I think in base form, the 215 had 155 hp, which is favorable compared to the 225 Slant Six's 145 hp. That little Ford 221 V-8 only put out 145 hp, and their 260 only put out 164.
That little 215 engine could keep up with a 283 Chevy at the time.
In spite of a spotty reputation it never gave me any trouble and it ran well when I sold it with something like 80,000 miles on it.
My parents bought it new and gave it to me. I drove the hell out if it and it never complained.
Just don't ask about the Dual Path automatic!
Usually, when they'd do their big-car comparo, the Chevy would be saddled with a 283, and get tromped by whatever Pontiac, Plymouth, and Ford they trotted out next to it. A typical base 283 automatic would only do around 13 seconds, and the Chevies got worse as they got heavier in later years.
CR tested a '68 Impala with a 307, and it did 0-60 in something like 14.5 seconds. Just for comparison, they tested a '68 Dart with a 225 and 2.76 gears; 0-60 in 14.0 seconds. '67 Valiant with a 225 and 2.93 gears: 13 seconds. Most compacts with their little base 6es of the time were more like 17-20 seconds, if not more.
I suppose somebody has worried about flow in that motor just for the sake of TR8 ralley cars or whatever...this of course is where the small block Chevrolet really shines, umpteen zillion man hours of fiddling with intake and exhaust tracts, piston shape, cam grinds, etc.
I could be totally off-base, but I'll bet you'd have to be careful buying a 40 year old BOP engine due to corrosion problems...people running ditch water instead of antifreeze...not sure.
Some V8s just are not receptive to modification. They don't breath right, their combustion chambers aren't right, they are heavy or lazy or whatever, or maybe not strong enough to take what it takes to boost HP.
On the other extreme, some V8s (mostly European) are so well developed that you aren't going to get much more out of them because the factory did all the work that could be done. It was $500 to make it go faster but $3000 more to keep the car in one piece.
Sometimes a V8 that is "easy" to modify can work against you. People who bought Sunbeam Tigers and then beefed up the orginal Ford V8s found out to their dismay that the Sunbeam rear end and suspension wasn't up to the task.
Time and money can work miracles (I mean, some people even won bigtime races with a V-12 Jaguar E-Type) but there are definitely better building "blocks" for high HP than just picking any old V8 IMHO.
I don't know what in particular held back the Buick V8 but you'll note that even when that same basic engine (but iron) was brought out to 350 CID it was never the racers' favorite. The undersquare design may have had something to do with it but the 300 and even the 340 versions used the same valve sizes as the 215.
You are making my point and not at the same time. Since breathing is the crux here...rpm limits aren't going to matter on the street...air flow can be modified on anything. Witness the number of aftermarket head designs for common V8's. If the heads and intake are allowed 'modifications' (up to and including complete replacement) then most of the low hanging fruit is here. The short version of my opinion is there isn't much to be gained by shortblock choice.
Having said that, I wonder what Travers and Coons' reactions were when they got the AMC contract for the 1970 Trans-Am. Probably broke apart a 304 and thought, holy s***, now what.
As far as 'well developed' European V8's are concerned...none pop to mind (at least from 30 years ago). All I can think of is the Mercedes V8, and that always struck me as sort of a boat anchor.
But what I mean by fully developed is that to get more HP out of them requires fairly radical methods. This is why I suspect that AMG cars cost so much when they modify the Benz engines. It's so much easier to breath on a well-designed American V8 because they are so crudely built and they leave so much on the table for the modifier to improve. For one thing you aren't dealing with four overhead camshafts as you would be on a 500SL--you just have one to change out.
That's why the V6 was the V8's 90 degrees instead of the usual 60, and why it was heavier than it needed to be--aluminum engines, at least in those days, needed more meat in the block for rigidity and the V6 used much of the same tooling as the aluminum engine.
As a point of interest, the '64 Buick 300 still had aluminum heads and intake.
I had a four barrel 215 in a '63 Skylark and agree with Isell that the car moved out well even with the two-speed automatic. It was just a small engine in a fairly heavy car so you were never going to go out and bag hemis.
It would have amazed someone in 1964 to know that the V6 and V8 would still be around almost forty years later, long after better engines were discontinued. And they're related to each other. Just amazing, a real monument to engineering inertia.
The GMC V6 was apparently similar to the W block 348--both had the combustion chamber mostly in the piston, not the head. The similarity makes sense--both were designed by GM for truck use in the late '50s.
Well the V-8 in a 1988 Mercedes 500SL will put out 389HP from 365 cid--that's not bad at all, certainly up to Chevy short block standards for a stroker 350, and enough to punch a 4,500 car to 0-60 in 6.1 seconds.
I see the disconnect now...we're talking about different eras. Since the 215 is a product of the '60s, I was drawing conclusions about engines of that era in general.
Well there aren't really too many Mercedes V8s in that era except the one they put in the 600 in 1963. That was a pretty good engine for power, putting out 300HP sae @ 4100 rpm out of 386 CID and a top speed of 144 mph at 5530 rpm engine speed. But that was a lot of cubes.
There was the 3.5 liter V8 in 1969 which might be more of a comparison with the 215 Buick.
