I haven't had any spots or bubbles on my dash board either, but it's probably too soon for that to affect me, I'll definitely keep an eye out for that as well as those other problems you mentioned.
I've only had my Mag for 4 days, so I haven't had any of the other problems (yet) that are mentioned above. The steering wheel and car body vibration described above sounds like something serious, especially if the wheel balance didn't work. Keep us informed on how that is resolved, because if that was there from the beginning, and they can't fix it you may have a lemon.
In New York you have up until 18000 miles though or (I think 2 years) and you have to bring it into the dealer with the same problem at least 4 times. I don't know what state you're in, but that is something to consider.
Look, I like this car as much as the next guy (or gal), but that vibration sounds serious, the braking noise, the engine noises and I'll be quick to use the lemon law if I have to and I would get another one too.
Before I bought the Mag, I rented a Ford Taurus, a Chevy Monte Carlo (I was very impressed) and a Ford Mustang 4.0 liter (bright yellow) (squeezed 3 people in the back seat to go out to dinner) (got the most buzz while driving around the city), and I had no pull issues or engine noises. I rented those cars in particular because I knew I was going to buy the Mag and I wanted to compare them to it.
Don't get me wrong, the Mag comes through with flying colors :shades:
They've been back on 3 shifts since 7/16/05.
I'm waiting to find out more before I take it back to the dealer.
Two of 4 brand new tires bad must be replaced.Balance rims & tires $ 114.They did find rear camber out of specification.Necessary to adjust rear strut mount.Transitowne Dodge Williamsville NY did not see that.They did alignment.In my opinion they destroyed my tires and breaks.I saw another post ,four tires destroyed because of bad alignment, after few thousand miles 300 or Magnum??? I am not sure which one.Steering & suspension components OK.Alignment.Vibration present.What is my point???
Positives: Great seating room - just did a 2K trip with full back seat. Rode in the back myself and it was great. Great power - pulled a trailer through the Colorado Rockies without any problems. Passed a lot of vehicles on the uphill sections with great fun. Great mileage - averaged 17 with the trailer at 80 mph - getting 22 to 24 without the trailer at 75-80. Great sound system. Great NAV system - makes a trip enjoyable and keeps me from getting lost. Great looks - I am still getting used to be stared at at stoplights. Got stopped by a cop who really just wanted to see the car! No pulling, vibration, or other handling problems.
In all, this is a great car - especially considering it is a first-year model (and all the problems typically associated with the first-year models). It is a leased company car and I will be replacing it with another RT AWD Hemi!
That having been said, if one or more valves have been pushed up into the head, if the connecting rods are bent almost into a swirl and or broken (with little apparent bearing damage), if the spark plugs have been blown through and/or if even a single piston has a hole in it then there is probably no argument that you can make to DC (or any other mechanic for that matter) to convince them that you didn't drive your car through water deep enough to allow the engine to ingest some (it doesn't take much).
Thinking about this from a different perspective, if it turns out that your engine did in fact suffer hydraulic damage, that should be covered under your insurance policy. The fact is that hitting a deep puddle or other water hazard is no different than hitting a deer or other road hazard.
Let us know what happens.
Best Regards,
Shipo
Does anyone that has the 3.5l V6 ever tow jetskis or a boat with it? I know it is only rated at 2000 lbs towing capacity, but I was just wondering how it does when pulling the boat or some jetskis out of the water.
Jamie
I DO NOT KNOW IF THIS HELPS WITH THE 3.5 V6. BUT THE CHEV TRAIL BRAZIER HAS A BIG V6 AND I SEE THEM PULLING LIKE 22 FT PLUS BOATS.
HOPE YOU FIND OUT WHAT YOU NEED HERE.
Kenny's Muffler in cypress, ca. is the bomb.
Did you ever take a look at the internal engine parts? I'm curious to know what they looked like. Assuming that they were fairly straight (ie. no signs of hydraulic damage), have you gotten any traction with the Dealer and D/C regarding the repair?
