Accord Automatic vs Manual reliability?
I'm about to get a 2003 Accord DX and can get either manual or automatic transmission.
Which is the wiser choice just in terms of reliability & expense over the long haul (100k+)?
thanks!
thanks!
I disagree with isellhondas on this. In terms of expense the manual transmission is definitely cheaper to replace/repair. As far as reliability goes you can generally get more miles on the original clutch than the original auto transmission. Of course if you don't shift properly or abuse the car, you may find the auto transmission more reliable - that is, you can burn a clutch in only a few minutes!
Having said that, the convenience cost of not having to shift it yourself may outweigh any $$ advantage a manual will provide, especially if you live in a congested city or anticipate other folks driving who aren't used to manual transmissions. It only takes one misshift to damage an engine.
Few people want them.
I think this question hinges more on the driver than the economics of the situation. If you aren't too handy with a stick shift, you could burn out a clutch every 6 months no problem, and you could damage synchros or gears. It's hard to abuse an automatic, you really have to be intent on destroying it.
Also depends on the type of car. I don't really see much point in having a manual shift Accord.
I'd say if it's an Accord, and if you aren't particularly fond of stick shift, buy an automatic. The difference in cost isn't so great as to warrant a decision based on money alone.
Is it cheaper to overhaul an automatic than it is to overhaul a 5-speed? Is the 5-speed more likely to need an overhaul than the automatic? I suspect that the 5 speed is cheaper and less likely to need an overhaul, but I've never seen any data for a manual tranny. If anyone is clumsy enough to abuse synchros or gears, they have no business even considering a manual - they won't be having any fun driving, that's for sure.
As far as resale goes, after the 6 or so years it takes to accumulate 100K miles, the difference isn't much, especially for a DX. For example, I found the following quotes on Edmunds for a '96 Accord DX with 100K, first column for Auto, second for 5-speed. You would expect about $200 more in trade or sale for automatic over the 5-speed:
Trade in - $3,704 vs. $3,520
Private - $4,575 vs. $4,355
Buy from Dealer - $5,808 vs. $5,508
In other words the manual transmission is cheaper to begin with and a lot simpler and more durable, but there is a greater risk that you will damage something (or gradually wear out something) if you are not a good driver. (Or if you happen to have a bad day and downshift into the wrong gear!)
If you are replacing a manual clutch every six months, then yes you should be driving an automatic.
If you are blowing an engine by downshifting and overreving then you probably shouldn't be driving a manual. This happens rarely. Apparently, one exception, you buy a celica GTS with the 6-spped for a young, aggressive driver and apparently some of the earler shift gates allowed a person to downshift from 6th to 2nd. I have a nephew who is a toyota mechanic and he said he replaced about 3 transmissions when the car first came out; Toyota covered them one time even though it was obvious misshift.
I have a lot of experience driving manuals. 75% of my cars that I own currently have a manual transmission and I will buy another manual in the future.
The people who think there is a lot more potential to dmage a manual transmission , obviously don't drive one !
The only item that I can agree with even a litlle in this whole thread is that a manual transmisison will reduce the resale, that is unless the person is looking for economy with better performance and is looking at a 4 cylinder.
Let's see the subject is reliability. I have an 1995 Acura Integra GSR 5-speed with 85K miles and I finally had to replace the clutch master cylinder. The Acura has probably been one of the most reloable cars I have owned and by the way did I mention that is is a manual with the original clutch and the engine hasn't been blown by downshifting. I guess the Apex exhuast and the AEM cold air intake and many years of driving expereince may contribute to that.
If you do the work yourself, you can buy 3 clutches @ 100ea, a master cyl. for 100, a slave cyl for 50, and still have lots of money left over for fluid changes.
For the '03 Accords, you can not use MPG as a determining factor, as they have the 5AT now, and it gets the same mileage as the 5MT(according to the paperwork) BUT, the 5AT gets ULEV status and the 5MT gets LEV status on the engine.
Push a CV tranny in there, and you will actually get better mileage, but I don't think they got those built well enough yet to handle higher HP applications, only available in 120HP or so applications.
I agree though: the manual will prove more reliable and cost-effective than the auto. I will be really sad if they kill stick shifts in the decade it will be before my next new-car purchase!
Just one note: in California, the auto '03 Accord LX and EX are SULEV, not ULEV, and since they are 5-speed autos, I guess they might be worth a try for the emissions reduction.
In CA, the Accords are available as NLEV(near zero emission vehicle) from what I've seen. Auto Only.
Funny thing is that since the AT gets the same MPG, but puts out less emissions, one would have to think that there is much computerized control in an AT over the MT...
Manuals will naturally rev a lot more.
The 4-cylinder EX automatic model is certified this year '03 as partial zero emissions, to be more precise. I cannot figure how a combustion engine that remains running all the time without shutting down at stops could ever be zero emissions, at any time. Can it be that they have so refined catalytic technology that once the engine is warm, they capture ALL the emissions in the pipe?
