all it is is a shift point delay. you don't drive around 4000 rpm, these trucks drive around 2000 rpm. just because all the max ratings are at high rpms, doesn't mean the engine operates there. normal highway driving (i drove the 4.8), the engine NEVER GOT ABOVE 3000, and that was on moderate take offs, cruised at 70 mph at 1800, had a 3.73 rear, i think. Only when you really lay into it, rpms will run way up there. if you drive one, it will do way more justice than my words could ever do. while cruising, if you put your foot in a little bit, it won't downshift, it will walk on up.
    these engines have plenty torque. You're trying to make this relatively simple feature, as tnt2 describes, a knockdown vs GM. If you drive one, you'll see its not. thats the reason i said something.
  • akjbmwakjbmw Member Posts: 231
    Well. . .
    I am surprised to find that there is actually some valid information in this topic in spite of the title.
    I visited this topic to see if Dave40 would establish any credibility. No surprise, none found.
    cdean, kcram: Do you remember the “character” from almost a year ago who was almost as disruptive? He eventually went away.
  • quadrunner500quadrunner500 Member Posts: 2,721
    Where are all these torque "curves" everyone is referring to? The only one I have seen was in the Silverado brochure, and a couple of magazine tests from the chassis dynomometer. Ask me which I believe? Forget the brochure hype, the results from the chassis dynomometer show the 5.9L Magnum and the 5.4L Triton engines produce more flywheel torque and peak horsepower than the 5.3L Vortec.
    From Truck Trend Feb 1999, here are the numbers:
    5.4L Triton Rear wheel torque 281.2 lb.ft/3000 rpm
    5.9L Magnum Rear wheel torque 257.5 lb.ft/3500 rpm
    5.3L Vortec Rear wheel torque 221.7 lb.ft/3750 rpm
    5.4L Triton Peak rear wheel hp 209.2 hp/4250 rpm
    5.9L Magnum Peak rear wheel hp 194.7 hp/4500 rpm
    5.3L Vortec Peak rear wheel hp 182.8 hp/5200 rpm
    I have several comments. The data Truck Trend reported is credible, but their interpretation is faulty. The numbers for rear wheel torque from the chassis dynomometer have nothing to do at all with gearing, because they are expressed at the crankshaft even though the measurement is made at the rear wheel. So calling it "rear wheel torque" is misleading. How do you know this? Because if the rear wheels were actually spinning 3750 rpm, the surface speed would be above 350 mph. Thus 3750 is obviously the crankshaft rpm. To calculate the actual torque at the rear wheel you multiply engine torque times the gear ratio you are in. But since the comparisons we want to draw are at the flywheel, I think kcram was fair to conclude the vortec 5.3L needs a tow/haul switch because of a lack of engine bottom-end torque. But I'm with cdean that it still has pleasing power in a general sense. Speaking as an owner of a '99 lt. pewter metallic Silverado, I think if I was towing a medium size 4500-5000 pound trailer up the hills where I go, without tow/haul the transmission would have to be downshifting frequently in order to maintain a comfortable momentum. With tow/haul, it raises the shiftpoint rpm, and thus reduces the frequency of shifts as it carries the rpm's farther in each gear. If indeed that is less comfortable, I submit it is no more noisy at 4000 rpm than the diesel is at 2000 rpm. While the old Ford 302 with its low end torque and a 3 spd auto maybe didn't need to shift much, it wasn't going as fast as the Silverado up these hills either. Just different ways of getting the job done. I am not disappointed in the Silverado because I understood the old axiom, "there is no substitute for cubic inches." The notion the 5.3 was going to out-torque the older 350 by a significant margin was not a notion I was ready to accept. But just getting performance close to the old 350 while adding best in class fuel economy was enough value added to make me buy it.
    ak - yep, i remember :)
    You also notice Dave has not had anything to say here since I posted the link of Dodge using the Allison before Chevy/GMC...
    quad,
    Rear wheel torque is still a valid term. It measures the engine torque that actually makes it to the rear wheels at any given engine speed, as opposed to the higher figure the engine will generate sitting on a rack. You're correct that the actual tire torque is a different figure, but dyno shops make corrections for the tire, axle ratio, and transmission/transfer case ratios.
    As for the figures, it's a reasonable averaging of all the published material that I work with, and I'm sure cdean does the same. Time will tell if GM's attempt at using steady torque over a wider powerband will beat Ford and Dodge's use of higher torque at lower rpm. This refers to gasoline engines, of course. Until the Isuzu 6.6 V8 shows up, comparing the current GM 6.5 to the Cummins and Navistar is pretty unfair.
    cdean and I argue a lot - don't mind us. But unlike this topic's titleholder, we argue trucks, not people.
    well said, Kcram.
    I do get the numbers I speak from a variety of sources, there usually isn't too much variation.
    One thing I'd like to point out is that there is a lot of comparison of torque and pulling power of the 5.3 vs the 5.4 vs the 5.9. The workhorse of GMs family is the 6.0. It was an interesting design strategy of 3 midsize v8s. I would really like to see one of those uphill pulling wars between the 3 motors to see just how that broad power band on the 5.3 would do. But I think the 6.0 would walk away easily from the 5.4 and 5.9 becuz its powerband from 2K to 4K rpms is around the 5.4 and 5.9 peak values.
    I think the 'real' replacement of the ol' 350 is the 6.0. the 5.3 is a in between, motor, great power for light hauling, good mileage for empty driving.
    I have to say Kcram I believe in the powerband. (not much of a slogan, eh) I was skeptical when I first saw the numbers come out a year or two ago, but after getting behind the wheel and putting my foot into one, I'm a believer. My 350 now has spec torque of 330 ft lbs. The 4.8 I test drove specs at 285 ftlbs (correct me if I'm wrong). The 4.8 in the basically the same size truck, will run circles around my current truck.
    Cdean, maybe you would like to share some of these sources of numbers with us? Not trying to be argumentative here, but until you prove it to me I remain skeptical.
    Dave40, I hate to see the disappointment in store for you when you decide to put your foot into it against the new Ford Lightning, or the old GMC Cyclone.
    F first
    O on
    R race
    D day
    quadrunner
    Its kinda like Kcram said, you see it here, there --you get a good idea of it then. I know I've seen all the Chevy torque curves in several brochures. I've seen Ford torque curves in those same Chevy brochures. I've also seen Ford and Chevy torque curves on independent web sites, but we'll have to clear some cob webs to remember exactly which one. I do remember several JPEGs of all the Ford torque curves.
    AS for the arguments on not trusting the brochure: the Ford torque curve seen in the Chevrolet brochure was identical to the Ford torque curve on the independent site. If it wasn't, Ford would be sueing GM, big time. Remember, they can skew it with scale, but they can't change the actual numbers.
    Don't worry, I understand your skepticism. I feel the same way about the chassis dyno numbers discussed, I'd like to see them myself. :)
    Oh, and how bout this acronym
    F irst
    O n
    R ace
    D ay right behind Jeff Gordon and Dale Earnhardt
  • dodgeramdodgeram Member Posts: 202
    DAve40,
    I want the six spd, and a bet theres 1000's more who would a ALLISON 6sp, over the current 4spd.
    I see that its dissapointing to you that dodge is bringing the 6spd to there trucks first.
    SO SAD!
    cdean:
    You are the man!
    But good effort for Penske team at Daytona. Rusty Wallace pole, Jeremy Mayfield 3rd.
  • etuffly2etuffly2 Member Posts: 29
    dodgeram,
    The addition of the Allison 6 speed to the already overpriced Cummins is going to put the already overpriced Dodge Ram out of reach for a lot of "everyday" people. You may as well buy a Peterbilt if you're going to spend that kind of money.