It was 213 CID and put out 230 HP and 231 ft. lbs of torque and accelerated a 3800 lb car in about 10 seconds 0-60. In contrast the Buick 215 V-8 put out 155 HP. So the Benz engine is putting out 75 more HP, and consequently accelerating faster with 1,000 lbs more weight. No doubt this was all due to internal engine design, overhead cams and fuel injection.
The Ford 260 cid V-8 of 1963 put out 164 HP. A base Chevy 283 CID engine of 1963 put out about 195 HP. The 1963 Chevy 327 cid engine with 4 bbl. carb was about equivalent to the Benz 213 cid in horsepower, a bit more at 250HP.
The point of all this is that European engine technology was often quite ahead of American engines in the early 60s, pound for pound and cube for cube.
European makers, in converting their horsepower ratings from DIN standard to SAE gross, tended to play particularly fast and loose with the numbers. Some were low (the 300 hp rating of the big Benz 6.3L V-8 was probably very conservative), some exaggerated.
It's true that European engines generally made more horsepower per cubic inch in the 60s, but it wasn't until everybody started quoting power in SAE net numbers from 1972 on that you could make a more reasonable direct comparison. (SAE net numbers are at the flywheel, as installed in the car with all accessories; they are NOT, contrary to some belief, taken at the drive wheels!)
Road test performance figures aren't necessarily a good point of comparison, either. Aside from the question of whether some of the testing was, er, fast and loose (who was reading the numbers, how performance was calculated, whether cars were strictly stock or not, etc), there were various other factors involved. MOTOR TREND, for example, did its road testing with two testers and more than a hundred pounds of equipment aboard, so its numbers (at least through the latter 60s) were more conservative than, say, CAR AND DRIVER.
Also, even if the test conditions are balanced, there are other things at work. A late 60s Mercedes 300 sedan had a four-speed automatic transmission, usually set up with rather firm shifts, keeping the engine closer to its peak through more of its speed range. A '61 or '62 Buick Special almost certainly had the old Buick Twin Turbine automatic, a non-lockup torque converter autobox for which the term "slushbox" might've been coined. That makes a big difference, as do things like tires and axle ratios.
Of course, the Americans in the 60s would never lie about HP
The "turbosupercharged" Olds 215 had 215 hp as long as the water/alcohol held out. Then poof.
BTW the Olds and Buick 215s had different heads. I wonder if Olds based its 330 smallblock on its 215 heads?
They did cut 'em down after a few years though. In '61, the 361 2-bbl only had 265 hp. And for some reason, the 383 2-bbl was low on power in '67. At least I remember the '67 Newport I had only had 270 hp.
Nowadays, fuel injection, variable intakes, use of alloys, and computer engine management all give the pushrod V8 a new lease on life, but back then they were just using cubic inches for power, and things like fuel efficiency, rev ability, noise, vibration, endurance, were not much of a concern. Power and a 90 day warranty, that's what you got.
The one exception I can think of is the Chevy fuelie and even that's just a very good sedan engine with excellent factory development (heads, cam) and mechanical fuel injection.
As far as specific output, Roger Huntington says the '57 283/283 put out about 240 net hp, the '61 283/315 280 hp and the '65 327/375 about 300.
Some of Detroit's engineering departments had their strengths, often to compensate for a weakness in an engine. For example nailvalve Buicks had some of the best exhaust manifolds and one of the early examples of a factory high overlap split-duration cam because the small combustion chamber didn't leave much room for an exhaust valve.
And Chrysler did some work with ram tuning. But that's about as fancy as it got. Even the killer drag racing engines were just more of what the street engines got. I think it's telling that Chrysler and Rambler backed away from fuel injection in the late '50s.
Can anyone name the first full production car using a V8 engine? (close is good enough).
Early automakers tried damn near every configuration at least once, and V-type engines date back to the beginning of the automobile. But the first major production V-8 was, I think, the 1915 Cadillac engine. It was 314.5 cubic inches, very undersquare (3.125 bore and 5.125" stroke) with a whopping 4.25:1 compression ratio. It was rated at 70 gross horsepower at 2400 rpm, with 180 lbs-ft of torque at 2000 rpm.
If you wanted to get really technical about it, the first V8 in an American car, and possibly any "real" car, was the 1908 Marmon, but I've never seen one and I suspect very few were made. Possibly none even survive. This engine was air-cooled and was rated at 60HP. It may only have existed in a catalog for all I know.
There is some evidence that the French used a few V8s for marine use before 1900.
Great race. My brother was riding shotgun and went nuts when I pulled away from the RR, not knowing he'd missed a shift. I guess he thought I'd cut in the afterburner or something. The RR was so close to me I thought for a second I'd missed the shift instead of him.
Just thought I'd share.
BTW I ran across a guy with a site who claims he put a boneyard '70 Buick 350 with, he thinks, a '79 Pontiac automatic into an early '60s Mercedes. No photographic proof of this, which is probably just as well. He also has all but two of the entire line-up of models Plymouth offered in 1955. These he does have photos of and they're mostly junkyard hulks.
Normally I don't go for those half-car half truck things but I'd make a exception for this one.