Best Regards,
Shipo
Thanks in advance
David
For those of you still wondering whether to get one, If you drive a lot of highways miles (which I don't, but I don't care) then this car is definitely worth taking a look at. You really can't call this car a gas guzzler the way it runs on the highway.
I guess I'm lucky cause the only consistent problem I've had with this car is the lift gate not working. I finally took it back to dealer they confirmed something was wrong and ordered a new switch, should get it this week.
Other than that when I'm driving I'm just :shades: :shades:
Initial response from the zone manager was that the shuddering was normal for the Magnum RT. HA HA! What an idiotic position to take. The car ran perfectly when I bought it and didn't shudder for the first 3000+ miles. No one would buy a Magnum RT if shuddering and rough running were normal. The service manager finally was able to get authorization for parts and my hopes are that the car will run properly when I pick it up tomorrow.
This time I have been told they are replacing the control module and have serviced and double flushed the transmission.
I think the disconnect of the fly by wire throttle twice got their attention. It is a potentially deadly safety problem and there is a Chrysler Service Bulletin that is supposed to fix it. The disconnect incidents occurred upon aggressive throttle application as one would use trying to pass another vehicle on a two lane road. The problem occured the first time after my first service visit and the second time after thay did the fix called for in the Service Bulletin ... go figure.
Stay tuned and I will report after I pick the vehicle up tomorrow.
The 2005 Dodge Magnum R/T with the trailer tow prep group is equipped to tow up to 3800lbs. So you’ll be able to tow the 2500lbs with ease, with or without the transmission cooler. Dodge wouldn’t release information stating that the Magnum can tow 3800lbs if transmission heat would be an issue. So the decision to get a transmission cooler is really personal preference.
Well enjoy what’s left of the camping season!
John B.
I just called to see if it was ready to pick up at the dealer and my contact said the service manager drove it after installing the new control module and double flushing and servicing the transmission and determined the problem is not fixed! ... so they have ordered a new torque converter and the installation should be completed by mid or late next week.
I have my fingers crossed and am thankful a real effort is being made to correct the shuddering problem. I was told the control system has 15 sensors, so if the new torque converter doeesn't do the trick ... only 15 mort things to explore.
Fortunately, I own a very low mleage 17 year old "garage queen" Corvette that needed some driving.
I can't wait to get the Magnum running again like it did the first 3000 miles ... it was like a quiet ... powerful ... smooth ... magic carpet! I loved it!
Stay tuned ...
I think i have some problem with the transmission, when i brake hard then let off and step on the gas it seem like it slips or hesitates. it also seem like it slam into gear also around the same time.
I do have the problem with the ruff idle but it sometimes depends what gas station i stop at.
i bought my RT in may have 5500 mile. Dose any one know of any new service update as of late may. I am going in to get a service and would like to know about any so they do not try to pull a fast one on me.
thanks all, this site is great love my mag it pulls my boat great and rides i style.
I bout my Magnum 2 weeks ago, having issues with the radio & had problem with the u-connect, but dealer fixed that...now dashboard is bubbling in 2 spots, taking to the dealer today to see what happens next.
Do they just give you a new mag or do they pay off the car?
I have heard about lemon law but do not know how it works any help would be great.
It replaced my beloved 2003 Yukon XL- she just ate too damned much !!
I hope I like my Magnum as well as my Yukon, it was VERY hard for me to let her go.
Does anyone know if you can use Ethanol blends in the new 2006 Hemi, the dealer emphatically said no and suggested I use premium . Certainly not gonna happen. I just don't ususally trust what service guys tell me, so I thought I would come to the "experts"
Made me laugh when the tech told the owner the shudders and noises were "normal" for a magnum. Where do they get these guys and how stupid and gullible do they think we are :confuse:
Looking forward to learning about my new wheels :shades:
