Mazda6 Maintenance and Repair
1282931333457
  • slickdogslickdog Member Posts: 225
    I agree that the Mazda6 ACC system isn't the best, as I've certainly used much better. However, I'd rather control things manually so it really doesn't bother me that much.
    My system also drops completely out of auto mode if I monkey with either the A/C button, the fan mode button, or the fan speed dial.
  • sweetsixteensweetsixteen Member Posts: 40
    I know many of you had mentioned this before, but I was curious if it has proven problematic for some people. I was driving home today when gradually my car started to shake. I thought maybe I had punctured a tire or something so when I get home I look and all the tires pressures are good. Then I look and realize that ice and snow had built up in the wheel well and was rubbing against my tire. I only had the car out in the snow for one day and its already built up enough to cause this problem. Do you think this is having a rough impact on the tread of my tires? A very bad design in my opinion.
  • baggs32baggs32 Member Posts: 3,229
    I have the same issue with cabin temp. I have to crank it up to 80 to get warm air to come out.
    I had to do that one day too. It was about 50F outside and we were travelling on a highway. The inside temp was set to 72F and cold (not cool mind you) air was blowing in our faces. I finally gave in and jacked the temp up to 82F and warm air finally started coming out of the vents.
    I also find myself adjusting the inside temp quite often just to maintain a comfortable atmosphere. These systems are supposed to be fully automatic and something you can set and forget. Not something you have to adjust more often than the radio.
    The only thing I can think of that might be throwing the system off is the sun sensor on the top left corner of the dash. I'm wondering if it overrides the temp sensor by your right knee when the sun is shining somehow.
    Other than the ACC the 6 is an awesome car and I don't regret choosing it for one minute. Stubborn ACC and all. :)
    FWIW the manual states this for the ACC...
    For an optimal cabin temperature,
    set the temperature close to 25.0°C
    (77.0°F). Adjust to the desired
    temperature if necessary.
    If I set my themostat to 77F in my house I'd be a lot thinner right now. :)
    68F - 72F seems more normal to me.
  • qddaveqddave Member Posts: 164
    Right, but the conductive steel panels and single pane glass of your car don't have near the insulation qualitites of your house. Think of how wind chill in the winter works. If it's cold out, you feel it, if's its cold and windy, you really feel it. Same thing happens to your car. The faster you drive (higher relative wind speed), the more heat is being sucked out of your car. Now for cooling in the summer, yeah, you'd cook, but that 77F comment is probably a setting that will cover the climate in "Everywhere, USA", and Canada for that matter. Think about how complex the manual would be if they suggested a temperature setting for every outside temperature in every city in North America.
  • mz6greyghostmz6greyghost Member Posts: 1,230
    If your car started to shake, then I think that you had snow buildup inside the wheel hub itself, which threw the wheel off-balance, causing the car to shake. I've had it happen to me when I drive in deep snow with the "open" 5-spoke wheels, much like the 6's.
    When I bought snow tires, I purposely bought the steel wheels, which are not as "open" as the 5-spokes, and keeps the snow build-up out from the inside of the wheels.
    As far as the snow build-up inside the wells is concerned, there has been a lot of concern mentioned about wearing the tires. I've driven in heavy snow, ice, slush, and even mud, and build-up has never been an issue with my 6. The only thing I've noticed is a slight rubbing sound when I make a sharp turn in the snow, and it's only happened twice on two different days. In both instances, it lasted a second, then went away. Yes, the snow tends to build up inside the wheel wells when driving. With snow tires, theres more build-up due to the snow being displaced. But I doubt the build-up will cause the tire to wear down. If it comes in contact with the snow, it usually "cleans it's own path", and keeps the snow from building up within it's rotation.
    It doesn't hurt to take the butt end of your snow brush, and knock the build-up out of the wheel wells after you've reached your destination. Other than that, don't sweat it. Worry more about the other drivers around you doing 75 in four inches of snow and ice in their "unstoppable" SUV's, only to skid out and bury themselves in the median!
    I think you're missing the point. I shouldn't have to set the temp in my car to 80F in order to maintain 70F. The system just doesn't work right. Insulation problems or not.
    Since the ACC systems in my dad's past two Fords work as advertised maybe Mazda should have raided that Ford parts bin for the 6 too. :)
    Makes sense. But it doesn't explain why the ACC won't heat the cabin when set to 70F if it's near or below freezing outside. You'd think that with all the heat being drawn out at highway speeds 70F would be plenty high enough to warm the cabin. the calibration has to be way off or something.
    At least the outside temp seems to work well. :)
  • likaglovlikaglov Member Posts: 82
    baggs32 - I think you are right about the sunlight sensor. It must overly complicate the complex algorithm used by the ACC computer :-) I might try to cover it up and see how it behaves. On the down side, the A/C still runs at night when it's 30 degrees outside... maybe the street lights confuse it further :-)
  • wtlwtl Member Posts: 11
    Interesting reading to the ACC. I too have some finding here and would like to share it with you for your comments.
    Here is the deal...outside temperature has been around 30s these few days, with interior temperature set at 72 degree, I have found that the air circulation control bottom does not response to my command. Here is my observation:
    When the car is first started (cold engine), if I have Auto climate control ON, cir circulation will stick with interior circulation, but the air circulation control will disregard my intention to change it to outside circulation. If the car is at Manual climate control mode, air circulation will stick with the mode that was on from last driving setting (note that I am sure I am not using defog to windshield at the time). I also found that if I start up at Manual climate control mode, with whatever air circulation mode to start with, changing of Auto/Manual climate control does not make air circulation response to my input.
    When engine is warm-up, or after driven for a while (~30 minutes), air circulation bottom will some times be able to changed (while fan speed, climate control mode, etc has not been changed from above description). Sometimes it will response with about 1 sec delay (a quick push won’t do it, it takes push and hold for a blink while to see the light change from green to red), sometimes it will “cycle” back to original mode by itself (i.e. goes from interior circulation to exterior, then back to interior; and it can be done with a light push of the bottom), but most of the time, it just won’t take any of my command.
    I don't mind to leave ACC ON, but I do want to be able cut outside air off from time to time. Any idea?
  • sstrz1sstrz1 Member Posts: 28
    Go back to your manual.......
    1) A/C- your perception is right- the ACC always lights up the A/C display, but......
    2) Auto Climate Control- please note that the A/C display will ALWAYS come on 100% of the time- but this does not mean that it is running....yes- I would like that fact that it came on only when the a/c was actually on, but who the heck knows the thought process of the engineers who designed the car- I look at it as the fact that if nec., the car will opt. to turn on the a/c...do you really think that the car is "fighting itself" by turning on the a/c while blowing hot air?- come on now!
    3) How to use ACC- as the manual states- set the ACC @ 77 degrees, and "let it go"....sure, my house in the Northeast is "kept" btw 68-72 degrees year 'round....and I wish I can set my ACC in my car the same....but I cant's.....though it makes no sense to set the ACC to 77 degrees- just do it!...it works!....and at worst, I may adjust it 2-3 degrees lower- get over it!
    Hope this helps......
  • rattlerrattler Member Posts: 7
    Can anybody tell me the TSB number for the clanging sound during window rollup? Thanks.
  • ebeneben Member Posts: 26
    "Does the little green light on the auto button go off as well as the word "Auto" on the display?"
    Yes. If I select auto ACC, then turn AC off, "auto" unlights from the display. However, as long as I don't adjust fan speed or blower mode, the system continues to automatically control those.
  • grahambgrahamb Member Posts: 47
    there is no kit available yet. I believe the two companies working on them are Metra and Sosche, but both keep pushing their release dates back, and one of the companies may have abanonned it altogether.
    Anyone that has an aftermarket system in their car has done serious custom work.
  • alaialai Member Posts: 4
    Can someone tell me if you put snow chains on the Mazda 6 Sportswagon? I have a 2004 Mazda6s 4dr Sport Wagon (3.0L 6cyl 5M with the luxury & sport package. I really need help on this one!
    From page 4-9 of the '04 Mazda6 manual:
    Tire Chains
    This vehicle cannot be operated with tire chains because it could cause interference with the vehicle body and scratching.
    Hello!