    A buddy of mine bought a 3/4 ton Dodge w/Cummins a couple of years ago and paid over $36,000. My brother in law just bought a Ford crew cab 4WD Super Duty with the Power Stroke and paid over $36,000. He put 5,000 miles on it and now he's selling it because the auto tranny is making noise and Ford found it to be within their "acceptable" range. They won't fix it. The Cummins is a good engine but the jury is still out on the Power Stroke and its longevity.
    In comparison I just ordered a '99 crew cab Chevy 4WD 3/4 ton loaded with everything available and powered by a 454. OTD price is $29,000. There's no way I can justify spending $7,000 to $8,000 dollars more on a Ford or Dodge. I can buy a hell of lot of gas with that much money. Gas is a lot cheaper than diesel where I live and the diesels are more expensive to maintain. Diesels last longer but you know the old saying about the Dodges. The truck disintegrates around the engine. Not many people drive a pickup the 300,000 mile life of a well maintained diesel engine. The truck body won't last that long.
    My point is this: These diesel rigs (Ford and Dodge now, perhaps Chevy next year) have gotten into the price range of a new house (OK maybe 1/2 a new house). You're paying $4,000 to $5,000 more just for the engine and, absent rare circumstances, most people don't buy them out of need or common sense. It's just ego. I'm open for attack now by the hard-core diesel lovers but I think my logic is right on with this.
  • stanfordstanford Member Posts: 606
    Why are you comparing gas to diesel? My '99 F350 4X4 V10 auto Lariat with every option possible had an OTD price of $31K. For a more recently designed truck, the $2K difference between it and your 454 is more than reasonable IMO. As for paying over $36K for a 2500 Dodge -- even with the Cummins -- your friend got taken.
    The diesel engines are more expensive, but pay for themselves in 100-120K miles (80-100 for the Dodge). The 6 speed auto would be fantastic -- I'd take it on my gas engine if it was an option. If it has a nice steep overdrive (I'd love .50) it could pay for itself in 50-60K miles even on my V10! As for trucks not lasting 300K, that depends a lot on where you live. Down here (Texas) its not uncommon at all.
    I agree with some of the conclusions you make about diesels. Some things are pretty frightening, related to the complexity. For example, sure the 100k warranty is nice, but not everything is covered. About 100k miles is about the time I've heard the injectors may get out of tolerance, and same for the rotary injection pump. These can be very expensive items to maintain. But strong as the bottom end may be, water pumps and accessories don't last any longer than on gas engines. I haven't even talked about turbochargers and intercoolers and I won't. But a friend of mine with a Ram Cummins took his recently to the Cummins shop (not Dodge) for his 24,000 mile valve adjustment. They also adjusted the injector pump. When he picked it up, it took over a minute of cranking to start, belches more black smoke when running, and has less power than before. It's drivable, be he's as disappointed as I am sorry for him. Cummins has not been able to restore the good running, so he took it to Dodge where they haven't helped either. There but for the grace of God go I. In purchasing a truck, I concluded the deciding factor should be if I have the payload that requires this engine to pull it, because that can be the only possible justification for me. The savings by purchasing the gas truck are up front and immediate, while the fuel savings on the diesel are only potential, and well into the future.
    Of course, new injectors for a gas engine run ~$200 a set for the good ones. Diesel injectors are a lot more -- they're also rated at 100X the pressure. I liked my '93 Navistar -- they've just gotten too complex for my taste. As the passenger-diesel trend catches up with the US, expect to see the prices of the more LD components drop somewhat. That'll be nice.
    I paid just $30,400 for a loaded 3500 Club cab 4x4 diesel in 96. Everybody tries to use the argument that the diesel costs $3-4K more than the gasoline engines and they feel they need to recover all $4K. NOT TRUE - the resale value of the diesel is also higher! My truck's value is still $2K higher than a comparable V10. Have I saved 2 grand in fuel? A LONG time ago... I was also on top of my loan in just 2 years of a 5 year note. Right now, my Ram is just quietly building equity towards its replacement.
