99silverado vibration problem
Waiting to buy a 2000 Z-71 ext. cab when my dealer gets one. I'm disappointed to see the above post on the 2000 model that shakes. I hoped that would have been corrected on the 2000's. A couple of questions:
1. Do you think the vibration/shake will show up on a test drive or does it appear later (after the sale!)
2. Does anyone think there is a certain assembly plant that has produced more of the problem trucks (worn tooling, etc.)
Works for me!
Right on time!
Thanks for all the info Steve
- "Wrath of Tim"
Steve
You mean at the Factorys as well for the parts?
Mine is to be built that week...any effort to have this never even happen would be awesome on GM's part!
I got a 2000 3/4 .....seems I haven't seen any posts for shimmys on those yet?...or have there been?
Tim
Can someone tell me what options, if any, are NOT
having problems?
6 bags of sand in the back and do a test on some hills. Results : It still has the vibration! right at 1500 rpm. Seems like they changed the trans. shift points also and I liked it better the way it was before ! I waited 8 weeks for these special shims. Still a great truck I hope they get it figured out soon.
Tires, wheels, shocks, new design suspension,or we are all not ignoring the problem like the guy down at the shop. I hope someone finds the problem soon before I get tired of it and start replacing the stuff myself.
Could somebody give a summary or refer to a previous posting that explains the vibration problem. Also, How will I know by test driving a new truck if it has a vibration problem.
I am interested in the Ext.Cab 2WD SB 4.8L or 5.3L
Any comments would be appreciated.
Potential Buyer.
They don't all drive like that. I have 11,200 miles on my 5.3L reg cab long bed. It is smooth and absolutely without vibration at any speed. But I don't know why some do and some don't. I've been looking for a common denominator. Does anybody with the 65 mph steering wheel shimmy have the PF9 aluminum wheels, or is this mainly found with the steel rims?
Still, there are about 3 different vibrations covered in this topic. The launch studder you have, the 35-42 drive line growl (eprom reflash), and the 65 mph shimmy (B9 hubs, rack and pinion preload adjust).
But I agree with you, the 3.42 seems to be the more common factor in at least two of the three cases. But I do remember reading about a vibration in a 3.73 Z71, and also a reg cab model. More vibration problems with 2wd than 4wd, but that could be the 3.42 issue since 4wd don't have it.
By the way, try swapping your wheels to the other side on the same axle to get rid of the steering-pull-to-the-right. My alignment was always spot on, but the pull, since corrected, was caused by the tires.
it will be late Sept. When I was odering I ran into a couple quandry's. I was told the 3.73 is only available on reg cab with limited slip,and 3.42 w/LS on ext cab models. Not available the other way around. Also The only tires available were 235x75, or 255x70. I will be getting the latter due to the fact I also got the z85 HD suspension pkg. I am going with the 3.42 rear due to the limited slip. I was just thinking that maybe GM has fiqured out some of this vibration problem by making only some rear with some tires available. Just a possibility. Also mine has the standard m30 auto tranny. Could some of this problem be associated with the new to/haul tranny with the wrong combination of rear? Hmmmm?
I think an earlier poster may have hit on one issue with a vibration potential...extended cab. They all have the two piece drive shaft. I don't know that, it's just a possibility.
SCRAW MANY THANKS FOR YOUR ASSISTANCE
I pick up mine Monday and will jump on the highway for a few miles before I sign...
Did it show up right away for most of you?
- Tim
Whew, I'm exhausted now, I didn't know I had it in me to make this oration. It's just that I get P'd off on this subject, when all GM is doing is shot gunning us with patches and make do's (instead of diagnoising the source) that don't seem to work, and in some cases make the original problem worse. Thanks for listening.
I love GM too...but some of their ways really suck!
- Tim
I too absolutely love this truck and want to keep it. Just want this fixed.
Good Luck
- Tim
Good Luck, it worked for me.
http://calid.gm.com/vci/