    Don't they say that for all cars? Gosh darn it, now I am having second thoughts about taking my car up to Mammoth in a few weeks. Has anyone out there put chains on thier Mazda 6 yet?
    Probably so, I've noticed it in other owners manuals.
  • escortownerescortowner Member Posts: 132
    I know first hand why they say that....my dad did that on a car a long time ago and the chain broke and beat the hell out of the side of the wheelwell.
    However, it was because he was in rushhour traffic and the snow had melted after a certain point and he just drove on the solid pavement....so, of course a chain could break.
    Regardless - I am in the Southwest so chains don't really apply here. Just thought I would mention why a manufacturer may say that about the car.
    If it were me....I wouldn't let that stop you from going to Mammoth.
    I read an interesting thread on ACC on another forum and then played around with it myself the other day and this is what i've confirmed.
    Push Auto button - Auto lights up, A/C lights up. It controls temp, direction, fan speed, and circulation.
    Push auto then press A/C - auto light goes out. A/C light goes out. It still controls the temp, direction, fan speed, and circulation.
    Push auto, then change the direction (even press A/C if you'd like) - Auto light goes out when you change the direction, but it will still control the fan speed and direction.
    Basically if you turn auto on, the only way to get it back to fully manual is to adjust the fan speed. Next time your car is warmed up turn on auto at about 75. turn the A/C off....then crank the temp up to 90. watch it adjust the rest of it.
    (As I'm writing this I'm realizing that I actually didn't pay attention to the circulation light, so I'm not sure if that still adjusts. I AM certain that it will adjust everything else automatically, even if the auto light is out, regardless of what you adjust, until you adjust the fan speed.)
    The recirc button always goes back to fresh air....I just checked it out.
    I too played around with it the other day and came to the same conclusions. However, it was 41F, raining and foggy while I was doing it and all the windows in the car fogged up on me. With the ACC in (for lack of better words) full on mode, and the A/C running, the windows never fogged up before.
    So I guess there is some benefit to the A/C running all the time but I'd still rather control that function manually. I mean, it's one thing to turn the A/C on when the defroster is on (most vehicles do this without you ever knowing) and another to just leave it on all the time sucking extra fuel out of the tank. Once the defroster shuts off, when in auto mode, the A/C should go down with it.
    One last thing. It should be noted that this whole ACC discussion really doesn't belong here in the problems board as it is not really a problem. Just a slightly bad design that can't be fixed. All we're doing is making this thread fatter and that could potentially turn some people away from what is an otherwise spectacular car. Anyone else agree and want to move this over to the Mazda6 thread? Am I just nuts? ;)
    Hopefully this is an easy question.
    I want to purchase some speakers for my 6. I have looked on 2 different web sites and gotten 2 different speaker sizes. I got a 6.5" round, and a 6x8" size. Anyone know which is correct?
    Well. I have sort of answered my own question. I know in the front they are 6x8...is it the same in the rear?
    Sorry for continuing the discussion, but I too played with the system yesterday when it was raining (which makes it easy to tell if the A/C is on or just the light). I have confirmed the following:
    1) If the A/C light is ON, the A/C is ON (regardless of temperature setting).
    2) If you push AUTO, the A/C comes on with it (all the time).
    3)You can turn off the A/C using the button, and the AUTO will stay ON (even though the light goes out) and the A/C will turn off. It will stay in AUTO unless you adjust the fan speed or turn on front defog.
    4) When you use the front-defog, it runs the A/C without the turning on the light (this is stated in the manual as well).
    Not clear why the dealer couldn't just explain this (instead of saying that the A/C always runs with the ACC). Now that I know how to work the system, I think it is OK.
    Thanks to everyone for their clarifications.
  • fitguyfitguy Member Posts: 220
    I had read somewhere on the forum about someone with a noisy heat/ac fan that got progressively worse and had to be replaced. Mine is a little noisy now, wondering if anyone else has had fan problems. It doesn't really bother me, but the car is going in for 1st oil change and I'd like to address it w/the dealer if it seems to be a common problem.
  • suydamsuydam Member Posts: 5,194
    If anyone can stand one more, I just discovered (after 3 years!) that my Nissan Maxima doesn't even HAVE an AC button! It really is set up for Auto control, and you just set the temperature you want and forget it and it works beautifully in all weather. Maybe that's what's confusing all of us. If that button wasn't there to light up or go out, we wouldn't even be thinking about it.
  • red sixred six Member Posts: 1
    i have the same problem with my 03 mazda 6,it is shaking and my stepdad said that the rotors were messed up and to call mazda that it should still be covered by my warranty but apparently my brake warranty ran out when my car got 12,000 which isn't right. i was going to get them turned but what is the point if they are just going to get warped again.
  • mazdajkmazdajk Member Posts: 28
    I have been reading you guys go back and forth now for awhile about the 6's ACC system. If you have not figured it out by now, the ACC is not going to give you the results it was intended to do. There are too many changes in Temperature, Humidity, Frost, Sun, Shade for it to give you the exact results you want.
    Personally, I wish the ACC was never put on this car in the first place. Obviously, Mazda did not do enough research and designing to truly give us an automatic climate control.
    I have had my Mazda 6 for about a year now and gave up on the ACC months ago.
    Here is what I have found to work best for me and I have had no problems since. I live in Wisconsin and there are a lot of extreme temperature and humidity changes throughout the year. One of the main complaints about this system is the fog that forms on the windshield when it is humid and hot out. What I have found is that if you have the air conditioner on to cool the inside of the car and you have the control knob in either all floor or floor defrost, the AC will blow on the windshield, obviously causing the fog to form on the windshield. What I have been doing is running the AC manually in the floor/panel setting and have had much less, if none at all, fog form on the windshield on hot and humid days. If you notice when you have the control setting in all floor mode there is a considerable amount of flow from the fan blowing cool air directly at the windshield. This is what causes the fog. When you have the setting in floor/panel, the majority of the cool air is coming from the panel vents and some from the floor vents. If you put your hands by the defrost vents, you will feel very little air coming out of those vents. If you do not like all the cool air blowing directly on you from the panel vents, close some of them. This will send more air to the floor but not at the windshield.
    Winter - It depends on what your priority is. If you want your car to warm up fast, and there is no frost to be loosened from the windshield, put the manual setting on floor. Put the recirculation control on inner air recirculation. I agree also keep the fan on a lower setting for awhile. It is easier for the engine to warm the cabin air that is warming than to try to warm the frigid air being sucked in by the air intake. Once the air starts to warm, turn it back onto fresh air recirculation or the windows will start to fog up on the inside because of the humidity in your breath. If your main concern is to defrost the windshield, obviously you need to shoot full air to the defrost and hope for the best.
    I really have to get a kick out of all of you guys and it has been an interesting read for the last nine months but come on, you guys have to finally realize that the ACC system is basically worthless unless you live in an area that has very little temperature and climate change. The system might have had a chance if it took into consideration the due point/humidity. We all can agree that a temperature of 80 degrees with a due point of 62 is much more comfortable than with a due point of 75. If you set the cabin temp at 70 the ACC will cool it to that temp. Don't dare open a door or window if it is humid outside. I just feel it is easier for me to control the temp myself to my comfort level and not let the ACC system tell me that I should be comfortable. I tried all last summer. Never got any consistent results.
    The one thing that really ticks me off about the ACC system is that even in summer when I have nothing on whatsoever, the AC is off, all fans are off, the ACC is off, I have noticed that there is still condensation dripping from the AC compressor. This obviously means that the AC is somehow still running with no cool air being used, all buttons are shut off, and I have to wonder how this is affecting my gas mileage.
    Good Luck to all! *@%& the ACC and start enjoying the rest of the car.
    John
  • dv8erdv8er Member Posts: 8
    Hello fellow 6 owners!
    I've had my 2004 6 4i/manual for about 5 months, and recently started hearing a noise coming from under the rear passenger area. It sound very similar to a washing machine running (whirr-whirr) and is very rhythmic. It does not seem to increase/decrease with engine RPM or car speed.
    What's even more interesting is that I can't cause the noise to happen, or happen regularly. Luckily I was at the dealer for a different reason and it made the noise, but the tech was not able to hear it later when they actually got it into the shop and were trying to narrow it down. They said they would have to leave the work order open and consult Mazda more, as there is no documentation or TSB's on this.
    Figures...I always get stuck with the "undocumented" problems.
    Has anyone else experienced this problem with their 6? I'm guessing that it's the fuel pump, but have not had a chance to get under the car myself.
    Any insight would be great!
    I agree with you...if not for the button and "a/c" on the display...no one would even notice!
    What do you guys think would be the best way to clean the dash and stereo panels? The winter has brought its share of salt, water, and sand into my interior. I used those pledge orange wipes, but now parts of the dash have small black streaks that wont rub off. Any ideas?
    I know there has been past discussion on here about the sulphur smell. My 1-year old M6s-AT has had this issue on and off the whole year I've had it. Initially it was only noticeable in the garage after driving home from work. Lately it's been detectable in the cabin and this morning it about made me sick while driving in to work.
    First time I took it to the dealer they said "switch brands of fuel and if it still does it, we will fix it next visit". On my next visit (5600 miles) they said that Mazda would not fix it yet because the engine was not "broken in". I'm trying to find out the name/number of the Mazda regional rep that I can talk to.
    Has anyone had this problem corrected? Was it just a matter of replacing the cat converter? Anyone else have the issue inside the cabin?
  • dayokayodedayokayode Member Posts: 31
    Sorry for being so dramatic. I work for an intl org in Costa Rica and currently own a 2005 Mazda 6i (leather and auto with ~8200km) built in Japan. However, I have to move to the UK; I will be leaving for the States next week and eventually going to Europe in February. Since I've not been able to sell the car (I bought it tax free and selling it has been a nightmare because buyers without tax-free status would have to pay huge taxes and complete inordinate paperwork).
    I love my car very much and don't want to leave it here for someone to sell on my behalf. As such, I wanna ship it to NY because it doesn't make sense for me to take it to the UK. Does anyone know if it would meet NY/US standards? Is there a big difference between Mazdas built in the States and those manufactured in Japan? If the car is not sold by this weekend, I will have to ship it to the States.
    I look forward to reading your suggestions and comments.
    Thanks so much!
    Don't know if anyone has experienced this but thought it worth mentioning: My 6S sat for about 4 days in very cold temps (-5 to 20), during the awful snow up north I use our SUV instead. Took it on a trip yesterday and noticed a vibration similar to wheel un-balance. The 17" Michelins seem sensitive to flat-spotting under these conditions- it took over 50 miles of 75 mph driving to warm them up enough to get rid of the vibration. I've had many other cars with Michelins and never had this problem; figured I'd post here so others won't condemn the tires, car or waste money on wheel balancing.
    While cleaning my windows today (being the idiot i am), I knocked a bottle of windex over and a decent amount went onto my hood. Considering that windex has ammonia in it, will this damage my paint at all?
  • civiceater4uciviceater4u Member Posts: 7
    hey for speakers both fronts and rears are the same. i replaced mine myself and found out the hard way they are 6*8s. dont forget u got 2 small tweeters that are on the front doors. i forget wut size they are but they should say. hookin up an amp and subs is easy
    hey to clean the car i use armorall cleanin wipes for the cars dash and the doors. it gives it a good shine and protects it from uv rays. it makes it last a lot longer. i also use the class cleaner for the windows and hard to clean spots. in 20 minutes my car looks better then it did at the dealership
    I had 2 amp's installed - a 4 channel for the speakers, and a 2 channel for the Subs. I built a box, and am now looking for a sub....well, I know what I want, but havne't bought it.
    I bought new speakers, but the front ones I bought will have to have some custom work done to them. I bought some 6.5 inch round speakers with separate component tweeters. Unfortunately, I think the tweeters are a little too big...I will have to check. Mine are 1 inch, and someone said the stock ones are .75 inch.....but I know in the end it will all work out and my system will rock.
    Anyone know about bass blockers? I am going to put some on the front speakers. I was thinking about putting some bass blockers in series with treble blockers for the mid's, thinking that it would limit the range of sound that was emitted...anyone done that before and know how it works?
    "Don't know if anyone has experienced this but thought it worth mentioning: My 6S sat for about 4 days in very cold temps (-5 to 20), during the awful snow up north I use our SUV instead. Took it on a trip yesterday and noticed a vibration similar to wheel un-balance. The 17" Michelins seem sensitive to flat-spotting under these conditions- it took over 50 miles of 75 mph driving to warm them up enough to get rid of the vibration. I've had many other cars with Michelins and never had this problem; figured I'd post here so others won't condemn the tires, car or waste money on wheel balancing."
    I'd say those weren't flat spots. I think those take a lot longer to form. I'd guess that it was snow/ice stuck inside the wheel. It made the wheel unbalanced and eventually fell out.
    Nope- I thought that too, at first; stopped and checked. I actually keep a long-handled plastic scrub brush in the trunk and use the handle to clear out those nice tight-tolerance wheel wells from snow/ice buildup. Those tight wheel wells and the loud heater fan are my only gripes with the 6- otherwise, the car is awesome.
    ....so I have had my car for about 2.5 weeks - it has 600 miles on it. I just noticed a couple of days ago that when I roll up my driverside window it makes this low clicking noise. I am going to take it to the dealer, but I was wondering if anyone has had this issue so far with their car?
    nothing major so far - just a comment.
    For any of you that want a different head unit for your car stereo....METRA has just come out with one. It is supposed to be able to replace the center console and retain all of the functionality of the ACC. It isn't scheduled for release until Feb 28. Also....it looks a bit pricy....MSRP is $190. I saw one for sale for $170.
    that's all I have....oh, and aparently you can get a CD changer adaptor to hook up external devices like an IPOD etc.
  • jahnu04jahnu04 Member Posts: 58
    My garage door opener has a thin metal hook that holds the opener to the sunvisor. The metal piece is a little bent outward at the end. Yesterday I noticed that the pressing of this against the roof has caused two small holes on the roof fabric of my 2 month old MZ6 wagon. I had this same opener on my camry for years and did not even see a impression. I also have a similar opener on my wife's Xterra and have been using it for the last 4 years and no holes/impressions. This tells me how cheap the material quality of my new wagon is. I am very disappointed with this car. Already have been in the shop for 3 different problems.
    Does anybody know if this can be repaired or if the holes can be filled? It's only visible when the sunvisor is lowered.
    GK
    I don't know how to fix your issue, but I had a feeling this may happen with mine, so I just put it in that huge storage bin above the center console with velcro. It still opens the door without having to take it out.
    I was planning on using the 3M Command adhesive strip to stick the opener on the top/inside of the bin. I have used this strip on many household items and it comes out neatly.
    I actually clipped my opener to the inside of the driver's door compartment right beside the water bottle holder. I didn't want to look at it on my visor (or make a permanent impression, like it did on my Civic). It took a little while to get used to, but it works great. Only problem is when I drive the mini-van, I always reach down to open the garage door only to remember it's not there in the van :-)
    Sounds like an even better idea :)....the other alternative is to pay $300 for a garage door opener that is built right into your review mirror (AKA Homelink)....hahaha.....I wanted it, but I hear the labor for install is tricky.
  • lefthandmanlefthandman Member Posts: 47
    As likeaglov, I also clipped my garage door opener to the inside of the driver's door compartment. If you find that it rattles over rough road surfaces, place a piece of foam or soft cloth between the lip of the door compartment and the opener. I used this same placement on my previous VW Golf and have never had a problem getting my garage door to open or close with the opener in this location.
    I agree with you about the interior materials on the 6- my '03 Accord had higher quality, more durable materials everywhere in the interior. Switchgear much better quality, too. I took this into serious consideration when I bought the 6; I still feel the 6 is a heck of a lot more enjoyable to drive and worth some extra caution with the interior bits. My wife is a ring fanatic and I've reminded her several times to be careful with the painted silver on the door handles and center console- otherwise it will scratch like crazy as it's pretty cheasy. I still can't condemn the car (sorry you've had problems already, mine has been trouble-free thus far) and would purchase it again. Hopefully someone from Mazda marketing research cruises these forums and takes notes; with just a little more attention to the little quality details the 6 would be first-rate.
    i've heard from a lot of guys on a different forum that this install is easy. basically just running a wire and plugging in on your fuse panel.
    you can buy it from mazdastuff.com for 225.