    Ummmm... well, with the Cummins, maybe not as quietly :)
  • tnt2tnt2 Member Posts: 115
    Got to looking at a '96 motorhome, diesel pusher. What do you know, powered by cummins with a 6sp allison tranny. I guess the combination is already there, just looking for new skin to wrap around it.
    i'd like to point out one thing etuffly2 said. With the Allison trans that Chevy's and Dodges are coming out with, Diesels will surely creep toward the $40K mark. You can get a Kenworth 'mini' for that price, get a Cat, Detroit Diesel, or Cummins, and get half a million mile warranty for that price.
    Just don't try to park it at the grocery store.
    Got to agree with kcram on resale value, the diesel especially the cummins havehigh resale. e>g there a 94 ram 2wd slt larmie with 350000km, on it and the guy wants 13000cdn price. Up here in canada I can get a Ram quad cab 4x4 diesel 24valve sport, with the leathre cd, travel convenience pkg, the works, aux suspension etc, for 39-400000, dollars, cdn. Thats not bad for the truck your getting. Plus diesel is cheap up here, costing 43cents a litre, cdn. For a 5.9l gas with a the option mentioned above costs 39000, cdn, go figure?
  • markbuckmarkbuck Member Posts: 1,021
    Ya, went by yesterday. Build week of March 1. Said they could look around a do a dealer trade. I'll probably wait for I ordered. Heck, my SD buddy waited 8 months. He is very happy and says as soon as you get your truck, you forget that you waited so long. Plus his wife has loaned me her 2wd toyota PU for me to run around in.
    Saving lots of money by not owning anything with 4 wheels.
    where'd this info come from, Dave?
    Airaid for $279? COULD add up to 16 more horses. Could add none and we'd be $300 poorer. I'll stick with my stock Chevy extra capacity air cleaner on the 4.8L.
    I gotta open a web page and start advertizing some engineering gimmick soon. Maybe I could afford a 3/4 ton if I did.......
  • 26andrew126andrew1 Member Posts: 93
    kcram
    GM has been using Allison trans in ther campers for years now.
    So what if dodge has it first.Who says they will? Sonds as if the will come out about the same time.
    WHO CARES WHO HAS IT FIRST!
    not the issue.
    Everone agrees the trans is bullet proof.
    the Chevrolet in truck trend is just some artists rendition, and its just a rumor of a 495 big block; No real word from GM on anything.
    Truck Trend has a tendency to be dead wrong with their renderings too. Their drawing of the Lincoln Blackwood was done off an F250 Super Duty, not the F150/Navigator platform as the text below the drawibg stated (and as the truck was eventually created upon).
    This is also a magazine that will drive a truck for a week and put "N/A" in the spec box under tire size because they were too lazy to get on their knees and read the tire itself.
    Markbuck,
    The extra capacity air cleaner that comes stock from Chevy is just that. It doesn't push any more air into the engine to make it run better - it just catches more dirt and goes longer between filter changes. No increased performance over the normal air filter.
    Quadrunner,
    I agree. When thought out with common sense, these diesels only are beneficial for snowbirds and very high mileage drivers (professional cowboys etc). You are right on in that only the basic engine is covered with the 100,000 mile warranty. A good gas engine will go well beyond that when maintained properly and is much cheaper to maintain and rebuild.
    Stanford,
    Yes, the Ford is a newer model, but $2,000 for the V10 over the Chevy 454??? I think the 454, in the real world, will run the tires off that Ford V10. The V10 is a weak engine according to what I have read in Four Wheeler and Peterson's Off Road magazines. Plus, the 454 has years of track record to back up its reliability and the Ford V10 has only been out a couple of years - no track record. Also, I was comparing diesels to gas engines because that was my intention - I don't follow your question about that.
    etuffly2
    I didn't think any air cleaner "pushed more air in".
    I'd have to believe that there is some reduction to airflow restriction when you have larger surface area to draw through. But you are correct, the major reason I purchased this option was dusty Arizona backroads.
    etuffly2:
    You said:
    "There's no way I can justify spending $7,000
    to $8,000 dollars more on a Ford or Dodge"
    I was pointing out that your numbers were misleading at best. There's a lot of nice things about the F-SD series that haven't made it into the Chevys yet -- just because they've had a more recent overhaul if nothing else. I wasn't suggesting that the V10 alone was worth $2K.
    I didn't notice that you were getting a 3/4 ton either -- mine's a 1 ton DRW. That probably puts the actual price on both at right about the same place. I certainly don't think you're saving $7-8K getting the Chevy. As for the V10 -- I certainly wouldn't call it a weak engine. Decent mileage and excellent towing power, with a very usable powerband.
    When you get down to it, they're both good trucks. I feel that the final decision falls more to personal preference than any other issue. I drove both (and the Dodge) before making up my mind, I'm sure you did two. They each have their strengths and weaknesses. If one was really a long distance ahead of the other, they just wouldn't sell.
  • page3page3 Member Posts: 54
    What happen to dave40! No more 300 hp news! How's "THE TRUCK" doing? I keep waiting for updates.My truck is still just a piece of paper sitting on someones desk waiting to built...I hope.Has anybody got any good news on the 2500's??? Somewhere... a salesman has got to leak a secret about whats going on in the truck plants of gm.They should be in the White House.They don't let anything out to the public.
  • peterm1peterm1 Member Posts: 16
    page3
    They are making 2500's, although I getting pissed at GM. I ordered my truck at the end of October. My build week was 2/8. I talked to the dealer yesterday and find out that my truck was not built and shows no new status. Apparently a truck very close to mine (Sierra K2500HD Ext Cab Long Bed) with an Auto instead of my 5spd WAS built and is on the way to california. The dealer claims he can get no updated info on the 5sp (which is what is holding the order), and of course the GM Customer Service # is a joke. Two other people here reported seeing 2500 long beds on lots in Colorado and Maine.
    Which one are you waiting for?
  • larry18larry18 Member Posts: 48
    etuffly2:
    I agree with Sanford. I have been looking at Chevy, Ford, and Dodge. Each has pluses and minuses over the other. Personal preference and a good dealer should weigh heavy. I am still not sure which one I will buy. The difference in price among the trucks when similarly equiped is negligible. I did look at a Ford F-150 today that had the AC and 4 wheel anti-lock disk brakes fully discounted on the sticker.
    peterm1
    I ordered a chevy 2500 ext-cab LT on Nov 4. It was given a build date of 2/11 but some how got screwed up in the computer,so they say.All along I have been seeing reports about delays on the 2500's no matter which truck (gm or chevy).I am going to wait till March to see if things change.I kinda got myself worked up on getting this truck if it's the last thing I do.The 800 is a joke,they really pay those people to make you think they care.I did e-mail them and got the same"sorry for the delay,there has been a delay on 2500's."These delays can't be helping the share holders.I'll be updating with any progress,as I know we are no the only ones waiting.
    I was comparing Chevy gas to Ford and Dodge diesel because I feel those diesels are overpriced. The current Chevy diesel, although admittedly not as strong, is only about a $2,400 option. The 454 is a $600 option. That's only $1,800 more for the Chevy diesel over big block. My brother is in the equipment business and bought a Chevy 6.5 new (because of the cheaper price). Over 150,000 hard miles (mostly pulling big loads) and only replaced the injector pump.
    In comparison, I believe the Ford V-10 is a $200 or $300 option and the Power Stroke is about a $4,400 option. That's $4,000 difference. I may be slightly off on the numbers but I believe I'm close. Plus, I don't trust Ford automatic trannys. I know lots of people personally who have had problems with them and they're expensive to rebuild. In the Four Wheeler truck tests, all of the Ford testers thought it didn't live up to the power ratings put out by Ford. Dyno tests backed this up. Maybe it was just a "bad" engine or maybe the Calif. emissions suck all the power out of them, but I'm not sold on anything with the Super Dutys, other than the fact that the Power Stroke put up some impressive torque numbers.