Too light in the rear? I'd find an old side-oiler block that's not doing anything and park it in the bed. It's the perfect parts rumnner for the discerning Cobra, GT-350 or GT40 owner, of which sadly, I am not one.
So from my point of view, nothing was gained by putting in the V8 except making it more suitable for lazy Americans to putt around on the boulevard. From a sales perspective however, it was an outstanding success, so Mercedes gets to laugh at Shiftright all the way to the bank.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1876577902&category=6278
Anyway, I seriously doubt that car will sell, as a Mark X is probably the least collectable Jaguar made, and a 504 engine alone isn;t worth that kind of money. The sad thing is, for what that guy spent on the Jag, he could have had a very very nice, brand new XJ8, that at least would take 3 or 4 years to depreciate, rather than being worth peanuts the instant it's finished. Shifty, your opinion on what the beauty is really worth?
In 1960 Jaguar bought Daimler (not to be confused with Daimler-Benz!), which had just developed new V-8 engines. Jaguar was impressed with the engine, so from 1962 to 1969 they produced a Daimler version of the smaller Mark II sedan (the Daimler 2.5 V-8, rebadged Daimler 250 in 1967). It was a modestly restyled Mark II body slightly modified to fit the V-8 engine. There weren't many left-hand drive models, though...only about 725 of the 18,000 or so produced were LHD. Jaguar also continued to sell the Daimler Majestic Major saloon, which had a bigger version of the V-8, through 1969. After 1969 the V-8 engines were dropped and all subsequent Daimlers were just loaded, upscale Jaguars, with all-Jag mechanicals.
The small Daimler V-8 had aluminum heads with hemispherical combustion chambers and two SU carburetors. It made 140 hp and 155 lbs-ft of torque from 2548 ccs, which wasn't bad for its day (it was designed in 1959). It was actually lighter than Jaguar's inline-six, too. The bigger engine was 4.6L, making 220 hp.
cuz they were soooo fugly.
Aside from the questionable looks, the rubber chassis didn't help. But from what I've gleaned at car shows, once you got the frame re-inforced and worked out all the bugs, it was a fairly competent car---still unfortunate genetics though.
Of course it was! It came from the same country that gave us Austin-Healy, MG, Triumph, and (my personal favorite) Jaguar! After all, didn't the British invent the sports car? (Along with the oil leak, the short circuit, rust...)
now of course a new generation has a completely different understanding of a sports car, more like what a GT car was 40 years ago.
I've done v-8 swaps on may types of vehicles.
SB 350 into Vegas were popular swaps. Did 4 in 3 months one year. A 427 into a Chevy Luv was an interesting one. 327 & 350s into Jeep CJ3As were also very popular.
The 64-66 Chevy and GMC pickups with 6 cylinder to V-8 swaps were also very common, easy too. LOL!
I think my favorites were always the 65-72 Nova big block swaps. The car seemed to be the right size for the power they produced. Combine the big block with a 6-71 blower and nitrous oxide and it was a pretty good runner. LOL!
Those days are mostly gone now, unfortunately.
Since BBC Novas (in both 396 and 427 CID) were built from '68-'70, just use those parts in a 73/74 car. I'm not certain about the '75/'79 cars, but I'll bet that they are so closely related to post 1970 Camaros that a person could just use motor mounts/radiator set/etc. from a 1970 or 71 SS-396 Camaro.
As for doing it 'right', those unit body Chevy's (well, unit body from the firewall back) look like they could stand some stiffening fer shure, especially if a standard transmission is used. That whole subframe connector / cage thing has been solved so many times I expect there are a zillion catalogs with those parts.
Those old Novas were supposed to make excellent copcars. I don't know how they compared to the Dart/Valiant police packages, but they totally dogged the later Volare/Aspen police packages. In fact, I read that the best thing to happen for the Mopar cheering section back then was when Chevy switched the compact police package from the Nova to the Malibu! Even though the newly-downsized Malibu was more modern than the Nova, evidently it wasn't as well-suited to police duty.
I'm a big fan of the 1975/79 Novas in 4 door trim. They are cool looking, cheap, and have great mechanical interchange. As I turn into an old fart, the thing that keeps me away from doing a 502CID/6 speed/4dr Nova is a combination of hassles with the smog police, and (mainly) the fact that you end up with $20k-$25k into a car you could sell for $5k. Better off dumping the money into an early Camaro or Chevelle.
One bad thing about disco Novas is the lack of support for body panels, trim, interior parts, etc. except for junkyards...and junkyards tend to crush them in any case.
Actually, they held up pretty well. Most of them we sub-framed though.
Did the '73-74 and '75-79 Novas ever go through that stage when it was popular to big-block 'em?
The 73, no. Not sure why, but it was never a choice of the hot rodders I knew. The 74, yes. It was almost as popular as the 72.
The 75-up, didn't seem to be much interest in them, although I'm sure times have changed. LOL!
A hemi powered dart was tough competition for the big block Nova. Great to watch though. LOL!
I was no doubt inspired by the Iso-Rivolta, Bizzarini GT and other efforts at marrying Italian style with American V8 power.