    The Dodge is a non-competitor to me because they don't make a crew cab
    I don't really like chevys but there a hell of alot of 2500 99 model trucks up hear in Canada, all on the dealer lots. Either there not selling, or all you people down south who ordered your 2500 chevs and are waiting forever, are all up here waiting for somebody to buy them. Don't see why they don't send some down your way.
    Its not to late to buy a dodge and actully enjoy the a new truck, before you turn old and grey!
    dave40,
    1.)Borla
    2.)Flowmaster
    I have a very good reason....cause I don't know 'nuttin 'bout Gibson. Borlas I like because they are stainless steel, and there was/is some tuning to the sound you can do by changing out bypass rings I recall. Flowmasters have good power too, at a lower cost. Borlas had a good reputation for fit. Be aware, a cat-back system isn't going to produce much if any more horsepower without some other mods to compliment it. Used to be that meant a high flow cold air intake system, 160F thermostat, hypertech chip, underdrive pulleys, etc.
    Forget all of them and get a set of headers first. Then get a Rhino Performance muffler and have a local shop bend you a cat back. I had dual 3". Better sound than all three, more hp and performance, for about the same money.
    So with out the airraid, the 6.0l lifeless!
    dave40, your words not mine, (the airraid brought the 6.0l to life) , so before it was lifeless.
    My 5.9l doesn't need anymore power, unlike your lifeless 6.0l---without airraid.
    P.S thanks for the new nikname, I love it.
    Average OTR semi = 300hp
    Do you really need more than that for a pleasure truck? Oh, sorry, I forgot -- this is a sports truck, with sport tires and everything. In that case, why not compare to sports cars?
    Our '98 3000GT VR4 = 320hp
    That's about the same as your 'enhanced' 6.0l chevy, right? Of course, the VR4 can get 20mpg in the city (although it usually gets more like 18) and is faster 0-60 than a new vette. It even handles better in bad weather than your truck(fantastic AWD system) :-)
    Of course, when it comes to doing 'real-truck' stuff, it falls short of your 6.0l for now -- keep up the mods, though, and that disparity will get less and less obvious.
    The real issue -- if you want a sports car, buy a sports car. If you want a truck, buy a truck. If you want both, buy both -- most truck/sportscar hybrids fall short in both areas.
    Right on stanford! My street bike get 45mpg, 0-60 in 3.5s,..... I'm buying my truck to haul me and my stuff most anywhere - could give a flip about it's sports car like performance. Dave40, why didn't you buy a camaro z28? That's what I would do if I wanted a fast 4 wheeler........
    no engine envy here - my Cummins only has 180hp, but its 420lb-ft of torque gets a 7000 pound dually moving to the tune of 22mpg highway. So while your high-hp 6.0 is at Exxon refilling, I'll be in the next state on the same tank :)
    Now Dave, don't mind us. You enjoy that iron-head Briggs & Stratton anyway!
    DAve40, whats with all the mods?
    Thought you said chevy's 6.0l got 3
    continuing from post 134, was the most powerful engine. Seems like your looking for more power?
    Isn't stock power enough. Doesn't it live up to your expectations?
  • chevy4mechevy4me Member Posts: 203
    Dave does that much noise come out of the airraid? Why did they make the housing out of plastic instead of aluminum or steel ? Did you have the high capacity air cleaner to start with?
    Dave40 did you happen to see thelatest issue of Truck Trend 99 Silverado 5.3 L with a whipple supercharger ? 375 HP !!!!
    dave,
    One post will do, bro.
  • jxyoungjxyoung Member Posts: 156
    I think the Supercharger would negate the airraid HP gain! You would have to remove the HP gain for the airraid!
    Don't forget to remove the hypertech chip also. Wipple has their own chip.
